#11
![]() Bruce wrote: Darryl I do not know the Cambridge 302 - but on the LX loggers you can add a long list of optional data to the B record. It does consume memory, but that is no problem with the LX toys... No idea where / how / if you even can set this on a 302 - but it is certainly worth exploring. No way to put this info in the 302 record. |
On Jan 10, 11:20*pm, Bruce wrote:
Darryl Ramm wrote: On Jan 10, 8:34 pm, Papa3 wrote: On Jan 10, 5:21 pm, Hal wrote: I downloaded a flight yesterday from the Cambridge 302. *When displaying with SeeYou there was no wind data. *The wind data was there on a previous flight. *I assume the problem is with the 302 log. *Anyone seen this problem before? Hal, Others have answered, but just thought I'd clarify. *I'm assuming the SeeYou you're talking about above is the desktop version and you were using it for post-flight analysis (since you say "I downloaded", seems pretty clear but just checking). Anyway, if you look at the specs for the IGC log file, you'll see that the only position data stored is location and time. * None of the calculated data (such as wind) is stored. *Thus, whatever SeeYou displays is based in post-flight calculation using only on position and time data. * As others have pointed out, unless you have some amount of drift in circling flight, it's impossible for a post-flight analysis using only this position data to determine wind. P3 Sory, this may be a common misconception, but it is not correct. IGC files B records can contain more than position and time, including ENL (engine noise) and the magic TAS data used for enhanced wind calculations. And See You will use that to enhance wind calculations just as SeeYou Mobile and WinPilog Pro uses. If your sample rate is fast enough (1 sec?) you should get a fairly accurate replay of the wind you PDA/computer told you existed during the flight. But yes it a recalculation, nothing is writing pre-computed wind data to the IGC file. Darryl I do not know the Cambridge 302 - but on the LX loggers you can add a long list of optional data to the B record. It does consume memory, but that is no problem with the LX toys... No idea where / how / if you even can set this on a 302 - but it is certainly worth exploring. Unfortunately you can't configure the data in the 302 IGC file B records, at least not as far as I know. If it is doable it is very well hidden. The thing to do is record a second IGC file through WinPilot or SeeYou Mobile or other software that supports logging the TAS data. The table of IGC file data options that vendors can support goes on for several pages in the IGC GNSS flight recorder spec. TAS is just one of them. Darryl |
On Jan 10, 11:41*pm, Darryl Ramm wrote:
On Jan 10, 8:34*pm, Papa3 wrote: On Jan 10, 5:21*pm, Hal wrote: I downloaded a flight yesterday from the Cambridge 302. *When displaying with SeeYou there was no wind data. *The wind data was there on a previous flight. *I assume the problem is with the 302 log. *Anyone seen this problem before? Hal, Others have answered, but just thought I'd clarify. *I'm assuming the SeeYou you're talking about above is the desktop version and you were using it for post-flight analysis (since you say "I downloaded", seems pretty clear but just checking). Anyway, if you look at the specs for the IGC log file, you'll see that the only position data stored is location and time. * None of the calculated data (such as wind) is stored. *Thus, whatever SeeYou displays is based in post-flight calculation using only on position and time data. * As others have pointed out, unless you have some amount of drift in circling flight, it's impossible for a post-flight analysis using only this position data to determine wind. P3 Sory, this may be a common misconception, but it is not correct. IGC files B records can contain more than position and time, including ENL (engine noise) and the magic TAS data used for enhanced wind calculations. And See You will use that to enhance wind calculations just as SeeYou Mobile and WinPilog Pro uses. If your sample rate is fast enough (1 sec?) you should get a fairly accurate replay of the wind you PDA/computer told you existed during the flight. But yes it a recalculation, nothing is writing pre-computed wind data to the IGC file. Darryl- Hide quoted text - - Show quoted text - Well, I guess that explains all those I and J records I'd been ignoring all these years... :-) Apologies for the mis-information. It seems like I've only ever received for evaluation IGC files with the mandatory B record information (aka basic data) for the last umpteen years. I had assumed that these optional fields weren't implemented, but I stand corrected. Humbly, P3 |
Seeyou NMEA to Winpilot/Seeyou | Jean | Soaring | 4 | June 3rd 06 11:38 AM |
U.S. Cloud Images for flight display | [email protected] | Soaring | 0 | January 21st 06 07:37 PM |
OLC 2006 flight uploads with SeeYou | Ted Wagner | Soaring | 2 | October 15th 05 05:31 AM |
Dynamic Contest Flight Display | Bob | Soaring | 0 | August 8th 05 01:38 PM |
OQO Handtop computer for flight display. | Guy Byars | Owning | 2 | June 28th 05 03:09 PM |
