#11
On Sat, 10 Jan 2009 11:15:40 -0800 (PST), "
wrote: 356-T6 is usually selected for its HIGH STRENGTH rather than its ability to pass heat While I don't disagree with you, my ASME Metals Properties (1954) shows the 356 alloy to be well above average in thermal conductivity. What alloy is usually used in aluminum heads? George |
On Jan 12, 7:17*am, GeorgeB wrote:
What alloy is usually used in aluminum heads? -------------------------------------------------------------------------------- I don't know, George. My data is probably out of date. The Navy code is (or was) MM212a... which I was told is equal to A.S.T.M. B26-37T , cited as suitable for Aluminum Sand Castings (Cylinder Heads, Crankcases, Etc.) It has 4% copper and has about the same thermal conductivity of the other copper-bearing alloys ( ie, 0.0000125 ...meaning that's it's coefficient of expansion between 68 and 392*F ). Not very strong, though... 32kpsi (Tension) ------------------------------------------------------------------------------------------------------------- While I don't disagree with you, my ASME Metals Properties (1954) shows the 356 alloy to be well above average in thermal conductivity. ------------------------------------------------------------------------------------------------------------- It's okay to disagree with me, George :-) I'm just whipping most of these numbers out of my ass anyway. When I was the leading Chief at COMCRUDESPAC's computer shop we were just across the street from the Pattern-makers school at the 32st Naval Station, and me & the Chiefs over there were about the only Chiefs for some distance around, so we were always bumping into each other. I picked up a little bit of knowledge about casting & pattern making. Enough at least, to cast little do-dads. Our local junior high usta teach that; showing kids how to make ash trays and the like. All gone now, of course. Too dangerous or something. But it doesn't really matter. Because I'll be using old pistons any way :-) It's not a question of strength, money nor physical properties, but more a question of time & convenience. With about a thousand people 'subscribed' to this group, and everyone TALKING about the subject, odds are I'll be the only one to actually DO anything about it :-) Pretty exclusive club, Doing Things. My muller (the thing that you use to mix the oil or what-have-you with the sand) is one of those humongous mixers you drive with a 1/2" drill motor (usually used to mix mortor). I use #100 sand from Dixieline Lumber in Escondido... costs about two bucks a bag (or did). I've got several flasks around the place, plus a small furnace that uses a weed- eater flame nozzle. My 'furnace' is a big bucket lined with fire- clay. Steel pot for the melting. Dipped in a slurry of refractory material, allowed to dry then 'cooked' in the furnance until it's cheery red and allowed to cool. The aluminum gets heated then chunked up with a BIG iron bar. Anything left over goes into a couple of steel molds. The tricky bit is making the patterns. I think I've got it figured out but I haven't tried making the core boxes as yet. To make cores I use some molasses and paste-flour, plus a bit of water. #100 sand. Pack it good & tight then dismantle the core-box and hope it don't crack. Put them in the over to cook overnight @ 250 degrees. Next morning (or eight hours later) you've got a light -- hopefully porous -- core that will fit the holes in your pattern. High tech it ain't :-) -Bob |
![]() "Stealth Pilot" wrote in message ... On Sat, 10 Jan 2009 14:11:47 -0600, "Maxwell" #$$9#@%%%.^^^ wrote: -------------------------------------------------------------------------- What do you use for sand and binder? How do you mix? you can make your own greensand. basically you get some buckets of sand. plonk a gently running hose into the bucket and let it float off everything but the sand. keep the hose running until the water coming off is clear. this gets rid of crap and non bentonite clays. find or buy some bentonite clay. you can buy sodium modified bentonite in 25lb bags. you need bentonite clay because of its peculiar charactersitics. it is different from all the other clays and the difference is what makes it useful in casting. ok let your washed sand dry off a bit. weigh the sand and mix in 5% thereabouts by weight of bentonite. this is the important bit; you need to put a coating of bentonite around each sand particle. you dig your clean hands into the sand and bentonite and with a handfull between your hands you run them back and forth to work a coating of clay around each sand particle. (your hands end up really smooth from this) ok now you let your mix dry right out. this can take a week. when you want to use the greensand you mix in 5% of water by weight and nead the greensand so that it is uniformly wet out. if you pat up a sausage out of it about 2" dia and a foot long you should be able to hold this by an end and wave it all over the place and none of the sand will part company. you then need to do some test pours to see if the porosity of your greensand means it is too coarse. if you can handle that intelligently I'll go on to tell you why most people get their furnaces wrong and what you need to do to get it right. Stealth Pilot What's the point? If you are going to buy bentonite, why not buy a quality molding sand like silica or olivine as well? At any rate, good luck on your green strength test. Even the finest seasoned and mix green sand will in no way meet the expectation of your 2" x 12" sample as stated. |
![]() wrote in message ... On Jan 12, 7:17 am, GeorgeB wrote: What alloy is usually used in aluminum heads? -------------------------------------------------------------------------------- I don't know, George. My data is probably out of date. The Navy code is (or was) MM212a... which I was told is equal to A.S.T.M. B26-37T , cited as suitable for Aluminum Sand Castings (Cylinder Heads, Crankcases, Etc.) It has 4% copper and has about the same thermal conductivity of the other copper-bearing alloys ( ie, 0.0000125 ...meaning that's it's coefficient of expansion between 68 and 392*F ). Not very strong, though... 32kpsi (Tension) ------------------------------------------------------------------------------------------------------------- While I don't disagree with you, my ASME Metals Properties (1954) shows the 356 alloy to be well above average in thermal conductivity. ------------------------------------------------------------------------------------------------------------- It's okay to disagree with me, George :-) I'm just whipping most of these numbers out of my ass anyway. When I was the leading Chief at COMCRUDESPAC's computer shop we were just across the street from the Pattern-makers school at the 32st Naval Station, and me & the Chiefs over there were about the only Chiefs for some distance around, so we were always bumping into each other. I picked up a little bit of knowledge about casting & pattern making. Enough at least, to cast little do-dads. Our local junior high usta teach that; showing kids how to make ash trays and the like. All gone now, of course. Too dangerous or something. But it doesn't really matter. Because I'll be using old pistons any way :-) It's not a question of strength, money nor physical properties, but more a question of time & convenience. With about a thousand people 'subscribed' to this group, and everyone TALKING about the subject, odds are I'll be the only one to actually DO anything about it :-) Pretty exclusive club, Doing Things. My muller (the thing that you use to mix the oil or what-have-you with the sand) is one of those humongous mixers you drive with a 1/2" drill motor (usually used to mix mortor). I use #100 sand from Dixieline Lumber in Escondido... costs about two bucks a bag (or did). I've got several flasks around the place, plus a small furnace that uses a weed- eater flame nozzle. My 'furnace' is a big bucket lined with fire- clay. Steel pot for the melting. Dipped in a slurry of refractory material, allowed to dry then 'cooked' in the furnance until it's cheery red and allowed to cool. The aluminum gets heated then chunked up with a BIG iron bar. Anything left over goes into a couple of steel molds. The tricky bit is making the patterns. I think I've got it figured out but I haven't tried making the core boxes as yet. To make cores I use some molasses and paste-flour, plus a bit of water. #100 sand. Pack it good & tight then dismantle the core-box and hope it don't crack. Put them in the over to cook overnight @ 250 degrees. Next morning (or eight hours later) you've got a light -- hopefully porous -- core that will fit the holes in your pattern. High tech it ain't :-) -Bob ----------------------------------------------------------------------------------------------------- First, I would recommend you double check your source on sand. Most building supply folks sell "river" sand. If you examine it closely, you will find it is made up of round granules that look simply like pea gravel. Silica sand, the white sand used for years in public ash trays and some blasting operations is much more suitable, and well worth the addtional cost. Olivine is also very popular for green sand molding, although it cost a good bit more. The shape of these sands are much more irregular, and thus will form much stronger molds regardless of which binder you choose. http://en.wikipedia.org/wiki/Olivine I'm not familiur with your binder recipe, but might want to try a sodium silicate based solution to simplify your process. You can mix a one part liquid with your sand, ram up your core boxes, and simply gas them with CO2 gas to set them in less than 60 seconds. There are also catalists available that will cure them in 10 minutes or so, if you have a mixing process that allows you to mix the sand and get it in the mold that quickly. I have friends in the business and could probably get you a gallon sample freebe if you would like to try it. I'm told it's about $75 for 5 gallons if you get addicted to it, but it only takes about 2% if you have a good mixing process. As for the metal and the melt process, to each his own. But I can say from experience you stand a good chance of having porosity problems with the method you discribe, and there are cheaper ways to do things. Having the ability to fabricate the patterns are the real challange here, and I have no doubt you can do that. Once they are complete, a small shop could probably cast you some heads for less than your time and supplies are worth. There is also the possibility of molding this in plaster, but that's another story. |
On Jan 12, 8:38*pm, "Maxwell" #$$9#@%%%.^^^ wrote:
----------------------------------------------------------------------------------------------------- First, I would recommend you double check your source on sand. ------------------------------------------------------------ BT, DT (big Smiley) This is good quality 100% silica. They don't even store it in the same shed, to prevent errors (They'll load stuff for you.). I've got a couple of bags of #80 but I've found it's a bit too coarse. (But works fine in the blast cabinet.) ------------------------------------------------------------ I'm not familiur with your binder recipe, ----------------------------------------------------------- I may not be either :-) I think I used 'Karo Syrup' the last time I made cores but I had a rather unfortunate accident with the materials. We have cats and... perhaps that's enough said :-) ---------------------------------------------------------- but might want to try a sodium silicate based solution to simplify your process. You can mix a one part ---------------------------------------------------------- I've seen this used to make some brass castings, literally while the 'customer' was waiting (circa 1975) I've always wanted to try it but applying the gas makes it appear rather complicated. Of course, guys who HAVE used it tend to make it sound like mother's milk, whereas guys who have TRIED to use it make it sound like WWIII. I assume it's somewhere in the middle :-) --------------------------------------------------------- . I'm told it's about $75 for 5 gallons --------------------------------------------------------- Then it's beyond my means. (The cancer has attacked my pocket-book with even more success than my spine :-) And besides, I still have the patterns to finish and prove. The last time I worked with fins I had a HELL of a time before I got the patten to 'rap' free. Indeed, it made cores simple by comparison. I will also have to develop the procedure for afixing the valve seats, hopefully like Stephen.... what's-his-name... the fellow who did so well racing the Type IV's. His foreman let me try my hand swaging the seats into a modified Type IV head and that puppy was HOT -- it came right out of the oven. (Do it COLD -- which was VW's recommended procedure -- and you'd end up with a loose seat for sure.) Plus the racer's seats were something like 5/8" deep; VW's appeared to be less than 1/2". So there's a bit of tooling needed on the production side, assuming I can get the thing to give me some fins. ....but you've got me thinking about using the CO2 method for the outer mold as well. Give me another hundred years... or even ONE :-) -------------------------------------------------------------------------- There is also the possibility of molding this in plaster, but that's another story. --------------------------------------------------------------------------- I think I mentioned the dentist. He was casting some exotic STEEL alloys for bridge-work using the lost-wax process. Had a little centrifuge, tiny ceramic crucibles -- the whole nine yards but in miniature. He let us use his oven to heat-treat the hinges for the Varieze. But only once :-) When I tipped the tray of hinges into the ice water it drove everyone out of the lab. I guess he'd never seen it done before. -Bob |
On Mon, 12 Jan 2009 22:04:43 -0600, "Maxwell" #$$9#@%%%.^^^ wrote:
"Stealth Pilot" wrote in message .. . On Sat, 10 Jan 2009 14:11:47 -0600, "Maxwell" #$$9#@%%%.^^^ wrote: -------------------------------------------------------------------------- What do you use for sand and binder? How do you mix? you can make your own greensand. basically you get some buckets of sand. plonk a gently running hose into the bucket and let it float off everything but the sand. keep the hose running until the water coming off is clear. this gets rid of crap and non bentonite clays. find or buy some bentonite clay. you can buy sodium modified bentonite in 25lb bags. you need bentonite clay because of its peculiar charactersitics. it is different from all the other clays and the difference is what makes it useful in casting. ok let your washed sand dry off a bit. weigh the sand and mix in 5% thereabouts by weight of bentonite. this is the important bit; you need to put a coating of bentonite around each sand particle. you dig your clean hands into the sand and bentonite and with a handfull between your hands you run them back and forth to work a coating of clay around each sand particle. (your hands end up really smooth from this) ok now you let your mix dry right out. this can take a week. when you want to use the greensand you mix in 5% of water by weight and nead the greensand so that it is uniformly wet out. if you pat up a sausage out of it about 2" dia and a foot long you should be able to hold this by an end and wave it all over the place and none of the sand will part company. you then need to do some test pours to see if the porosity of your greensand means it is too coarse. if you can handle that intelligently I'll go on to tell you why most people get their furnaces wrong and what you need to do to get it right. Stealth Pilot What's the point? If you are going to buy bentonite, why not buy a quality molding sand like silica or olivine as well? At any rate, good luck on your green strength test. Even the finest seasoned and mix green sand will in no way meet the expectation of your 2" x 12" sample as stated. rubbish. I *actually* do castings. the shake test is one I can demonstrate in 5 minutes with two handfulls of greensand from the black bin in my workshop. I'm writing from first hand experience. can I suggest you get off your arse and *do* something in life. your pleasure would increase immeasurably. Stealth Pilot |
On Mon, 12 Jan 2009 22:38:54 -0600, "Maxwell" #$$9#@%%%.^^^ wrote:
There is also the possibility of molding this in plaster, but that's another story. unless you've tried it you would have no idea how dangerous that suggestion actually is. firstly the strength of plaster vanishes to nothing beyond a certain temperature. that temperature is just 5 degrees celcius above the melting point of aloominum. I have tried the technique to cast a mills 0.75cc diesel crankcase. this is a tiny thing about an inch and half by an inch and a half in overall dimensions. relatively tiny and easy to work with. it was done lost wax. a day after the plaster was set the mold went into the oven to melt out the wax. it was then cooked up to about 180 degrees farenheit for a while (2 hours afaik) to evaporate off the moisture. it stayed in the oven overnight (I've never been allowed to use the oven again) it was then given 15 minutes in the microwave to really dry it out. it was wrapped in a cloth and raced out to the workshop hot. it looked alabaster white and as dry as a piece of chalk. when the aluminium was poured into the mold a guyser of molten aluminium ejected to the ceiling of the workshop. this seemed to continue for some time. an examination of the mould later showed it to be totally empty. I dont know how dry you need to get it but I gave it a fair go at getting a bone dry mould. I have to ask you what your experience is in casting. have you ever done any of this yourself or is it something you've watched? Stealth Pilot |
![]() "Stealth Pilot" wrote in message ... On Mon, 12 Jan 2009 22:04:43 -0600, "Maxwell" #$$9#@%%%.^^^ wrote: "Stealth Pilot" wrote in message . .. On Sat, 10 Jan 2009 14:11:47 -0600, "Maxwell" #$$9#@%%%.^^^ wrote: -------------------------------------------------------------------------- What do you use for sand and binder? How do you mix? you can make your own greensand. basically you get some buckets of sand. plonk a gently running hose into the bucket and let it float off everything but the sand. keep the hose running until the water coming off is clear. this gets rid of crap and non bentonite clays. find or buy some bentonite clay. you can buy sodium modified bentonite in 25lb bags. you need bentonite clay because of its peculiar charactersitics. it is different from all the other clays and the difference is what makes it useful in casting. ok let your washed sand dry off a bit. weigh the sand and mix in 5% thereabouts by weight of bentonite. this is the important bit; you need to put a coating of bentonite around each sand particle. you dig your clean hands into the sand and bentonite and with a handfull between your hands you run them back and forth to work a coating of clay around each sand particle. (your hands end up really smooth from this) ok now you let your mix dry right out. this can take a week. when you want to use the greensand you mix in 5% of water by weight and nead the greensand so that it is uniformly wet out. if you pat up a sausage out of it about 2" dia and a foot long you should be able to hold this by an end and wave it all over the place and none of the sand will part company. you then need to do some test pours to see if the porosity of your greensand means it is too coarse. if you can handle that intelligently I'll go on to tell you why most people get their furnaces wrong and what you need to do to get it right. Stealth Pilot What's the point? If you are going to buy bentonite, why not buy a quality molding sand like silica or olivine as well? At any rate, good luck on your green strength test. Even the finest seasoned and mix green sand will in no way meet the expectation of your 2" x 12" sample as stated. rubbish. I *actually* do castings. the shake test is one I can demonstrate in 5 minutes with two handfulls of greensand from the black bin in my workshop. I'm writing from first hand experience. can I suggest you get off your arse and *do* something in life. your pleasure would increase immeasurably. Stealth Pilot Then whip one up in 5 minutes, and send us the pic. |
![]() "Stealth Pilot" wrote in message ... On Mon, 12 Jan 2009 22:38:54 -0600, "Maxwell" #$$9#@%%%.^^^ wrote: There is also the possibility of molding this in plaster, but that's another story. unless you've tried it you would have no idea how dangerous that suggestion actually is. firstly the strength of plaster vanishes to nothing beyond a certain temperature. that temperature is just 5 degrees celcius above the melting point of aloominum. I have tried the technique to cast a mills 0.75cc diesel crankcase. this is a tiny thing about an inch and half by an inch and a half in overall dimensions. relatively tiny and easy to work with. it was done lost wax. a day after the plaster was set the mold went into the oven to melt out the wax. it was then cooked up to about 180 degrees farenheit for a while (2 hours afaik) to evaporate off the moisture. it stayed in the oven overnight (I've never been allowed to use the oven again) it was then given 15 minutes in the microwave to really dry it out. it was wrapped in a cloth and raced out to the workshop hot. it looked alabaster white and as dry as a piece of chalk. when the aluminium was poured into the mold a guyser of molten aluminium ejected to the ceiling of the workshop. this seemed to continue for some time. an examination of the mould later showed it to be totally empty. I dont know how dry you need to get it but I gave it a fair go at getting a bone dry mould. I have to ask you what your experience is in casting. have you ever done any of this yourself or is it something you've watched? Stealth Pilot Both. http://www.gp.com/build/product.aspx?pid=1569 |
On Jan 13, 1:00*am, Stealth Pilot
wrote: On Mon, 12 Jan 2009 22:38:54 -0600, "Maxwell" #$$9#@%%%.^^^ wrote: when the aluminium was poured into the mold a guyser of molten aluminium ejected to the ceiling of the workshop. *this seemed to continue for some time. an examination of the mould later showed it to be totally empty. I dont know how dry you need to get it but I gave it a fair go at getting a bone dry mould. Stealth Pilot Your experience pretty much matches mine. I was able to get dry enough plaster to make castings without porosity, but it took WAY to long to dry to that point. My first pour too resulted in a steam geyser and I would have sworn I baked that thing long enough. I was also having fill problems. One plaster cast per go made the experimentation too time consuming. I gave up and went back to sand. I was trying to make fined valve covers for my1/2VW and was having trouble getting molds in sand to stay together while puling the pattern. At that time I didn't have a muller and could not get oil based sand to work at all - thus the try at plaster. I finally managed to modify my sand formula and got satisfactory results. A touch of sugar did the trick. The fins on the valve covers were enough of a challenge that I won't be trying to do any head casting in sand, oil or bentonite based. IMHO buying/building a muller is worth the time and trouble as the oil based sand is good stuff. The humidity in my part of the world is such that an uncovered covered heap of sand will dry out too much in a matter of hours. Oil doesn't and for that reason alone I made the switch. Just in case you don't have the formula, even though I'm sure you do........................... http://www.foundry.ray-vin.com/k-bond/k-bond.htm http://users.hal-pc.org/~lwhill/sandsystems.html ======================= Leon McAtee |
Need help with a rocket motor ID unk-rocket- | Dave Kearton | Aviation Photos | 0 | February 2nd 07 08:09 AM |
Traffic Heads-up | [email protected] | Products | 1 | July 7th 05 04:50 PM |
1966 Cessna 172 Control Yokes --- What Alloy? | jls | Home Built | 0 | November 4th 04 05:02 PM |
TWO EXTREMELY RARE ROCKET BOOKS ON EBAY - INCREDIBLE ROCKET HISTORY! | TruthReigns | Military Aviation | 0 | July 10th 04 11:54 AM |
SCAM - Heads up | DaveSpringford | Soaring | 0 | December 4th 03 11:13 PM |
