On Nov 24, 9:15*pm, "Viperdoc" wrote:
So, the encoder could be culprit for the mis reported altitude. I suppose there could be a difference in altitudes of 700 feet if the day was very non-standard (such as very cold, high pressure, etc). 30.32 is "higher then normal" for the deep south of MS but I sure hope that wouldn't have caused that much discrepancy :-) Since the altimeter was spot on to field elevation at before take off checklist, I knew that wasn't the culprit. I suppose if I understand the digital world, that the FL displayed on the transponder should match field elevation when on the ground. Is that something worthy of checking before take off to make sure they match? |
Blind encoders are just that.. Blind, they do not care what the current
proper "altimeter setting" is. ATC decoders know the altimeter settings for a given area and automatically apply the correction before displaying. I've watched entire digital radar displays report everyone 300ft off instantaneously as the altimeter setting table was loaded into the system, a momentary blink when there was no corrections, and then the updates as the new setting corrections were applied to the ModeC data received. ATC will issue the altimeter setting to the pilot in the event the "displayed" altitude does not agree with the pilot reported altitude just in case the pilot has miss set or not set the altimeter for the correct pressure. In such cases normally about a 200-300ft difference, the pilot dials in the correct pressure and then either reports a new altitude that may agree with the reported altitude, or descents/climbs to the reported altitude and the ModeC now agrees. It appears that the Garmin 3xx series transponder may have an error in it's sensor, a leak in the static line to the sensor or something creating a vacuum near the sensor as it was reading about 700-800ft to high. You state that the altimeter agreed with the ASOS setting on the ground. At ground level and not moving (ground speed = zero) does the reported FL altitude display agree? If they agree, then I would suspect that the static line might be off the back of the encoder transponder and that in-flight the encoder is sensing cabin pressure and not outside static pressure. In flight in C-172s, the inside cabin is slightly lower pressure than outside due to vacuum effects of a leaky fuselage. I'm somewhat surprised, if the pilot is part owner and flies this aircraft regularly, she does not know the operation of her transponder. She can select STBY, ALT and put in the code, but she does not understand it's operation. A nice thing about those transponders.. the VFR button will automatically load 1200. BT "Viperdoc" wrote in message ... I have flown with a couple of Garmin 327's and now have two 330's. The pressure altitude readout on the transponder comes (as I recall) from the blind encoder. It is obviously not connected to the altimeter setting. So, the encoder could be culprit for the mis reported altitude. I suppose there could be a difference in altitudes of 700 feet if the day was very non-standard (such as very cold, high pressure, etc). |
On Nov 24, 7:15*pm, "Viperdoc" wrote:
I have flown with a couple of Garmin 327's and now have two 330's. The pressure altitude readout on the transponder comes (as I recall) from the blind encoder. It is obviously not connected to the altimeter setting. So, the encoder could be culprit for the mis reported altitude. I suppose there could be a difference in altitudes of 700 feet if the day was very non-standard (such as very cold, high pressure, etc). That is for sure. The altitude used by the transponder for all us flying non-digial, non-flat screen bug smashers is not the same necessarily as what you see on the panel. However, in my experience when ATC is getting the wrong altitude its almost always either a calibration issue or a wiring (i.e. dirty connectors, etc) issue. Its usually something a good avionics shop can fix in minutes. -robert |
A Lieberma wrote:
On Nov 24, 7:54 pm, "Robert M. Gary" wrote: My guess is that its a new C-172 with the G1000 with the transponder just built in. There is a button along the bottom of the PFD that brings up transponder options. The transponder is no longer a separate unit. -Robert Robert, One thing I can say, it wasn't the G1000 I put in my reply to BT it was a Garmin product looking at pics on Google. I hope instructors learn from this to take the time to teach how to stop the mode C. In my training, I never got such training. My transponder on my plane is the king analogue flaver, just off, stby, alt and test and turn knobs to squawk. Nothing to think about on my transponder but when you start getting digitalized with more options, maybe some basic transponder 101 with explanations on why you do what should be in order for flight training??? Yes, instructors should cover things like this, but the pilots should also read the avionics manuals! Most people I know have never read the manual for their car let alone their avionics. There is simply no excuse for this. Matt |
On Nov 25, 7:23*am, Voyager wrote:
Yes, instructors should cover things like this, but the pilots should also read the avionics manuals! *Most people I know have never read the manual for their car let alone their avionics. *There is simply no excuse for this. Agree Matt for airplane owners, but I guess some forgiveness should be given for "renters" for practicality purposes. I don't know of any airplane that has all the user manuals for all the avionics in the plane. I would suspect checkout should include instructions on Xponder operations and during training as well. I never got such training. |
A Lieberma wrote:
Little did we know how much "communicating" was in her future! You dog... |
| Thread Tools | |
| Display Modes | |
| Transponder problems with ATC COMS - Video | [email protected] | Piloting | 8 | November 27th 08 01:56 AM |
| Pop up IFR clearance with ATC COMS - Video | [email protected] | Piloting | 0 | November 15th 08 06:05 PM |
| Pop up IFR clearance with ATC COMS - Video | A Lieberma[_2_] | Owning | 0 | November 15th 08 06:04 PM |
| Pop up IFR clearance with ATC COMS - Video | [email protected] | Instrument Flight Rules | 0 | November 15th 08 06:04 PM |
| No Gyro and ILS approach with ATC COMS - Video | [email protected] | Instrument Flight Rules | 0 | November 1st 08 05:10 AM |
