LS-4 FOR SALE:
1982 LS-4, ser. # 4209, N30RD, only 462.8 flight hours. NDH. Standard category certified. Complete logs and manuals. Blue tint canopy. Narrow panel for tall pilots. Sage vario, Tasman, Dittel radio, -302A GPS/logger, iPaq 3950, GNII. Rudder and horiz. tail/elevator refinished ’07. New internal seals and external mylar seals all around. Finish is darn near excellent with only minor crazing in a few typical locations. Completely wet sanded in ’03 with annual hard waxing and constant Wx/ Block. Recently installed or replaced: -Battery box (new battery) -Boom mic. -Electric wiring -Gear struts -Main tire and tube -Pneumatic tubing (color coded) -PTT switch -Quiet vent -Seat belts -Seat cushions (astronaut foam) -Sheepskin seat cover and headrest cover -Speaker -Tail wheel -TEK TE probe -Tip skids -Tost release -Wheel brake rebuilt -Wing wheel 1982 Komet trailer (‘glass top), refinished ‘08, new axle/wheels/ tires, elec. brakes, LED tail lights. This glider/trailer combo is immaculate and needs nothing. No surprises! $40,000 firm. Serious inquiries contact: rcornay at gmail dot com (Georgia) |
On Feb 1, 10:54*am, wrote:
LS-4 FOR SALE: 1982 LS-4, ser. # 4209, N30RD, only 462.8 flight hours. *NDH. Standard category certified. *Complete logs and manuals. Blue tint canopy. *Narrow panel for tall pilots. Sage vario, Tasman, Dittel radio, -302A GPS/logger, iPaq 3950, GNII. Rudder and horiz. tail/elevator refinished ’07. New internal seals and external mylar seals all around. Finish is darn near excellent with only minor crazing in a few typical locations. Completely wet sanded in ’03 with annual hard waxing and constant Wx/ Block. Recently installed or replaced: -Battery box (new battery) -Boom mic. -Electric wiring -Gear struts -Main tire and tube -Pneumatic tubing (color coded) -PTT switch -Quiet vent -Seat belts -Seat cushions (astronaut foam) -Sheepskin seat cover and headrest cover -Speaker -Tail wheel -TEK TE probe -Tip skids -Tost release -Wheel brake rebuilt -Wing wheel 1982 Komet trailer (‘glass top), refinished ‘08, new axle/wheels/ tires, elec. brakes, LED tail lights. This glider/trailer combo is immaculate and needs nothing. *No surprises! $40,000 firm. Serious inquiries contact: *rcornay at gmail dot com *(Georgia) I saw this glider last year at Cordele (Region 5N). It indeed is in perfect condition. Ray, why are you selling your bird? |
On Feb 1, 10:59*am, AK wrote:
On Feb 1, 10:54*am, wrote: LS-4 FOR SALE: 1982 LS-4, ser. # 4209, N30RD, only 462.8 flight hours. *NDH. Standard category certified. *Complete logs and manuals. Blue tint canopy. *Narrow panel for tall pilots. What is the fit like in an LS-4 for a 6'2" 215 lb. pilot? Jeff |
I think the seller is taller than that. I don't see you having a
problem fitting in or being comfortable. Charlie What is the fit like in an LS-4 for a 6'2" 215 lb. pilot? Jeff |
On Feb 12, 10:10*am, wrote:
On Feb 1, 10:59*am, AK wrote: What is the fit like in an LS-4 for a 6'2" 215 lb. pilot? Jeff Jeff - I'm 6'1" and 210 lbs. I flew an LS-4 at Minden last year and found the fit to be fine. LS gliders are a little narrower than some older gliders; but the LS-3 and LS-4 cockpits are roomier than some of the later models of LS aircraft. I found the ergonomics of the LS-4 to be superior to the Discus/Ventus. In fact, I'd say that next to my DG-300 I think the LS-4 had the best ergonomics out of the glider's I've flown (which includes an SZD-55, Mini-Nimbus, Russia AC-4, several Schweizers, Blaniks, G-103s, and more). My torso-to-leg ratio seems to be a little different from folks; so some of these other gliders I flew may fit folks better than they fit me - but in the end i think the handling qualities combined with the decent ergonomics of the LS-4 make it a great ship to own and fly. Take care, --Noel |
On Feb 12, 11:10*am, wrote:
What is the fit like in an LS-4 for a 6'2" 215 lb. pilot? No one will be able to answer that. You have to try it yourself. You won't believe how many people insisted I would fit in an SH A series fuselage. I do not. The big issue with tall people fitting into sailplanes is the relationship between torso length and leg length. 2 people of the same height and weight may have completely different ability to fit a sailplane depending on torso/leg length and also on mass distribution. Andy |
On Feb 12, 1:10*pm, wrote:
On Feb 1, 10:59*am, AK wrote: On Feb 1, 10:54*am, wrote: LS-4 FOR SALE: 1982 LS-4, ser. # 4209, N30RD, only 462.8 flight hours. *NDH. Standard category certified. *Complete logs and manuals. Blue tint canopy. *Narrow panel for tall pilots. What is the fit like in an LS-4 for a 6'2" 215 lb. pilot? Jeff I'm 6' 3", 200lbs, and I flew my LS-4 (X3) for many years. It *was* a tight fit, but do-able. My knees were high enough in the air so the backs of my legs weren't supported, and over time, this caused problems. At about age 58 or so, I started noticing that I had to stand for a few seconds beside the glider before I could walk after a long X-C. The very best glider for a tall person is the Ventus 2bx with the extended nose. I have one now, and it is *wonderful* ;-) Regards, Frank (TA) |
On Feb 12, 2:00*pm, Frank wrote:
The very best glider for a tall person is the Ventus 2bx with the extended nose. *I have one now, and it is *wonderful* ;-) Can you see the tailplane from you normal seated position, just by turning your head? Andy |
Andy wrote:
On Feb 12, 2:00 pm, Frank wrote: The very best glider for a tall person is the Ventus 2bx with the extended nose. I have one now, and it is *wonderful* ;-) Can you see the tailplane from you normal seated position, just by turning your head? Andy Is there any glider that fits a tall person where you can do that? |
LS-8/18 for sale | [email protected] | Soaring | 0 | March 28th 08 11:13 AM |
L39 ZA for sale! | Erik Wertheim | Aviation Marketplace | 2 | September 26th 04 12:23 AM |
Another Cub For Sale | Newps | Owning | 1 | June 6th 04 02:33 AM |
For Sale | samcgiltner | Soaring | 0 | January 15th 04 11:39 PM |
Twin Astir For Sale / Astir CS 77 for Sale | DaveSpringford | Soaring | 0 | December 4th 03 11:30 PM |
