"Simon Robbins" wrote in message ...
"David Harper" wrote in message om... Does the C-130 have two 1553 buses onboard? One for flight control and one for EW/mission systems? I don't think 1553 is used for flight control since the latency and speed isn't sufficient. Mission systems may well use it though. I think by nature 1553 is dual-redundant so that's where you might get the idea of two from. Not familiar with the C-130 personally though. Si Thanks for the info. So none of the flight controls interface with the 1553 at all? I'm just now getting familiar with Mil-HDBK-516 (airworthiness criteria) for my new job and not sure if some of the equipment we are installing on the 1553 bus would affect/cause latency for flight control. From what you've said, apparently that's a non-issue then... I guess on a non-related note, how exactly does equipment on the 1553 bus manage communications to prevent them from overlapping / "stepping on" each other? Is there something in the data sentence once a unit begins transmitting that puts all other equipment on "hold" until it is done sending data? Wouldn't there be interrupts needed for critical equipment to override less critical sentences? Thanks again! Dave |
David Harper wrote:
I guess on a non-related note, how exactly does equipment on the 1553 bus manage communications to prevent them from overlapping / "stepping on" each other? Is there something in the data sentence once a unit begins transmitting that puts all other equipment on "hold" until it is done sending data? Wouldn't there be interrupts needed for critical equipment to override less critical sentences? Collisions don't occur because the bus operates like a classroom where the "pupils" (remote terminals) never speak unless the "teacher" (bus controller) calls on them. It does so by transmitting a command word with the RT's address. The command word also contains a transmit bit in the high state and the number of words to transmit (32 words max). The RT transmits the words, followed by a status word, then goes quiet until it receives another transmit command. There's no way for a remote terminal to bypass this protocol when it's desperate for attention. The standard suggests such emergencies could be handled with a dedicated interrrupt line to the bus controller. Tony wrote: The 1553B bus is, by definition, dual redundant. Each bus has an A and B side. Data is transmitted on one or the other - never both at the same time. That's true for Air Force avionics, but the standard has no blanket requirement for redundancy, does it? MIL-STD-1553B (1978) says, "If redundant data buses are used, the requirements as specified in the following shall apply..." In Notice 2 (1986) a requirement for redundancy was added: "30.2 Application. Section 30 of this appendix shall apply to all dual standby redundant applications for the Army, Navy, and Air Force. All Air Force aircraft internal avionics aplications shall be dual standby redundant, except where safety critical or flight critical requirments dictate a higher level of redundancy." I infer from that paragraph that applications other than "Air Force aircraft internal avionics" can use single buses. By the way, the 1553B standard was titled "Aircraft Internal Time Division Command/Response Multiplex Data Bus" until Notice 2 changed it to "Digital Time Division Command/Response Multiplex Data Bus". The language was slightly revised so it no longer sounded like the standard was only for aircraft. -- Paul Hirose To reply by email delete INVALID from address. |
