On Wed, 15 Oct 2003 06:56:54 +0000, Rich S. wrote:
Harbor Freight currently has their filter/regulator/lubricator unit #45009 on sale at 50% off ($19.99). http://www.harborfreight.com/cpi/cta...unction=Search I bought this particular item earlier this year on sale at HF. It leaked so I brought it back to exchange it with one that now also leaks, audibly. This is with only the water filter and regulator in the line. - Holger |
Ed Wischmeyer wrote: Who has recommendations for inline filters on the air compressor, for water and other stuff? And sources? thanks I second the tool lubricator. You definitely need a water filter (sump) and need to drain the air tank periodically, or it will corrode and can result in a nasty explosion. A friend was painting a new RV-8 and was getting fisheye, even though he had cleaned everything. I suggested that his air supply was contaminated (it was) and was putting out droplets of oil alnoh with the paint. He cleaned wverything up and got a nice finish. |
![]() "Ed Wischmeyer" wrote in message ... Who has recommendations for inline filters on the air compressor, for water and other stuff? And sources? thanks Ed Wischmeyer I like my filter which uses a roll of toilet tissue. I'll go look at the name on it. intermission Okay, it's an M-30 from Motor Guard Corporation, Manteca, CA. Pricey but effective, particularly when painting. Of course you know to cool your air (thus condensing the water in it) by having a couple of risers in each line with collectors and valves at the bottom of the loops to drain off water. I notice they are freeze-drying the compressed air at the Ford Dealer before it reaches the paint gun. If you're running an air-tool, oil it at the inlet. Use a 2-stage compressor too. It runs cooler. Hot air is not good, especially when compressed because it's usually full of moisture. And remember Boyle's law of temperature, pressure, and volume of a gas. Well, YOU would, Ed. |
Ed,
I just put a Wix Aquachek in my system. I used the 50 cfm model and got it at Carquest. $69.95. I can't tell you how well it works since we just put it in today. They recommend putting a regular water separator ahead of it to increase filter life, but we're trying it without one. http://www.aquachekfilters.com/products/faq.asp Give me a week or so and I'll tell you what I think of it. Replacement elements are around $30. John Stricker "Ed Wischmeyer" wrote in message ... Who has recommendations for inline filters on the air compressor, for water and other stuff? And sources? thanks Ed Wischmeyer |
![]() I tried several of the so called water filters/driers without much success. The problem is the hoses were cooler than the air tank and the water would condense in the hose. I decided I needed to cool and condense the water out of the hot air that comes out of the compressor BEFORE it goes into the tank. I gutted an old 3 ton air conditioner and left only the fan and the condenser coil. I connected this between the compressor and the tank with a self draining water trap at the output of the condenser. The fan runs only when the compressor is running. It works VERY well. I can run the compressor for hours and get ZERO water out of the air lines now. This also removes most of the compressor's oil mist from the air. John On Wed, 15 Oct 2003 06:37:06 -0700, Ed Wischmeyer wrote: Who has recommendations for inline filters on the air compressor, for water and other stuff? And sources? thanks Ed Wischmeyer |
I have a set of videos on automotive restoraton, and in one of them it
shows a homemade air drier which consists of shop air plumbed into a coil of copper tubing, which is then placed in a bucket of ice water followed by a tee fitting with a drain. The cold causes water vapor to condense to liquid, which can be drained periodically. It seemed to be a cheap and effective setup for occasional painting or whenever dry air is required. ---------------------------------------------------- Del Rawlins- Remove _kills_spammers_ to reply via email. Unofficial Bearhawk FAQ website: http://www.rawlinsbrothers.org/bhfaq/ |
If you are setting up a paint rig, then the most cost effective working
strategy is going to be a combination filter/regulator unit (called a "piggyback" in the industry) followed by AT LEAST a coalescing filter unit, in series. Minimum 5 micron filtration on the piggyback, and 0.01 micron on the coalescer. That will take care of the oil and dirt. For water, there are a few good inline desicant-type units that will work with low CFM's. A refer-dryer is much better, but most start in the $1000 range. If you're only going to use air tools, then the piggyback unit alone would be sufficient. I would only add a lube unit if the air line its attached to is dedicated to tools that require (the same) oil. The best units on the market are made by Wilkerson, Norgren, and SMC. These are REAL units that industrial machines use. BUT in your CFM range, they shouldn't cost any more than the junk that Harbor Freight sells ($20-$50) If you can't find an industrial pneumatics supplier in your area, try contacting SEPA (South East Pneumatic Automation) in Atlanta. The owner is a retired Lockheed engineer. www.sepaautomation.com That should do it. Harry former pneumatic industrial sales specialist |
