#11
What has worked for me is to crank DOWN my altimeter 125' at the
beginning of final glide along with closing the airvents (noise), turning on the seat belt sign, and battening down the hatches. I'll be damned if I don't see the altimeter on field elevation at the stops. R |
On Mar 17, 3:45*pm, hretting wrote:
What has worked for me is to crank DOWN my altimeter 125' at the beginning of final glide along with closing the airvents (noise), turning on the seat belt sign, and battening down the hatches. I'll be damned if I don't see the altimeter on field elevation at the stops. R Am I the only one wondering why not just get a current altimeter setting from a local AWOS or such? I suppose there are contest sites so remote there are none. |
Why do that Bubba when I just gave you a simpler way. In 25 contests ,
it has never failed. We're not talking take-off in Miami and landing in Anchorage. R |
Maybe I'm missing something, but the I believe Tom (and the CD at the
Seniors) are mistaken in regard to any altimeter error due to ram air static pressure. The faster the speed the higher the pressure in the cockpit and thus the lower the reading on the altimeter. In other words as you go faster you get a "safety" factor on the altimeter and should finish a couple feet higher than indicated. As to the comments on the danger of collisions at the finish, they are worth attention. A few years ago at the Seniors I was close to the finish in a DG-1000 when another glider overtook us and flew directly over our canopy about 30 feet up. Had I eased off the airspeed just a little.... I don't want to think about it. Incidentally, the owner, worth billions (invented Netscape) was in the back seat and any resulting legal action might have been nasty. Karl Striedieck wrote in message ... What we saw on the new start at the Seniors was in simple words....works great, will be good for along time. Just a note you might want to remember. When you leave threw the top, make sure your flown distance agrees with the distance given you by the scorer. Most of us found a good thermal, dropped down into the cylinder for our 2 minutes below MSH and then thermaled up in the thermal, staying below cloud base and left on course. On the finish. Now, this is for you, Joe the sailplane racers, you need to slow down before crossing into the finish cylinder at the minium finish height. Your altimeter will read wrong at the end of the day and your logger will lag when you cross into the cylinder. We saw alot of finish penalities of 10 to 30 points because some guys were coming in at 130 KTS and crossing into the clyinder at what their altimeter said. Well, we all were warned its best to slow down before crossing into the cylinder at least 10 seconds before you get their and don't count on your altimeter to read correctly at the end of the day. You will lose the fight with the scorer as he uses your logger and what it reads as your altitude when you finish. He DOESN'T see your cockpit altimeter when you finish. That about covers the new start and finish. We had limited internet coverage here at the Seniors and posting news and information was not easy. I did try and post the last day information, but I couldn't get service. My next stop is Perry and hopefully will be able to update my blog with daily news. Also, for those who race sports class, new 2009 handicaps need to be checked. Its best to take your given handicap speed and divide by the raw speed on your score sheet to see if your handicap is correct. It might be a tad off because of the weight adjustment, but if its alot off, either way, bring it to the attention of the scorer. This may be best by writing down your case as then it will be addressed. Thermal tight, Soar high, Fly safe. #711 reporting. |
On Mar 18, 8:04�am, "Karl Striedieck" wrote:
Maybe I'm missing something, but the I believe Tom (and the CD at the Seniors) are mistaken in regard to any altimeter error due to ram air static pressure. The faster the speed the higher the pressure in the cockpit and thus the lower the reading on the altimeter. In other words as you go faster you get a "safety" factor on the altimeter and should finish a couple feet higher than indicated. As to the comments on the danger of collisions at the finish, they are worth attention. A few years ago at the Seniors I was close to the finish in a DG-1000 when another glider overtook us and flew directly over our canopy about 30 feet up. Had I eased off the airspeed just a little.... I don't want to think about it. Incidentally, the owner, worth billions (invented Netscape) was in the back seat and any resulting legal action might have been nasty. Karl Striedieck wrote in message ... What we saw on the new start at the Seniors was in simple words....works great, will be good for along time. Just a note you might want to remember. When you leave threw the top, make sure your flown distance agrees with the distance given you by the scorer. Most of us found a good thermal, dropped down into the cylinder for our 2 minutes below MSH and then thermaled up in the thermal, staying below cloud base and left on course. On the finish. Now, this is for you, Joe the sailplane racers, you need to slow down before crossing into the finish cylinder at the minium finish height. Your altimeter will read wrong at the end of the day and your logger will lag when you cross into the cylinder. We saw alot of finish penalities of 10 to 30 points because some guys were coming in at 130 KTS and crossing into the clyinder at what their altimeter said. Well, we all were warned its best to slow down before crossing into the cylinder at least 10 seconds before you get their and don't count on your altimeter to read correctly at the end of the day. You will lose the fight with the scorer as he uses your logger and what it reads as your altitude when you finish. He DOESN'T see your cockpit altimeter when you finish. That about covers the new start and finish. We had limited internet coverage here at the Seniors and posting news and information was not easy. I did try and post the last day information, but I couldn't get service. My next stop is Perry and hopefully will be able to update my blog with daily news. Also, for those who race sports class, new 2009 handicaps need to be checked. Its best to take your given handicap speed and divide by the raw speed on your score sheet to see if your handicap is correct. It might be a tad off because of the weight adjustment, but if its alot off, either way, bring it to the attention of the scorer. This may be best by writing down your case as then it will be addressed. Thermal tight, Soar high, Fly safe. #711 reporting.- Hide quoted text - - Show quoted text - Yes, I was quoting the CD, and when I think about it, Karl's right, my bad. When flying from a low to a high, the altimeter reads low and your higher than you altimeter shows. When flying from a high to a low, the altimeter reads high and your lower than shown...old saying is high to low, look out below. I do think almost all altimeters are hooked up to the glider static anyway, so really, vent air shouldn't even come into play. Our glider altimeters just don't offer the precession (non electric and non viabrating and we don't have radar altimeters ...yet.) to cut the finish height so close. Its easier to judge the 50 foot height when using a finish line and yes, more fun. But , with the finish circle and finish height, you need to be on the safe side, as if you get a finish penalty, its their on your logger and won't get removed. |
On Mar 17, 2:45*pm, hretting wrote:
What has worked for me is to crank DOWN my altimeter 125' at the beginning of final glide along with closing the airvents (noise), turning on the seat belt sign, and battening down the hatches. I'll be damned if I don't see the altimeter on field elevation at the stops. R That's consistent with my observations. If I don't have a local altimeter setting I reduce my altimeter my 100ft at start of final glide. This gives a conservative final glide but those that don't do that have a hundred foot advantage over us at the finish since they will be scored based on the takeoff altimeter setting. Andy |
On Mar 17, 2:53*pm, bildan wrote:
Am I the only one wondering why not just get a current altimeter setting from a local AWOS or such? *I suppose there are contest sites so remote there are none. This only works of course if the altimeter calibration is accurate. I suspect that most glider pilots set field elavation on takeoff and do not not check that the baro setting matches the local altimeter setting. If there is an offset then that same offset has to be applied before using a local altimeter setting for final glide. I became aware that my Winter altimeter setting was not accurate when I saw large discrepancies between the settings of the Winter and my 302. I had to have my Winter rebuilt to fix the problem. The 100ft offset method works even if the altimeter calibration is horribly wrong. Andy |
On Mar 18, 5:04*am, "Karl Striedieck" wrote:
Maybe I'm missing something, but the I believe Tom (and the CD at the Seniors) are mistaken in regard to any altimeter error due to ram air static pressure. The faster the speed the higher the pressure in the cockpit and thus the lower the reading on the altimeter. In other words as you go faster you get a "safety" factor on the altimeter and should finish a couple feet higher than indicated. If it is true that cockpit pressure increases with speed then, at high speed, loggers with no external static connection will read lower that an altimeter which has an external static connection. This may result in the logger showing a finish below gate altitude while the altimeter indicated a safe margin above. Anyone know for sure that cockpit pressure does actually increase at high speed? Andy |
On Mar 18, 6:43*am, Andy wrote:
On Mar 18, 5:04*am, "Karl Striedieck" wrote: Maybe I'm missing something, but the I believe Tom (and the CD at the Seniors) are mistaken in regard to any altimeter error due to ram air static pressure. The faster the speed the higher the pressure in the cockpit and thus the lower the reading on the altimeter. In other words as you go faster you get a "safety" factor on the altimeter and should finish a couple feet higher than indicated. If it is true that cockpit pressure increases with speed then, at high speed, loggers with no external static connection will read lower that an altimeter which has an external static connection. *This may result in the logger showing a finish below gate altitude while the altimeter indicated a safe margin above. Anyone know for sure that cockpit pressure does actually increase at high speed? Andy Well at least on some gliders you have the air holes in in the luggage shelf blocked (all it takes is a jacket or similar jammed in there) and open the front vent you can feel the pressure increase. It is my impression that many piltos with built in loggers like the Cambridge 302 do not understand that the flight recorder is using cockpit ambient pressure and not the static line-in on the rear of the instrument (only used for airspeed calculations). This is a requirement to prevent the pilot being able to connect to the static line and tamperer with logged pressure altitude. Darryl |
On Mar 18, 7:00*am, Darryl Ramm wrote:
On Mar 18, 6:43*am, Andy wrote: On Mar 18, 5:04*am, "Karl Striedieck" wrote: Maybe I'm missing something, but the I believe Tom (and the CD at the Seniors) are mistaken in regard to any altimeter error due to ram air static pressure. The faster the speed the higher the pressure in the cockpit and thus the lower the reading on the altimeter. In other words as you go faster you get a "safety" factor on the altimeter and should finish a couple feet higher than indicated. If it is true that cockpit pressure increases with speed then, at high speed, loggers with no external static connection will read lower that an altimeter which has an external static connection. *This may result in the logger showing a finish below gate altitude while the altimeter indicated a safe margin above. Anyone know for sure that cockpit pressure does actually increase at high speed? Andy Well at least on some gliders you have the air holes in in the luggage shelf blocked (all it takes is a jacket or similar jammed in there) and open the front vent you can feel the pressure increase. It is my impression that many piltos with built in loggers like the Cambridge 302 do not understand that the flight recorder is using cockpit ambient pressure and not the static line-in on the rear of the instrument (only used for airspeed calculations). This is a requirement to prevent the pilot being able to connect to the static line and tamperer with logged pressure altitude. Darryl Oh and this explains the warnings from knowledgeable CDs. Increased cockpit ambient pressure, the logger will read record lower, while your altimeter will say you are OK. And as mentioned, since you are descending any lag or stickiness in the altimeter will also err to the pilot's disadvantage. Darryl |
Last Day Seniors USA 2009 #711 reporting | [email protected] | Soaring | 0 | March 15th 09 02:12 AM |
Day 2 Seniors USA 2009 711 reporting. | [email protected] | Soaring | 4 | March 13th 09 01:10 AM |
Seniors USA 2009 #711 reporting. | [email protected] | Soaring | 1 | March 9th 09 02:03 AM |
# 2 Day 05 Seniors USA # 711 reporting | [email protected] | Soaring | 2 | March 11th 05 07:36 PM |
Rules for 1000k with start/finish at midpoint. | Andrew Warbrick | Soaring | 2 | August 10th 04 05:04 AM |
