"Secret" Overvoltage Protection?
Old February 15th 09, 05:26 AM posted to rec.aviation.homebuilt
Default "Secret" Overvoltage Protection?
I had an unusual experience last week, and figured I'd air it here for
some opinions.
My Fly Baby had developed charging problems again. I wasn't sure if it
was the generator or regulator, so I decided to do a bit of temporary
wiring to bypass the regulator (Generator armature to +12V, ground the
Field terminal).
I knew that in this mode, the generator could produce high voltages that
could fry my radio (ICOM IC-A5) and transponder (Microair). So I left
the power switches for both off.
I started the engine and watched the voltmeter. It read 8V at idle, but
when the power came up, the voltage started to rise. I chopped the
throttle before the voltage got much past 14V on the gauge.
So, the regulator was bad. Fortunately, I'd bought a spare at a
fly-market a few years back ($5). I switched regulators, buttoned up
the cowl, and mounted up for a test flight.
Strangely enough, neither the radio nor the transponder would power-up
at first try. I cycled the power on and off, and pressed the "on"
buttons on each a couple of times.
The ICOM powered up about the third try, and worked normally. The
Microair was more stubborn, but after about 15 minutes of power-on, it
too came on when I hit the switch.
The only thing I can think of is that both units have some sort of
overvoltage protection that clears itself after a time. Neither has the
classical "On" button with mechanical contacts that make or break the
power to the unit; the "On" button undoubtedly tells some aspect of the
circuit board what to do (on the Microair, one hits the power button
multiple times to adjust the LCD lighting).
Still, the units shouldn't have seen that direct generator output...they
were turned off. So what activated the overvoltage protection?
Anybody got any ideas?
"Stealth" Secret Service aircraft No Name Piloting 10 August 21st 08 12:12 AM
NASA to Release "SECRET" Survey Larry Dighera Piloting 9 November 13th 07 12:54 PM
THE BIGGEST SECRET 9/11, 7/7 and ("Operation Iraqi Freedom"? ) Mighty Thor General Aviation 0 October 27th 07 11:35 AM
THE BIGGEST SECRET 9/11, 7/7 and ("Operation Iraqi Freedom"? ) Mighty Thor Instrument Flight Rules 0 October 27th 07 11:34 AM
Saturday 072807 in Oshkosh Pt 5 - the US Customs and Border Protection Blackhawk [3/5] - "03 Blackhawk - a different angle on Sunday.jpg" yEnc (1/1) Just Plane Noise[_2_] Aviation Photos 0 July 31st 07 07:31 PM
