gutsy
Old October 29th 08, 09:49 PM posted to rec.aviation.soaring
Ralph Jones[_2_]
Default gutsy
On Wed, 29 Oct 2008 15:42:06 -0600, Ralph Jones
On Wed, 29 Oct 2008 10:53:05 -0700 (PDT), Frank Whiteley
http://www.youtube.com/watch?v=XRCbkBfdBrQ
Almost nothing about that video passes the smell test. Just a couple
of observations:
1) The wing root that's exposed just before the airplane turns around
on the runway has no broken spars sticking out of it. Instead, it
shows two nice round holes -- which looks just like the wing root of
an RC model. In this model class, the wings are connected to the
fuselage by aluminum tubes that telescope into fiberglass tubes built
into the structure.
2) After the airplane stops, it sits dead level on the gear, even
though there's ostensibly a few hundred pounds of wing missing from
the other side.
Plus which, neither video shows a single frame of the "damaged"
airplane after the incident.
rj
Old October 29th 08, 10:37 PM posted to rec.aviation.soaring
bildan
Default gutsy
Some other things I noticed: It appears that the airplane rolls
toward the 'good' wing instead of away from it as one would expect.
The airplane comes to rest essentially level with the 'good' wing
toward the camera when it's reasonable to expect that it would sag or
even touch the ground if the other wing is missing. Even the
'failure' occurred at low airspeed in near vertical flight instead of
under earlier high G loads. It looks like there may have been several
flights videotaped with conveniently timed out-of-focus intervals that
cover editing cuts and splices.
On Oct 29, 3:15*pm, Nyal Williams wrote:
I think it has been faked. *Woman's voice didn't sound alarmed about the
wing. *Plane flew upside down in level flight briefly on one wing. *Came to
rest too suddenly after touching down. He was slow getting out -- notice
how slow he was latching the canopy open after it stopped and in his
int4rview he said he smelled gas; *I think this was from another landing
-- notice that the right wing doesn't show.
At 20:51 29 October 2008, wrote:
On Oct 29, 4:43=A0pm, "noel.wade" *wrote:
It is most definitely fakery. =A0If nothing else, the landing
"bounce"
is wrong from a physics standpoint.
--Noel
There's an awful *lot "wrong" in that video. *But the clincher is
that
if you look frame by frame while he's taxiing you can see that there's
no damage at all on the horizontal tail.
That's a con job.
Old October 29th 08, 11:19 PM posted to rec.aviation.soaring
cfinn
Default gutsy
I think this is totally fabricated. A month ago a R/C flier lost a
wing while doing a high speed snap roll and was able to land the model
by basically flying it in knife edge. Modern R/C ships have such a
high power to weight ratio, you can hover them on the prop. Here's a
link to video and pictures, and the pilot's story:
http://www.rcgroups.com/forums/showthread.php?t=931845
Charlie
Old October 30th 08, 03:27 AM posted to rec.aviation.soaring
Default gutsy
For crying out loud! That's fake as hell.
Not saying it's impossible. But that video is a weak fabrication.
Old October 30th 08, 01:42 PM posted to rec.aviation.soaring
Martin Gregorie[_4_]
Default gutsy
Here's another pilot's account of a real wing fold.
http://www.aerobatics.org.uk/repeats...ng_failure.htm
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old October 30th 08, 02:31 PM posted to rec.aviation.soaring
vic20owner
Default gutsy
On Oct 29, 2:55 pm, vontresc wrote:
Neat editing tricks......no way that is for real.
Totally fake, but here's a story of an F15 landing with one wing (for
real).
http://www.youtube.com/watch?v=DVkB7V-JybY
Old October 30th 08, 02:56 PM posted to rec.aviation.soaring
Vaughn Simon
Default gutsy
"Martin Gregorie" wrote in message
I distinctly remember a wild story of a lucky fellow who survived after a
1-26 lost some important parts in a thunderstorm, but a Google search turns up
fruitless. Does anyone remember?
Vaughn
Old October 30th 08, 03:28 PM posted to rec.aviation.soaring
Default gutsy
On Oct 30, 10:56*am, "Vaughn Simon"
* *I distinctly remember a wild story of a lucky fellow who survived after a
fruitless. *Does anyone remember?
Vaughn
http://www.ntsb.gov/NTSB/brief.asp?e...08X08467&key=1
The events preceding the wing separation as reported to the NTSB are
ahem not exactly the way the story was retold in the local
community.
-T8
Old October 30th 08, 03:30 PM posted to rec.aviation.soaring
Brian Bange[_2_]
Default gutsy
As I recall, it was published in Soaring. The pilot flew into cloud and
pulled a wing off. The aircraft spiralled down into trees at a golf
course. The trees and bushes broke the fall and the pilot survived.
Brian
after
a
turns up
Vaughn
Old October 30th 08, 04:03 PM posted to rec.aviation.soaring
Frank Whiteley
Default gutsy
For crying out loud! *That's fake as hell.
Not saying it's impossible. *But that video is a weak fabrication.
Apparently it's a production of a sports apparel company. Probably
have the opposite effect they've intended.
Frank Whiteley
