![]() "Eunometic" wrote in message om... "Kevin Brooks" wrote in message ... "Eunometic" wrote in message ... snip more of Arndt's unsupported fantasies The reason for the 'bouncing bomb' was surely that it was the ony way that a large charge could be placed accurately. There are at least half a dozen different guidence methods in service in various types of missile that can achieve 1 meter accuracy. Maverick, Martel, the old Condor, Raptor, SLAMER differential GPS, TV with or without man in the loop etc. All that is needed is to 'super size' them. An extraction of a MOAB sized weapon from a C130 being one option. A C-130 penetrating 1400 miles of PRC airspace and delivering a MOAB, huh? Get a grip. And doesn't "differential GPS" require both quite a bit of time and some post-processing? The MOAB launch vehicle and system is what is interesting. Taiwan I expect does have C130s and this suggests that extracting a 10 ton missile by parachute from a cargo plane is possible. Perhaps 20 tons is possible from a C130? Neither "missile" would be capable of breaching TG. For gosh sakes, people, TG is a friggin' GRAVITY dam--its a large concrete monolith! Folks keep comparing this to the Ruhr dams--but weren't they *arch* dams? One hell of a difference between the cross sectional depth of an arch structure and that of a gravity structure. Again, get a grip on reality. MOAB is a freefall device. I would envisage a missile more akin to either skybolt or blue steel to give the necessary standoff capabillity. Great, now you have a standoff capability with a puny warhead that can't do anymore than scab the concrete. And doesn't "differential GPS" require both quite a bit of time and some post-processing It only needs to update and calibrate an inertial platform. No, I believe you are talking about two different things. Differential GPS is the process used by surveyors to acheive sub-meter (centimeter?) level accuracy, and it requires positioning of ground transponders and some degree of post processing support. One advanced version of SCUD has a TV guidence system to reduce the accruacy to well below 50 meters. (Using a trident missile for this sort of business with a penetrating warhead is another option) Taiwan has neither Scuds not Tridents. Scud lacks enough of a warhead, too. In WW2 apart from the fact that the carrier aircraft were impossibly vulnerable And a C-130 lumbering through PLA and PLAAF defended territory would not be?! Yes, well rather a lot of standoff capability would be needed. Again, you trade standoff for warhead load; acheiveing standoff means you are not going to have enough whumpf! to do the job against a monolithic concrete gravity dam of the size of TG. Brooks snip |
"Kevin Brooks" wrote: Neither "missile" would be capable of breaching TG. For gosh sakes, people, TG is a friggin' GRAVITY dam--its a large concrete monolith! Folks keep comparing this to the Ruhr dams--but weren't they *arch* dams? Nope. They were arch-*shaped*, but the Moehne and Eder were gravity dams. Oddly enough, the RAF officers who thought the mission wouldn't work in 1943 were saying pretty much the same things you're saying now. "The bombs aren't big enough, you can't put them in place, the risk isn't worth it..." -- cirby at cfl.rr.com Remember: Objects in rearview mirror may be hallucinations. Slam on brakes accordingly. |
30 Jan 2004 - Today’s Military, Veteran, War and National Security News | Otis Willie | Military Aviation | 0 | January 31st 04 03:55 AM |
15 Dec 2003 - Today’s Military, Veteran, War and National Security News | Otis Willie | Military Aviation | 0 | December 15th 03 10:01 PM |
27 Nov 2003 - Today’s Military, Veteran, War and National Security News | Otis Willie | Military Aviation | 1 | November 30th 03 05:57 PM |
11 Nov 2003 - Today’s Military, Veteran, War and National Security News | Otis Willie | Military Aviation | 0 | November 11th 03 11:58 PM |
18 Sep 2003 - Today’s Military, Veteran, War and National Security News | Otis Willie | Military Aviation | 0 | September 19th 03 03:47 AM |
