Nice cheat sheet for the electrically challenged
Old March 20th 09, 05:53 PM posted to rec.aviation.soaring
ContestID67[_2_]
Default Nice cheat sheet for the electrically challenged
Yes, in the upper left hand corner it should be Watts X Ohms (not
additive). Turn your head sideways. ;-)
E=IR is what they taught me in Electrical Engineering school (and
everyone else in the electrical field I believe), so, yeah, it is "out
there". For me I simply cannot say "Voltage equals amps times ohms".
V=AO sounds like a fraterity. Your mileage may vary and we both get
the same values and don't melt wires and stuff.
WARNING - Boring science content below...
E = "electromotive force" (EMF)
I = the German Intensität meaning "intensity".
Go figure. Blame it all on Herr Ohm. At least the R still is the
letter that starts resistance (which came from the German resistanz it
seems).
John "Eee equals Eye Are" DeRosa
Old March 20th 09, 09:45 PM posted to rec.aviation.soaring
Cliff Hilty[_2_]
A simpler version and memorizable is:
_ P_ _ E_
I ! E I ! R
PIE and EIR is all you have to remember fill in any two values and divide
top from bottom and multiply across. example:
P/I=E, P/E=I, IxE=P E/I=R, E/R=I, IxR=E
P=Watts (power or VA)
I = Amps (current or flow)
E = Volts (EMF electromotive force)
R= Ohms (Resistance)
Graphics are not good in a text editor but consider the underlines are
solid and the exclamation point is solid and conected to the line also put
a circle around each set of three. With that in mind, if you have any two
you can get the other two, this is for DC only by the way. This was also a
Navy school way of remembering the basics. The other one so fondly
remembered was:
"Bad Boys Rape Our Young Girls Behind Victory Garden Walls"
for the resistor collor code. As you can see it was way before "Tail
hook"
E=3DIR is what they taught me in Electrical Engineering school (and
V=3DAO sounds like a fraterity. Your mileage may vary and we both get
E =3D "electromotive force" (EMF)
I =3D the German Intensit=E4t meaning "intensity".
seems).
Any vision challenged pilots that can give some advice? Kirk Ellis Piloting 22 March 18th 08 12:55 AM
OSH Homerun? Glass Cockpit for the Budget-Challenged Marco Leon Piloting 4 July 27th 07 11:27 PM
FAA Mandatory Pilot Retirement Rule Challenged Larry Dighera Piloting 0 March 20th 05 08:56 PM
METAR cheat sheet M.E. Borner Instrument Flight Rules 11 February 10th 05 07:04 PM
Cuts to Stealth Force Challenged Henry J Cobb Military Aviation 0 March 6th 04 03:22 PM
