How to install tubing on the te probe 1/2 way to the rudder?
Old April 2nd 09, 02:30 PM posted to rec.aviation.soaring
Default How to install tubing on the te probe 1/2 way to the rudder?
The tubing from the instrument panel to the total energy probe has
fallen off. The total energy probe on my asw-15b is located half way
from the cockpit to the rudder. It's mounted from the inside of the
fuselage. There are no external bolts. The only thing outside is a
metal hole that curves aft 2.5 inches inside at the bottom of the
metal sleeve.
If my arm was 9 feet long I could easily reach back and slip the
tubing on it. Unfortunately my arm is about 3 feet long. Seems like
if I had a 2X2X8 with some sort of contraption built to hold the
tubing at the end, I could use that to place it on. I can't think of
any ideas to have a good firm grip to slide the tubing over the inside
mounting of the total energy probe.
Any thoughts?
Anyone know a midget I can fly into Mississippi?
Flexible exhaust tubing Stuart & Kathryn Fields Home Built 16 July 13th 08 03:48 AM
Relesable instrument tubing [email protected] Soaring 6 February 13th 07 06:38 AM
pvc tubing/sleeve source? Jim Burns Home Built 4 September 28th 06 04:36 AM
Gauge of tubing??? Michael Horowitz Home Built 7 June 6th 06 02:32 PM
Tubing strength Ernest Christley Home Built 0 January 17th 04 12:43 AM
