NTSB urges grounding of all Zodiac CH-601XL's
Old April 16th 09, 03:41 PM posted to rec.aviation.homebuilt
Frank Stutzman[_3_]
Default NTSB urges grounding of all Zodiac CH-601XL's
cavelamb wrote:
I've flown a 701 with the hingless hinges.
The ailerons felt very stiff in flight.
I can well believe that set-up would prevent flutter -
or at least move the resonant response way up there.
A 701?
Hingless hinges can be done on the 6xx series planes, but the 701
(according to the plans) uses hinges. Not to say that someone couldn't
do it on a 701, but it would seem to be a diversion from the standard
designe that would be of dubious value.
Frank Stutzman
Bonanza N494B "Hula Girl"
Boise, ID
Old April 16th 09, 05:46 PM posted to rec.aviation.homebuilt
Jim Logajan
Ron Wanttaja wrote:
You're right, I don't think they can formally take action against the
Experimental Amateur-Built Zenairs. And if they do, it wouldn't last
long.... the "manufacturer" of the aircraft can "correct the
condition" any way they see fit.
Here's the notice online, which in turn contains links to safety letters to
the FAA and ATSM International:
http://www.ntsb.gov/Pressrel/2009/090414a.html
The very first item NTSB recommends in the FAA letter
(http://www.ntsb.gov/recs/letters/2009/A09_30_37.pdf)
to the FAA is:
"Prohibit further flight of the Zodiac CH-601XL, both special light sport
aircraft and experimental, until such time that the Federal Aviation
Administration determines that the CH-601XL has adequate protection from
flutter. (A-09-30) (Urgent)"
I don't think the authors of that NTSB safety letter quite understand
experimental certificates and their ramifications. For example, there is at
least one builder who pointed out on the Matronics Zenith mailing list that
he built his aircraft using push rods, not cables.
Old April 16th 09, 06:09 PM posted to rec.aviation.homebuilt
cavelamb[_2_]
A 701?
Sorry, bad typo Frank, it was a LOW wing 601HD.
Old April 16th 09, 08:02 PM posted to rec.aviation.homebuilt
Bob Kuykendall
experimental certificates and their ramifications...
Yup. They also don't seem to understand that someone who builds an
aircraft from a kit or from plans is under no obligation to register
that aircraft as having the same type as the kit prototype aircraft.
For example, many of the Schreder HP-series kit sailplanes have types
such as "Drew Two" and "RS-1" and "MR-3" instead of "HP-18" or "HP-11"
or "HP-14." So there are no doubt several CH-601XL aircraft to which
the NTSB's narrowly-worded letter A-09-30 does not apply.
Overall, I think that the NTSB, while perhaps meaning well, is being
too heavy-handed in asking the FAA to take this action. I think that
it would be far more constructive to work with Zenith and with
builders groups to make them aware of the issues and possible
mitigations. I think that it would be well within the FAA's purview to
firmly decline the NTSB's demands.
If they ground every CH-601XL, what else could or might they have
taken action against? Adventurers with their horizontal stabilizer
attachment issues? BD-5As with their marginal takeoff characteristics
and flaky engines? Vari-Ezes (not Long-Ezes) with their somewhat
marginal wing carrythrough strength and attachment plate corrosion
issues? And that's just a few experimental airplanes, to say nothing
about gliders or rotorcraft. In all of these cases the carnage has
been kept to a dull roar by kit makers and builder communities who
(usually) worked together to raise awareness of the issues and to
mitigate them.
Thanks, Bob K.
Old April 16th 09, 08:34 PM posted to rec.aviation.homebuilt
Morgans[_2_]
Jim wrote:
I see both sides of it, but think it is high time that the NTSB made a real
effort to get some changes made, and the top change is to make all of the
owners aware of the problems, as they see them.
As far as the flutter issue goes, the case was made that even planes that
had proper tension on controll cables have had cases of catestrophic
flutter. It should not be that hard to get a mass ballance engineered, such
as a "C" shaped ballance that penetrates the wing ahead of the hinge point,
and attaches to top and bottom of the aileron.
mitigate them.
Jim wrote:
It could be said that the NTSB should have taken a more active stand in many
of the cases you mentioned, and many more might be alive. It would be a
fresh breeze to see action taken before more "blood rules" have to be
written.
If this is the case, it would be wrong to let more die, just because that is
the way it has been done in the past.
Old April 24th 09, 10:39 PM posted to rec.aviation.homebuilt
kfvorwerk
On Apr 14, 2:26*pm, " wrote:
http://www.cnn.com/2009/US/04/14/nts...ane/index.html
Designed by Zenair.
Just saw it on CNN.
Karl
http://www.theledger.com/article/200...odiac-Aircraft
Panel urges Navy move some jet training -- perhaps to Kingsville Otis Willie Naval Aviation 1 September 10th 05 03:53 AM
AOPA urges allowing cell phone use in general aviation Eric Greenwell Soaring 7 March 30th 05 08:44 PM
Grounding of K-7 and K-10s in the UK. Robertmudd1u Soaring 1 May 28th 04 02:53 AM
Rabbi Urges Pig Fat on Buses to Stop Bombers Mike Marron Military Aviation 11 February 20th 04 11:37 PM
