Dutch rolls
Old May 16th 04, 03:46 AM
Peter Stickney
"John Carrier" writes:
Dutch roll is an unavoidable dynamic response, not a desirable
maneuver. It's no more useful than the phugoid. And no more
intentional.
You've never seen Dutch roll til you've seen it at high Mach. Quite
disconcerting @ 1.75 (at this speed, we're supposed to be going straight,
eh?).
On the subject of instability, what was the aerodynamic cause of the X-2's
departure and crash? Adverse yaw + minimal directional stability?
That, and a bit of Roll Coupling, as well.
Pete Stickney
A strong conviction that something must be done is the parent of many
bad measures. -- Daniel Webster
Old May 16th 04, 07:37 AM
Ian MacLure
Mary Shafer wrote in
On Fri, 14 May 2004 17:21:39 +0100, "Jim Doyle"
I've been thinking about this, and although I'm far from being an
authority on air combat, I can't see dutch rolls being a beneficial
combat manoeuvre in the slightest. Even though the aircraft is
oscillating in yaw and pitch the track heading remains the same, so
surely it's straight forward to get shots on target?
intentional.
Specifically its a coupled roll-yaw phenomemnon supposedly
getting its name from the motion attributed to Dutch
sailing vessels ( the design of which was influenced
by the shallow coastal waters in which they often
operated ) of yore. Not sure I believe this but its
the conventional explanation.
I believe early 747 models had a small problem with this
making passengers in the aft rows ill.
IBM
__________________________________________________ _____________________________
Posted Via Uncensored-News.Com - Accounts Starting At $6.95 - http://www.uncensored-news.com
The Worlds Uncensored News Source
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 January 1st 05 07:29 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 November 9th 04 03:47 PM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 May 1st 04 08:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 December 1st 03 06:27 AM
Dutch military cutbacks Ralph Savelsberg Military Aviation 5 July 2nd 03 06:08 PM
