G'Day all.
Just a quick query for all, both in the US and Australia. If I was to take a proven aircraft, say a C172, totally dismantle it, including EVERY rivet and bolt, replace anything corroded (ie:sheetmetal etc) and any hardware/bolts/cables, and rebuildcorrosionproof it, put in a certified or auto engine, Photograph the entire process to prove you didn't cheat, could it be certified as an experimental? My intertepretation for Australia is that is allowable, and as it is a proven aircraft, you have all the numbers to prove specs from the original manufacturer. The only thing that would prevent a simple sign-off after hour would be if you used an auto engine, and I know there are some successful Cessnas out there with auto conversions in other countries. If you fill in the paperwork to prove % as per CASA regs you'd be in without a problem. For the airframe you can obtain many engine-free fuselages in the states and basically have a zero-hour remanufactured aircraft for a small % of the cost of what Cessna/Beechcraft/Piper are charging. Any thoughts/opinions/evidence/flaming (please minimise this bit). References would be appreciated. Thanks in advance. Rob. Melbourne Australia. |
Fonz wrote:
G'Day all. Just a quick query for all, both in the US and Australia. If I was to take a proven aircraft, say a C172, totally dismantle it, including EVERY rivet and bolt, replace anything corroded (ie:sheetmetal etc) and any hardware/bolts/cables, and rebuildcorrosionproof it, put in a certified or auto engine, Photograph the entire process to prove you didn't cheat, could it be certified as an experimental? My intertepretation for Australia is that is allowable, and as it is a proven aircraft, you have all the numbers to prove specs from the original manufacturer. The only thing that would prevent a simple sign-off after hour would be if you used an auto engine, and I know there are some successful Cessnas out there with auto conversions in other countries. If you fill in the paperwork to prove % as per CASA regs you'd be in without a problem. For the airframe you can obtain many engine-free fuselages in the states and basically have a zero-hour remanufactured aircraft for a small % of the cost of what Cessna/Beechcraft/Piper are charging. Any thoughts/opinions/evidence/flaming (please minimise this bit). References would be appreciated. Thanks in advance. Rob. Melbourne Australia. Perhaps you are refering to the Blanton conversion? Can't answer for the FAA on that one, but I can guarantee that in the US an STC for the engine change would be a lot easier and cheaper! |
On Fri, 23 Jan 2009 21:44:04 +1100, "Fonz" wrote:
G'Day all. Just a quick query for all, both in the US and Australia. If I was to take a proven aircraft, say a C172, totally dismantle it, including EVERY rivet and bolt, replace anything corroded (ie:sheetmetal etc) and any hardware/bolts/cables, and rebuildcorrosionproof it, put in a certified or auto engine, Photograph the entire process to prove you didn't cheat, could it be certified as an experimental? My intertepretation for Australia is that is allowable, and as it is a proven aircraft, you have all the numbers to prove specs from the original manufacturer. The only thing that would prevent a simple sign-off after hour would be if you used an auto engine, and I know there are some successful Cessnas out there with auto conversions in other countries. If you fill in the paperwork to prove % as per CASA regs you'd be in without a problem. For the airframe you can obtain many engine-free fuselages in the states and basically have a zero-hour remanufactured aircraft for a small % of the cost of what Cessna/Beechcraft/Piper are charging. Any thoughts/opinions/evidence/flaming (please minimise this bit). References would be appreciated. Thanks in advance. Rob. Melbourne Australia. WAS legal in Canada - no longer. You could MAKE all the parts to DUPLICATE the original, but you cannot rebuild the original. |
On Jan 23, 5:21*am, wrote:
On Fri, 23 Jan 2009 21:44:04 +1100, "Fonz" wrote: G'Day all. Just a quick query for all, both in the US and Australia. If I was to take a proven aircraft, say a C172, totally dismantle it, including EVERY rivet and bolt, replace anything corroded (ie:sheetmetal etc) and any hardware/bolts/cables, and rebuildcorrosionproof it, put in a certified or auto engine, Photograph the entire process to prove you didn't cheat, could it be certified as an experimental? My intertepretation for Australia is that is allowable, and as it is a proven aircraft, you have all the numbers to prove specs from the original manufacturer. *The only thing that would prevent a simple sign-off after hour would be if you used an auto engine, and I know there are some successful Cessnas out there with auto conversions in other countries. *If you fill in the paperwork to prove % as per CASA regs you'd be in without a problem. For the airframe you can obtain many engine-free fuselages in the states and basically have a zero-hour remanufactured aircraft for a small % of the cost of what Cessna/Beechcraft/Piper are charging. Any thoughts/opinions/evidence/flaming (please minimise this bit). References would be appreciated. Thanks in advance. Rob. Melbourne Australia. WAS legal in Canada - no longer. You could MAKE all the parts to DUPLICATE the original, but you cannot rebuild the original. With that much work REassembling an airframe and engine, why not have an A&P follow and document your work and hours and get YOUR own A&P ........ Reggie |
On Jan 23, 10:40 am, wrote:
With that much work REassembling an airframe and engine, why not have an A&P follow and document your work and hours and get YOUR own A&P ........ Reggie Not that easy in Australia. The US probably has one of the easiest-to-get licenses; the Australian system, like our Canadian, is based on the British system. Our Canadian requirements include an 1800- hour formal course of study (some of which can be applied to the apprenticeship time, the course is an approved course), 70% of the applicable ATA tasks performed, an apprenticeship that will run anywhere from two to four years, depending on the level of the formal training course take, and four exams (airframe, engine, general and regulations). The whole thing will take four years at least, no matter what. Australia will be similar. Mine took me six years. The result is an Aircraft Maintenance Engineer's license, with the inspection privileges of the A&P-IA. And the stickler: a homebuilt project doesn't count. A homebuilt is an airplane when it comes to registering it, getting a C of A, flying it and insuring it, but not if you want it to count for apprenticeship time. Strange. Dan |
![]() wrote in message ... On Jan 23, 10:40 am, wrote: With that much work REassembling an airframe and engine, why not have an A&P follow and document your work and hours and get YOUR own A&P ........ Reggie Not that easy in Australia. The US probably has one of the easiest-to-get licenses; the Australian system, like our Canadian, is based on the British system. Our Canadian requirements include an 1800- hour formal course of study (some of which can be applied to the apprenticeship time, the course is an approved course), 70% of the applicable ATA tasks performed, an apprenticeship that will run anywhere from two to four years, depending on the level of the formal training course take, and four exams (airframe, engine, general and regulations). The whole thing will take four years at least, no matter what. Australia will be similar. Mine took me six years. The result is an Aircraft Maintenance Engineer's license, with the inspection privileges of the A&P-IA. And the stickler: a homebuilt project doesn't count. A homebuilt is an airplane when it comes to registering it, getting a C of A, flying it and insuring it, but not if you want it to count for apprenticeship time. Strange. Dan A friend bought an amateur built helicopter that was complete with the exception of the builders tag and airworthiness. He disassembled it to the point beyond a quick build kit, re-painted it and checked off the 51% form and he did more than 51%. FAA found that he had used an airframe that had been previously used and had some flight time on it and refused to license it as experimental homebuilt and insisted on making it exhibition only. There is a wide variation on what is accepted by the various FAA and DARs when issuing airworthiness certs. Stu |
I find that amazing.
If you totally disassembled the aircraft, cleaned all parts/fittings etc back to bare aluminium, recoated with zinc-chromate or whatever, photographed it as evidence, it is basically a kit. It wouldn't even be a quickbuild, and would come in at over 75% or higher. I can't see how anyone could challenge it, as the aircraft is constructed by the builder from parts, for his own education or enjoyment, to a proven design. Even in Australia, CASA seem to have a mind of their own, making their own rules, and not being challenged. I believe things are generally OK so far as the SAAA basically monitor everything. As part of my previous occupation I was involved in the legal system (I'm not a defence lawyer by the way, but rather the other side of the fence), and I believe it would be a very short hearing in the lower court, but winning that battle doesn't mean you'll win the war. I think I'm starting to answer my own original question here. Is there anyone from the SAAA technical side of the fence that would like to share an opinion? Any annon reply would also be taken in good faith. Thanks in advance, Rob. Melbourne Australia. ---------------------- "Stuart Fields" wrote in message ... wrote in message ... On Jan 23, 10:40 am, wrote: With that much work REassembling an airframe and engine, why not have an A&P follow and document your work and hours and get YOUR own A&P ........ Reggie Not that easy in Australia. The US probably has one of the easiest-to-get licenses; the Australian system, like our Canadian, is based on the British system. Our Canadian requirements include an 1800- hour formal course of study (some of which can be applied to the apprenticeship time, the course is an approved course), 70% of the applicable ATA tasks performed, an apprenticeship that will run anywhere from two to four years, depending on the level of the formal training course take, and four exams (airframe, engine, general and regulations). The whole thing will take four years at least, no matter what. Australia will be similar. Mine took me six years. The result is an Aircraft Maintenance Engineer's license, with the inspection privileges of the A&P-IA. And the stickler: a homebuilt project doesn't count. A homebuilt is an airplane when it comes to registering it, getting a C of A, flying it and insuring it, but not if you want it to count for apprenticeship time. Strange. Dan A friend bought an amateur built helicopter that was complete with the exception of the builders tag and airworthiness. He disassembled it to the point beyond a quick build kit, re-painted it and checked off the 51% form and he did more than 51%. FAA found that he had used an airframe that had been previously used and had some flight time on it and refused to license it as experimental homebuilt and insisted on making it exhibition only. There is a wide variation on what is accepted by the various FAA and DARs when issuing airworthiness certs. Stu |
G'Day all. Just a quick query for all, both in the US and Australia. If I was to take a proven aircraft, say a C172, totally dismantle it, including EVERY rivet and bolt, replace anything corroded (ie:sheetmetal etc) and any hardware/bolts/cables, and rebuildcorrosionproof it, put in a certified or auto engine, Photograph the entire process to prove you didn't cheat, could it be certified as an experimental? My intertepretation for Australia is that is allowable, and as it is a proven aircraft, you have all the numbers to prove specs from the original manufacturer. The only thing that would prevent a simple sign-off after hour would be if you used an auto engine, and I know there are some successful Cessnas out there with auto conversions in other countries. If you fill in the paperwork to prove % as per CASA regs you'd be in without a problem. For the airframe you can obtain many engine-free fuselages in the states and basically have a zero-hour remanufactured aircraft for a small % of the cost of what Cessna/Beechcraft/Piper are charging. Any thoughts/opinions/evidence/flaming (please minimise this bit). References would be appreciated. Thanks in advance. Rob. Melbourne Australia. Fonzie dont torture yourself. In CASA you are dealing with the most assinine form of government ever created. a certified aeroplane remains a certified aeroplane in their eyes. CASA are not logical or sensible when it comes to the regulations. ....in my experience they have developed the regulatory environment into some sort of religion devoid of any sense, with the overriding factor being avoidance of liability. CASA wont even introduce the canadian system of private owner maintenance into australia, despite it being introduced in canada on an objective safety case. if you want safe and proven build an RV under experimental. (it will be as competent as your building of it) as the builder you will be free to maintain it. if you want something cheaper follow the old CASA test pilot's example and build an Rans S7. (an S6 courier would be my choice) if you want sense then follow the other 8,000 pilots and join the RAA and then buy/build one of the better ultralights. by my accounting 8,000 of Australia's 12,700 or so pilots have joined the RAA to get free of the wank act that CASA subjects the rest of us private owners to. I know of one cessna that was totally dismantled to bits by the amateur owner, corrosion removed and then fully reassembled. all amateur work. it remained certified with just a LAME annual signoff to get it back in the air. so part of what you outlined is possible. as a caveat I no longer have anything to do with the SAAA. their failure to support or go for private owner maintenance must rank as one of the failures of the century. as a result I doubt their membership is any more than 3 digits compared to the RAA. just remember in all your dreamings about cobbling together bits to make a hybrid aircraft that underpinning aviation are some hard physical realities that operate irrespective of your understanding of them. get it wrong and they can kill you real quick. (most of the fun is knowing that you're getting it right.) Stealth Pilot |
World's First Certified Electrically Propelled Aircraft? | Larry Dighera | Piloting | 2 | September 22nd 06 01:50 AM |
Web Seminar: The FAA Has Certified the Adam Aircraft A500 | Valerie L Magee | Piloting | 0 | June 1st 05 03:36 PM |
Web Seminar: The FAA Has Certified the Adam Aircraft A500 | Valerie L Magee | General Aviation | 0 | June 1st 05 03:36 PM |
Web Seminar: The FAA Has Certified the Adam Aircraft A500 | Valerie L Magee | Owning | 0 | June 1st 05 03:36 PM |
Accident Statistics: Certified vs. Non-Certified Engines | Ron Wanttaja | Home Built | 23 | January 18th 04 05:36 PM |
