Brian Whatcott wrote:
Here's a model report on treating home-builders like grownups. Highlights: Mass balancing controls - tight control wires not enough Reduced stick force per G at higher G made worse by aft CofG Don't push the stick hard by mistake - it may be your last. http://www.ntsb.gov/recs/letters/2009/A09_30_37.pdf Brian W I forgot to mention a tactic used for improving pitch stick force per G. Where an elevator rod or wire is connected by a pulley wheel or lever - a mass on a fore and aft lever arm from the pivot provides a turning moment which increases with increasing g, so as to increase the reaction to elevator control force with g. This was the tactic used on the Spitfire, if I remember.... There's another mass that is not structural like surface balances. Brian W |
On Apr 19, 6:39 pm, Brian Whatcott wrote:
I forgot to mention a tactic used for improving pitch stick force per G. Where an elevator rod or wire is connected by a pulley wheel or lever - a mass on a fore and aft lever arm from the pivot provides a turning moment which increases with increasing g, so as to increase the reaction to elevator control force with g. This was the tactic used on the Spitfire, if I remember.... There's another mass that is not structural like surface balances. That's called a bobweight, and it's to give the pilot some sense of the stress he's putting on the airframe. Many current aircraft use it. Even the Cessna 185, IIRC, has it. See a service bulletin regarding the bobweight on the Citation: http://www.tc.gc.ca/CIVILaviation/ce...rt/1999-05.htm Dan |
On Apr 19, 7:55*pm, wrote:
See a service bulletin regarding the bobweight on the Citation: ------------------------------------------------------------------- Dear Dan, On the Citation I believe you will find it is called the 'Robert Mass'. :-) |
Wanna see an airplane break up from flutter?
Watch the movie clip: http://www.velozia.com/?p=1387 BTW, the Auguste Raspet Memorial Department of Aeronautical Engineering at Mississippi State University does flutter testing on airplanes, including experimentals. Bring your checkbook. White Lightning designer and Citadel-educated engineer Nick Jones had the White Lightning successfully tested there. I have balanced a set of flight controls with lead embedded in the leading edges--- rudder, elevator, ailerons --- for the White Lightning; and no, they are not completely balanced, just enough to avoid flutter up to about 350 kts. This is a 220 kt. cruise aircraft. |
jl wrote:
Wanna see an airplane break up from flutter? Watch the movie clip: http://www.velozia.com/?p=1387 BTW, the Auguste Raspet Memorial Department of Aeronautical Engineering at Mississippi State University does flutter testing on airplanes, including experimentals. Bring your checkbook. White Lightning designer and Citadel-educated engineer Nick Jones had the White Lightning successfully tested there. I have balanced a set of flight controls with lead embedded in the leading edges--- rudder, elevator, ailerons --- for the White Lightning; and no, they are not completely balanced, just enough to avoid flutter up to about 350 kts. This is a 220 kt. cruise aircraft. Great post! That flying wing breakup looked kinda like a divergent pitch oscillation to me. There is nothing like a first hand account of a surface balancing - any idea what proportion of the control surface weight was balanced? That would be an interesting value! Regards Brian W |
jl wrote:
Wanna see an airplane break up from flutter? Watch the movie clip: http://www.velozia.com/?p=1387 Here's the proper way to handle flutter: http://www.youtube.com/watch?v=a-qS7oN-3tA Sorry - it's an experimental aircraft in the traditional sense, so probably not topical for a "homebuilt" group. ;-) |
Klewless newbie alert! (Was Troll alert! Why is "CovvTseTung" using multiple aliases here?) | Maxwell[_2_] | Piloting | 76 | August 22nd 08 04:07 PM |
USA / The Soaring Safety Foundation (SSF) Safety Seminars 2008 | [email protected] | Soaring | 0 | November 8th 07 11:15 PM |
Find a Safety Pilot in your area with Safety Pilot Club | Safety Pilot Club | Instrument Flight Rules | 0 | December 29th 06 03:51 AM |
The Soaring Safety Foundation (SSF) Safety Seminars Hit The Road in the USA | [email protected] | Soaring | 0 | September 11th 06 03:48 AM |
