#11
On Dec 11, 11:53*am, wrote:
I like the planform. A little retro, a little contemporary - plus you gotta have forward sweep unless you want the back seater to sit on the spar. The Duo planform is similar, with the tips swept back. The Arcus seems a bit more radical in the sweep changes, but that could just be due to a narrower chord, which it appears to have. 9B Agreed, although I'm not sure I find it aesthetically pleasing (says the man with a Russia AC-4 for sale!)... I'm betting the change in wing-sweep on the outboard sections is to reduce twist loads and improve the behavior/control-authority at the stall - but that's just a guess from an amateur aerodynamics enthusiast. :-P Also, I'm betting it would be weird to try to fit winglets onto a tip that is swept forward. Very cool, though! The future is now... --Noel (who is betting that electric prop-jobs will be much easier to qualify and get insured than Jets, for the foreseeable future; at least in the USA) |
On 11 Dec, 16:32, Greg Arnold wrote:
Andreas Maurer wrote: On Thu, 11 Dec 2008 09:16:01 -0600, "Paul Remde" wrote: Cool! A very kind r.a.s. friend sent me a PDF with drawings of the Arcus. It looks great! Beauty is in the eye of the beholder... I still cannot get used to this wing planform. A 3-side view can befound he http://ukjuniors.blogspot.com/2008/12/new-duo.html ... although I don't know if it's already an official drawing. Bye Andreas Is there a higher resolution drawing out there? Interesting that the first announcement of a new SH product appears on the Lange webpage. Two friends of mine, one in Scotland and one in the US, have received notification about the Arcus direct from the Schemmp-Hirth factory saying that it would be available in pure glider, turbo, self launching (I presume conventional engine) and electric self-launcher versions. So the Lange website wasn't entirely the first announcement. What interests me is not the wing planform (which I like) but whether they use a Ventus-type aerofoil section or do they have a new flapped section - something that could lead to a new version of the Ventus??? John Galloway |
Beauty is in the eye of the beholder... I still cannot get used to this wing planform. Form follows function, I would hope. |
I think it looks nice, here is hoping if handles as nice as a Duo (good for it's size) ... If I had one on order I'd definitely let my friends fly it. And I hope the person with one order I know thinks same way :-) Darryl |
On Dec 11, 12:00*pm, "noel.wade" wrote:
...I'm betting the change in wing-sweep on the outboard sections is to reduce twist loads and improve the behavior/control-authority at the stall - but that's just a guess from an amateur aerodynamics enthusiast. :-P There are many possible reasons for the tip treatment. One possible reason is aeroelastic as forward sweep can lead to unpleasant flutter characteristics due to a positive relationship between wing bending and AOA - though it doesn't seem to cover enough of the span to do much. Another possibility is to influence spanwise flow at the tip and reduce vortex losses. Thene there may be weight and balance and/or handling reasons as you mention. Or maybe they though it looked cool. 9B |
On 12 Dec, 17:31, wrote:
On Dec 11, 12:00*pm, "noel.wade" wrote: ...I'm betting the change in wing-sweep on the outboard sections is to reduce twist loads and improve the behavior/control-authority at the stall - but that's just a guess from an amateur aerodynamics enthusiast. :-P There are many possible reasons for the tip treatment. One possible reason is aeroelastic as forward sweep can lead to unpleasant flutter characteristics due to a positive relationship between wing bending and AOA - though it doesn't seem to cover enough of the span to do much. Another possibility is to influence spanwise flow at the tip and reduce vortex losses. Thene there may be weight and balance and/or handling reasons as you mention. *Or maybe they though it looked cool. 9B All SH gliders since the Discus have had swept back outer wing planforms - following Will Scheumann's deduction that it would reduce induced drag ( on his cut down ASW 12 wings). The heart-warming thing about that was that he worked this out logically, but non- mathematically, from consideration of the likely relative pressures at adjacent spanwise stations - and had the courage of his convictions to modify his glider accordingly to prove it. .... but for me the most important reason for having the sweep backs is that, from some viewpoints, a wing with a step change in dihedral gives the illusion of there being a aesthetically clumsy sweep-forward if there is not a sweep-back at that point. Walk round a DG 1000 to see this effect at the near-tip dihedral http://www.dg-flugzeugbau.de/Data/dg1000-6.jpg Once the designer has got the planform as close to ellipticaI as is practical there are extra induced drag gains to be made from going out of plane with progressive dihedral change. Add to that the Scheumann effect and the aesthetic desirability of sweep back and the modern SH wing emerges. John Galloway |
On Dec 12, 9:31*am, wrote:
There are many possible reasons for the tip treatment. One possible reason is aeroelastic as forward sweep can lead to unpleasant flutter characteristics due to a positive relationship between wing bending and AOA - though it doesn't seem to cover enough of the span to do much. Another possibility is to influence spanwise flow at the tip and reduce vortex losses. Thene there may be weight and balance and/or handling reasons as you mention. *Or maybe they though it looked cool. 9B While we're having fun with speculation: I've helped Brad and Bob a bit on a few of the HP/Glidiar bits; and Brad and I have gone through a few design processes on potential glider projects in the future (think something between an Apis and an LS-8, with provisions for non-2-stroke-motor self-launching systems)... Bottom-line: I'm an amateur, but I've studied a lot of the basic aerodynamics and design stuff out there, and have some hands-on experience with laying up composites molds and molded parts. I've looked at the manufacturing complexities involved in a multi- segement or "bent" main spar (with wings that have multiple taper- breaks and thus a different chordwise airfoil thick-points where the spar would tend to be placed), and it seems to me that you need to have a really good reason, before you start introducing all of those extra calculations and production hassles. Plus, at each bend in the spar you have the potential for stress-concentrations as the loads have to be taken a slightly different direction - and the lift forces being places on the spars at different angles to each other can induce torsional effects that you have to take into account... You could design your system with this in mind - for example to induce wing- twist at different speeds - but again you're increasing the complexity of the system, so there had better be a good pay-off! Obviously top- end racing machines are going to be trying to squeeze every last % of performance they can, but you still have to look at return-on- investment; and influencing spanwise-flow / wingtip vortices can be done more simply with airfoil selection, simpler taper-changes, and simple well-desiged winglets. And in regards to CG - couldn't you just take a couple of degress of sweep out of the whole wing to adjust that, rather than mess with the outboard wing panels and all of the issues mentioned above? Whatever the reason, its certainly an interesting development! Take care, --Noel |
On Fri, 12 Dec 2008 09:31:19 -0800, ablackburn6 wrote:
Or maybe they though it looked cool. The Duo and the Arcus 3-view both look very like a gannet in flight. I mean the sea bird, not the Fleet Air Arm turboprop toy. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
planforms - following Will Scheumann's deduction that it would reduce induced drag As this thread started with the Antares: Somewhere on their homepage, Lange claims that theoretically the best wing shape is a super-ellipsis. And that's what the Antares got. Incidentally, the Disci (single and duo) wings come pretty close. |
| Thread Tools | |
| Display Modes | |
| Parachutes & life expectancy | fredsez | Soaring | 16 | March 18th 08 08:46 PM |
| Advertisment Increased the range | Paul Buchanan | Soaring | 0 | July 28th 06 07:32 AM |
| battery life | Paul Feltz | Soaring | 9 | December 6th 04 01:19 AM |
| Generator Life Expectancy | Lockrdg | Owning | 5 | July 19th 04 04:59 AM |
| Battery life...how to test? | Jim Kelly | Soaring | 2 | July 11th 03 10:12 PM |
