Flush Latches
Old November 12th 08, 06:25 PM posted to rec.aviation.soaring
Bob Kuykendall
Default Flush Latches
On Nov 12, 9:04*am, DRN wrote:
Sorry if this is a dumb question, but is it possible to adjust
the B&B's latch surface to accomodate different thicknesses
of hatch/shell more easily ?
Not a dumb question at all. I think the best answer is "not really."
The design of that particular Camloc latch is predicated on it being
used on fairly thin panels as you'd expect for non-structural
inspection doors on aluminum aircraft. It seems to have been primarily
designed for applications where the door jamb is relieved where the
nose of the latch is, so that the latch catches on the skin panel and
not the jamb.
On metal aircraft, it looks like the latch will accommodate a thin
door jamb, and you can accommodate various greater gauges of jamb
thickness by adding a spacer under the latch frame and bending the
button arm so that the button fits flush into the hole in the door.
However, once you get into the .050" to .070" skin thicknesses you
often find with composites, and then add in a joggled door jamb of the
same thickness, you definitely have to get a bit creative to make it
work. But considering that these only cost $5 ea and the alternatives
are 12x to 18x the price, it seems worth a little extra thinking and
fussing with it.
By the way, Dave, the other night I was at a benefit dinner for the
elementary school in Yosemite Valley that serves the families of park
employees, and I sat right behind a guy who looked just like you,
except a bit more wiry. It turned out to be Hans Florine, the speed
climber who scaled El Capitan (2800 feet, usually around 30 pitches)
in 2.5 hours.
Thanks, Bob K.
http://www.hpaircraft.com/hp-24
Old November 12th 08, 06:51 PM posted to rec.aviation.soaring
sisu1a
not the jamb.
fussing with it.
Could one not just install them with shims in between the latch body
and the inner door surface until the desired thickness latching grip
was achieved? Of course the button would need a faceplate of equal
thickness to bring it back flush since it would be recessed the same
amount the body is spaced...
This is how I planned on overcoming this obstacle when/if I am faced
with it (my hatch rim I'm intending to use these latches on is rather
thickish...) I wanted to use a composite faceplate bonded on my button
anyhow, just for the 'slick' factor. It would also have an easier time
keeping it's paint on longer... The Genesis has composite faces bonded
to the buttons on it's hatch, and it does indeed look slick although
I'm not sure if they're set to the door with spacers in between to
manipulate the grip range.
-Paul
Old November 12th 08, 07:07 PM posted to rec.aviation.soaring
Bob Kuykendall
Yes, I think that will work just fine. That's what I'm doing on
Steve's RV oil door.
Thanks, Bob K.
Old November 25th 08, 02:49 AM posted to rec.aviation.soaring
sisu1a
So as a follow up for this thread, after a bit of searching and asking
around I got in contact with the builder of the RV-9A (not RV-10...)
that had the latches I posted here about, and he looked closer at his
latches for me last time he fle, ( http://www.n523rv.com/fuselage/Cowl%...%20outside.jpg,
same pics as before
and http://www.n523rv.com/fuselage/Cowl%...h%20inside.jpg )
revealing them to be Hartwell 4050-S081 latches for those who care...
Searching for these latches was another thing entirely, as the closest
I came up with was:
http://catalogs.google.com/catalogs?...Hartwell+H4050
Luckily Dan Brown at B&B knew exactly what I was talking about when I
called him with part numbers and descriptions this morning, and had
(past tense!) 15 left for a good price. Packed them up and shipped
them to me with a bill and an address to send the check to, despite
the fact that this is our first dealing. I just love mom and pop
aviation suppliers!
-Paul
Multipoint Door Latches...need a source... DonMorrisey Home Built 1 January 7th 08 03:19 AM
