Examiner "Distractions" During Checkride
Old April 30th 09, 04:44 PM posted to rec.aviation.soaring
Gary Boggs
Default Examiner "Distractions" During Checkride
As an instructor,one of my favorite tricks is to set the altimeter
about 800ft low before the student gets in. The student inviably
turns the knob 200ft to minus 600ft, 1000ft lower than our field.
Then I keep asking how things look. Gets'em every time! The
lesson: Believe your eyes over the instruments!
On Apr 29, 7:59*pm, Michael wrote:
Hi all,
My checkride is a long way off, but this evening I read the PTS for
Gliders for the first time. *I noticed this section:
"Use of Distractions During Practical Tests
Numerous studies indicate that many accidents have occurred when the
pilot has been distracted during critical phases of flight. To
evaluate the applicant’s ability to utilize proper control technique
while dividing attention both inside and/or outside the cockpit, the
examiner shall cause a realistic distraction during the flight portion
of the practical test to evaluate the applicant’s ability to divide
attention while maintaining safe flight."
Obviously, the Examiner isn't going to do anything dangerous, but what
sorts of distractions have people encountered? *It is obvious when the
distraction occurs....or is it something subtle?
--Michael
Old April 30th 09, 10:47 PM posted to rec.aviation.soaring
Mike Ash
In article
That's a good lesson, since the weather can do this to you too. The one
time I did it, I managed to do it to *both* altimeters in a two-seater,
and only discovered the error after getting off tow. Then I asked my
passenger what his read and found out that I did it to both seats. No
big deal as long as you're alert, of course, but I learned something
that day.
Mike Ash
Radio Free Earth
Broadcasting from our climate-controlled studios deep inside the Moon
Old May 1st 09, 12:01 AM posted to rec.aviation.soaring
Jim Logajan
Interesting. If your field elevation is under 1000 ft MSL I would have
assumed that the thousand-foot indicator pointing just left of zero would
be a tipoff.
Old May 1st 09, 03:48 AM posted to rec.aviation.soaring
TonyV[_2_]
be a tipoff.
You'd think - but it ain't so for about half of the folks I pull that
trick on.
Tony LS6-b "6N'
Old May 1st 09, 05:44 AM posted to rec.aviation.soaring
Mike Ash
be a tipoff.
trick on.
It's too easy to see that hand where you "know" it is instead of where
it really is, when you're paying most of your attention to the 100s hand
anyway.
Mike Ash
Radio Free Earth
Old May 1st 09, 08:30 AM posted to rec.aviation.soaring
Jonathon May[_2_]
Default Examiner
These are all good tests. In my 7 years as a basic instructor flying first
flights I have had only one real problem flight,that was when a" Lady "
started to scream at about 100ft and didn't stop untill we finished the
landing roll .Far more distracting because she could not be talked round
and would not shut up.
We beat the tug back.
At 04:44 01 May 2009, Mike Ash wrote:
have
would
be a tipoff.
trick on.
anyway.
Mike Ash
Radio Free Earth
Old May 1st 09, 12:08 AM posted to rec.aviation.soaring
TonyV[_2_]
LOL! I do that too. Our field elevation is about 500 MSL and before the
student gets in, I'll set it to -500 MSL.
Getting back to examiner distractions and/or other things. My students
have reported among the following:
- miss-setting the altimeter as per above before flight when the
applicant is not looking
- purposely failing to lock the canopy (easy to do in a 2-33, more
difficult in other aircraft).
- suggesting chasing distant or downwind thermals.
- raising/lowering the gear while the examiners says "look at that
airplane over there".
- blocking the spoiler handle with his knee.
- suggesting a much longer downwind.
You get the picture.
Tony V
Old May 1st 09, 01:01 PM posted to rec.aviation.soaring
Mike125
I don't see how a mis-adjusted altimeter gets by the pre-flight
checklist. Instruments: altimeter set to field elevation?
Old May 1st 09, 03:06 PM posted to rec.aviation.soaring
BrianC-V6
Do I detect a bit of "invulnerability" there.
It is easy to not be able to see how it can happen, until it happens
to you.
Under the right circumstances it can be very easy to do. To the point
even a highly trained, F16 Thunderbird pilot can do it i.e. Mountain
Home AFB Crash.
Brian
CFIIG/ASEL
Old May 1st 09, 05:23 PM posted to rec.aviation.soaring
Mike Ash
In article
You check it, see that it's a bit off, and set it so that it's correct.
All the while, never noticing that the thousands hand is in the wrong
place.
The human brain has a powerful capacity for illusion. If you "know" that
something is true, it can be difficult to see otherwise. Especially when
the object in question is small and you're not concentrating on it.
Mike Ash
Radio Free Earth
Checkride Wednesday...followup to: "Tips for Commercial Glider Checkride?" Don Byrer Soaring 4 July 19th 08 03:57 AM
Phrase "landing runway" vs. "cleared to land" Robert M. Gary Piloting 168 February 5th 08 05:32 PM
Phrase "landing runway" vs. "cleared to land" Robert M. Gary Instrument Flight Rules 137 February 5th 08 05:32 PM
Old polish aircraft TS-8 "Bies" ("Bogy") - for sale >pk Aviation Marketplace 0 October 16th 06 07:48 AM
