Glider towing with 08 Honda CR-V?
Old October 18th 08, 07:35 PM posted to rec.aviation.soaring
Default Blaink L-13 right wing needed. (USA)
Call me. I can help. Fred 661-944-9449
On Oct 16, 8:39*pm, Pete Brown wrote:
Any leads on a Blanik L-13 right wing for sale would be appreciated. Can
be located anywhere in the USA. Please call or email with details.
Thanks
Pete Brown
work: 907-564-0450
cell: 907-748-7529
Old October 16th 08, 03:33 PM posted to rec.aviation.soaring
Discus 44
Default Glider towing with 08 Honda CR-V?
On Oct 15, 8:30*am, Tuno wrote:
I just bought a 2008 CR-V with no expectation of towing anything with
it, but the book says it will tow up to 1500 pounds, so now I'm
wondering if it would be worthwhile to add a hitch so I can tow a
utility trailer, and the glider for short hauls or when the primary
tow vehicle isn't available.
I imagine the top towing speed would be pretty limited ... the Honda
Pilot I used a few years ago was subject to fishtailing above ~63 mph,
regardless of the trailer tongue weight. With a shorter wheel base,
the CR-V would likely be worse. Does anyone have any experience towing
a glider behind this generation CR-V?
Thanks
~ted/2NO
Ted:
I own a Honda CRV 2007 and I had the trailer hitch added. I towed my
Discus in a Cobra trailer with it just fine on freeway and local
roads. Freeway speeds of 70 and climbing hills 60. It is noticable
on the passes that you may not maintain full speed limit but it gets
there while sipping gasoline.
Old October 16th 08, 07:52 PM posted to rec.aviation.soaring
noel.wade
How about my 2000 Mazda Protege ES? 70mph towing an 80's Cobra
trailer with a DG-300 inside. Over the Cascade mountain pass between
Seattle and Eastern Washington state I get an even 20mpg. :-)
But I will admit that strong cross-winds and speeds over 70mph are a
problem, as the car itself is fairly light-weight and the wheelbase is
shorter than most SUVs and trucks (I put 75lbs of lead in the front of
the trailer and it helped a lot). I would have the same concerns with
a CR-V.
--Noel
Motorhome towing a glider trailer tmlkbr Soaring 11 May 14th 08 06:44 AM
Towing glider trailers with a VW Jetta Wagon? Allan[_2_] Soaring 20 August 24th 07 01:20 PM
Glider Towing Available - Payson AZ (& local) [email protected] Soaring 0 June 5th 07 10:20 PM
CAM 125 Honda [email protected] Home Built 4 November 20th 05 03:26 AM
Glider trailer towing Jeff Landfield Soaring 0 July 21st 03 04:25 AM
