#11
"Dan Camper" wrote in message ... On Mon, 23 Mar 2009 21:16:23 -0500, Dan Luke wrote: "vaughn" wrote in message ... "Dan Luke" wrote in message ... And we know how much about that, exactly? We know the Cessna is claiming to do more testing than is required under the LSA Industry Standards. It that biting them on the ass? Are you privy to the testing syllibi of Cessna and "other LSAs?" No, Then how do you know "Cessna is claiming to do more testing than is required under the LSA Industry Standards" but given the range of folks that post here, I would not be surprised to get a useful answer. Perhaps, but that is beside the point. Do you have anything useful to add yourself? Never claimed I did. I questioned your assertion that "Cessna is claiming to do more testing than is required under the LSA Industry Standards." What is your basis for that assertion? Cessna - the new GM -- No, FORD made the Pinto. |
On Tue, 24 Mar 2009 18:43:18 -0400, Darkwing wrote:
"Dan Camper" wrote in message ... On Mon, 23 Mar 2009 21:16:23 -0500, Dan Luke wrote: "vaughn" wrote in message ... "Dan Luke" wrote in message ... And we know how much about that, exactly? We know the Cessna is claiming to do more testing than is required under the LSA Industry Standards. It that biting them on the ass? Are you privy to the testing syllibi of Cessna and "other LSAs?" No, Then how do you know "Cessna is claiming to do more testing than is required under the LSA Industry Standards" but given the range of folks that post here, I would not be surprised to get a useful answer. Perhaps, but that is beside the point. Do you have anything useful to add yourself? Never claimed I did. I questioned your assertion that "Cessna is claiming to do more testing than is required under the LSA Industry Standards." What is your basis for that assertion? Cessna - the new GM -- No, FORD made the Pinto. Ill buy into that. Regardless, Cessna has got a hyooge problem with this bird when you have two crashes with the best of the best test pilots on board. Got to wonder what their doing with those depositors. |
"Dan Camper" wrote in message ... On Tue, 24 Mar 2009 18:43:18 -0400, Darkwing wrote: "Dan Camper" wrote in message ... On Mon, 23 Mar 2009 21:16:23 -0500, Dan Luke wrote: "vaughn" wrote in message ... "Dan Luke" wrote in message ... And we know how much about that, exactly? We know the Cessna is claiming to do more testing than is required under the LSA Industry Standards. It that biting them on the ass? Are you privy to the testing syllibi of Cessna and "other LSAs?" No, Then how do you know "Cessna is claiming to do more testing than is required under the LSA Industry Standards" but given the range of folks that post here, I would not be surprised to get a useful answer. Perhaps, but that is beside the point. Do you have anything useful to add yourself? Never claimed I did. I questioned your assertion that "Cessna is claiming to do more testing than is required under the LSA Industry Standards." What is your basis for that assertion? Cessna - the new GM -- No, FORD made the Pinto. Ill buy into that. Regardless, Cessna has got a hyooge problem with this bird when you have two crashes with the best of the best test pilots on board. Got to wonder what their doing with those depositors. Here's your new Skycatcher! Uh, don't try to spin it. |
On Mar 26, 7:58*am, "Darkwing" theducksmail"AT"yahoo.com wrote:
"Dan Camper" wrote in message ... On Tue, 24 Mar 2009 18:43:18 -0400, Darkwing wrote: "Dan Camper" wrote in message .. . On Mon, 23 Mar 2009 21:16:23 -0500, Dan Luke wrote: "vaughn" wrote in message ... "Dan Luke" wrote in message ... And we know how much about that, exactly? * We know the Cessna is claiming to do more testing than is required under the LSA Industry Standards. *It that biting them on the ass? Are you privy to the testing syllibi of Cessna and "other LSAs?" * No, Then how do you know "Cessna is claiming to do more testing than is required under *the LSA Industry Standards" but given the range of folks that post here, I would not be surprised to get a useful answer. Perhaps, but that is beside the point. Do you have anything useful to add yourself? Never claimed I did. *I questioned your assertion that "Cessna is claiming to do more testing than is required under *the LSA Industry Standards." What is your basis for that assertion? Cessna - the new GM -- No, FORD made the Pinto. Ill buy into that. Regardless, Cessna has got a hyooge problem with this bird when you have two crashes with the best of the best test pilots on board. Got to wonder what their doing with those depositors. Here's your new Skycatcher! Uh, don't try to spin it. they are calling it a basic trainer. Basically stay away from stalling exercises and you'll get your training |
On Mar 21, 1:50*am, "vaughn"
wrote: Is this plane snakebit? *Or is Cessna really testing their product better than the other LSA manufacturers? http://www.aopa.org/aircraft/article...cher.html?WT.m... Vaughn I can imagine the problem resides in a refusal of the plane to drop its nose properly and build airspeed when one wing is more deeply stalled than the other. I'd guess a tendency to be too flat in the spin and adding more rudder is not the solution. One thing that stops yaw increasing is body section and the center of aerodynamic resistance as the spin progresses. It may be that the skinny aft section and a lack of boxiness to increase drag for yaw (and a low inertial nose) makes things worse in that regard. As yaw rate increases the spin starts to flatten... My 2c. Cheers |
I can imagine the problem resides in a refusal of the plane to drop its nose properly and build airspeed when one wing is more deeply stalled than the other. I'd guess a tendency to be too flat in the spin and adding more rudder is not the solution. One thing that stops yaw increasing is body section and the center of aerodynamic resistance as the spin progresses. It may be that the skinny aft section and a lack of boxiness to increase drag for yaw (and a low inertial nose) makes things worse in that regard. As yaw rate increases the spin starts to flatten... My 2c. I'll add another 1cent. worth. Notice that most new designs that are spin resistant have their vertical tail members well in front of the horizontals. That configuration places the fin into clean air as the airplane is spinning and descending.. Where the fin is you could double it, and it would not do much better. It needs to be out in clean air, not blanketed by the horizontal, IMHO. -- Jim in NC |
Helen wrote:
Unlike most of the other LSA manufacturers, Cessna hasn't designed a piston single in more than 40 years and I doubt any of the engineers involved in their last design are still working for them. Helen But one would think they would have left some notes around. |
| Thread Tools | |
| Display Modes | |
| F/A-18D Hornet crashes crashes in San Diego suburb, two homesdestroyed, Two dead so far | AirRaid[_2_] | Naval Aviation | 0 | December 9th 08 02:06 AM |
| 162 Skycatcher crashes | Kingfish | Piloting | 12 | September 22nd 08 11:24 PM |
| RIP Cessna...Skycatcher | Darkwing | Piloting | 134 | December 5th 07 12:10 PM |
| Skycatcher IFR? | Matt Whiting | Owning | 57 | November 27th 07 12:59 AM |
| Skycatcher to be a import. | Gig 601XL Builder | Piloting | 0 | November 26th 07 06:01 PM |
