Departure Question
Old January 10th 09, 05:00 PM posted to rec.aviation.ifr
Steven P. McNicoll[_2_]
Default Departure Question
VOR-DME wrote:
The previously cited phrase :
"...ODPs are recommended for obstruction clearance
and may be flown without ATC clearance unless an alternate departure
procedure (SID or radar vector) has been specifically assigned by
ATC. "
is not in my 2008 AIM.
Had it been, I would not have started this thread.
Are you referring to the Jeppesen FAR/AIM? It's in the 2006 edition,
paragraph 5-2-6 INSTRUMENT DEPARTURE PROCEDURES(DP)--OBSTACLE DEPARTURE
PROCEDURES(ODP) AND STANDARD INSTRUMENT DEPARTURES (SID), exactly as you
quote it above. The paragraph in the current AIM has the same title but is
now paragraph 5-2-8.
Old January 10th 09, 10:42 PM posted to rec.aviation.ifr
VOR-DME
I thank you, and the previous poster for these regulatory citations, which help
to clarify. I actually did check my AIM before initiating this thread, and did
not find any of this language indicating pilot's perogative to adhere to the
ODP. My AIM is 2008. Has this language appeared or disappeared recently?
I did see this in 5-2-8 :
"As a general rule, ATC will only assign an ODP from a non-towered airport when
compliance with the ODP is necessary for aircraft to aircraft separation.
Pilots may use the ODP to help ensure separation from terrain and obstacles."
It would appear this specific case does not follow the "general rule" as the
ODP published is clearly for terrain and accomplishes nothing for aircraft
separation, which it could actually exacerbate if an aircraft is initiating an
approach at the same fix.
I'm surprised they don't just assign a name or designator to this type of ODP,
the way they do with SID's, that you can just type into the form.
says...
VOR-DME wrote:
I'm departing a non-towered field IFR, let's stay East Coast, and say
Bennington (KDDH), departing eastbound. There is a published departure
proceedure, for obstacle (read mountain) clearance. Under Part 91, I
am not required to follow this proceedure, but due to mountain
obscuration I may wish to do so. What do I put in my flight plan, or
in my communication via the local GCO to indicate whether I intend to
return to the Cambridge VORTAC or not? Albany approach may have other
IFR traffic coming into Bennington, so they will want to know if I am
backtracking to CAM or not.
You should file what you intend to fly, DDH..CAM.V490... for example.
Here's a note from the paragraph on Departure Clearances in FAAA 7110.65:
"If a published IFR departure procedure is not included in an ATC clearance,
compliance with such a procedure is the pilot's prerogative."
However you're actually cleared you retain the option to fly the departure
procedure.
Old January 11th 09, 12:40 AM posted to rec.aviation.ifr
VOR-DME
In article , says...
VOR-DME wrote:
Thanks to all for previous helpful replies.
Here's a departure question. (Those who do not fly real airplanes under
IFR need not feel compelled to reply):
proceedure, for obstacle (read mountain) clearance. Under Part 91, I am
not required to follow this proceedure, but due to mountain obscuration I
may wish to do so. What do I put in my flight plan, or in my
communication via the local GCO to indicate whether I intend to return to
the Cambridge VORTAC or not? Albany approach may have other IFR traffic
coming into Bennington, so they will want to know if I am backtracking to
CAM or not.
Thanks in advance . . .
Put in the remarks that you will be flying the KDDH ODP and advise ATC
via the GCO prior to takeoff. Making sure you and ATC are on the same
page makes the system work the best.
Yep. Sounds right to me, after this discussion.
I would still plan to depart KDDH eastbound VFR to avoid wasting 15min in the
DP, if ceilings are 4000 or better (no mountain obscuration). With lower
ceilings (mountain obscuration) like you say makes sense. . .
Thanks to all.
Departure Procedure jStumper Question [email protected] Instrument Flight Rules 10 September 22nd 07 12:27 AM
departure or arrival? George Aviation Photos 6 April 15th 07 07:58 PM
Fedex Departure (MCO) Glen in Orlando Aviation Photos 0 November 29th 06 11:13 PM
Alternate same as departure? dlevy Instrument Flight Rules 34 December 11th 04 01:15 PM
