#11
I would like to solicit comments on the question: Compared to a standard
tail configuration such as a 2-33 or Blanik L-13, does the initiation and recovery from a spin vary substantially in *T-tail (ASK-21 type), all-flying (Phoebus) or V-tail (HP series) sailplanes? Really look forward to reading and learning. Center of Gravity is critically important when considering spin characteristics. The same 'docile' ship with a forward CofG can bite your head off quite easily with an aft CofG, regardless of tail type... which in my book this is the single most important reason to fully understand and fully respect the G/G specs for whatever ship you are in. Now up to $0.04 on the subject, -Paul |
sisu1a schrieb:
Center of Gravity is critically important when considering spin characteristics. The same 'docile' ship with a forward CofG can bite C of G ist critical for spin entry, but for recovering from a sustained spin, mass distribution is far more important. (The rudder force must overcome the angular momentum.) Of course, C of G and mass distribution are somehow related. |
On Mon, 11 May 2009 21:53:53 +0200, John Smith
wrote: Eric was the accident investigator for this case and examined the spin behaviour of another salto. He found that the salto would only recover with the stick pushed *fully* forward. I've been doing some spins in the alto myself - the cause for this is the poor (doenwards) deflection of the outside tail surface, the inner having sufficient deflection but being blocked by the outer tail surface. But again, this is the theory, in practice, do whatever the AFM recommends. Always a good advice. By the way, it's pretty amazing how spin manners change with CG. Bye Andreas |
On Mon, 11 May 2009 12:59:17 -0700 (PDT), Cats
wrote: And if you can get an ASK-21 to spin I suggest you check the cockpit weights - I don't know anyone who has without the use of tail ballast. Raises his hand and yells "Here" The 21 won't stay in the spin (will enter a spiral dive after 1.5 turns), but even enters a spin with pretty forward CG (up to 30%). How to reproduce this: - Start turn in a 15 degrees bank at 130 kp/h - raise nose 10 degrees over the horizon and keep this attitude. Speed is going to bleed off - at 80-82 kph IAS enter full rudder into the direction of the turn and start to pull back the stick fully to raise pitch attitude slowly - once the 21 starts to rotate, apply full adverse aileron - Keep full rudder, adverse aileron and full elevator Voila - the 21 starts to spin immediately. You'll find your self in a genuine spin and can practice recovery techniques. After 1.5 turns it will recover itself into a very steep spiral dive. Neutralizing the controls will end the spin immediately. Bye Andreas |
On Mon, 11 May 2009 23:19:26 +0200, John Smith
wrote: C of G ist critical for spin entry, but for recovering from a sustained spin, mass distribution is far more important. (The rudder force must overcome the angular momentum.) Interesting noone has mentiond flap setting yet - setting the flaps to negative is by far the best way to quicken up the spin recovery. I guess pretty many pilots here have flown the ASW-20 - recovering it with setting 4 (zhermal setting) with a medium to rearward CG ca take up to 2 turns, but with flaps 1 (fully negative) recovery takes at maximum 0.75 turns. Bye Andreas |
On May 11, 3:19*pm, Andreas Maurer wrote:
On Mon, 11 May 2009 23:19:26 +0200, John Smith wrote: C of G ist critical for spin entry, but for recovering from a sustained spin, mass distribution is far more important. (The rudder force must overcome the angular momentum.) Interesting noone has mentiond flap setting yet - setting the flaps to negative is by far the best way to quicken up the spin recovery. I guess pretty many pilots here have flown the ASW-20 - recovering it with setting 4 (zhermal setting) with a medium to rearward CG ca take up to 2 turns, but with flaps 1 (fully negative) recovery takes at maximum 0.75 turns. Bye Andreas Not surprising at all - it would surprise me if anybody really wants to teach this. Lets see - - A desire to teach a standardized recovery - Don't distract people with grabbing for a handle while under stress (or if not stress just physically being thrown around a little) - Likelyhood of grabbing the wrong handle (esp. if transitioning from another ship) and just moving it (i.e. opening full spoilers) - With full negative flap what happens to increased likelihood of entering another/reverse spin if the pilot recovers too "hard"? Darryl |
On Mon, 11 May 2009 09:53:56 -0700 (PDT), bildan
wrote: This led to the NACA standard spin recovery technique which called for anti-spin rudder while holding full up elevator until the auto- rotation slowed and only then applying down elevator. The reasoning was that full up elevator exposed more of the rudder to high energy flow. Trying this method in nearly any glider is a very safe way to get killed. I am pretty sure that most glasss gliders of the least 40 years will not recover from a spin if the elevator is held fully up during the recovery attempt - they simply are not going to stop rotation quickly enough. Bye Andreas |
On May 11, 4:30*pm, Andreas Maurer wrote:
On Mon, 11 May 2009 09:53:56 -0700 (PDT), bildan wrote: This led to the NACA standard spin recovery technique which called for anti-spin rudder while holding full up elevator until the auto- rotation slowed and only then applying down elevator. *The reasoning was that full up elevator exposed more of the rudder to high energy flow. Trying this method in nearly any glider is a very safe way to get killed. I am pretty sure that most glasss gliders of the least 40 years will not recover from a spin if the elevator is held fully up during the recovery attempt - they simply are not going to stop rotation quickly enough. Bye Andreas Read more carefully. I didn't write anything about trying a recovery with full up elevator. I wrote "until the auto-rotation slowed and only then applying down elevator" |
to negative is by far the best way to quicken up the spin recovery. Actually flap settings are touched on in my first $0.02 I pitched in 9 posts ago... although I make no mention of negative flaps I simply state that retracting them hastens the recovery process in it, and that it was probably not specific to V tails... The Fowler flaps on my Sisu had 0-20 deg, but no neg... but- flap setting as a concept was at least mentioned ![]() Feeling like I only pitched in $0.04 (OK, maybe $0.05), but for an actual price of $0.06, -Paul |
Interesting noone has mentiond flap setting yet - setting the flaps to negative is by far the best way to quicken up the spin recovery. It may quicken up the recovery, but JAR-22 requires a sailplane to recover with any flap setting. |
Spin Recovery Training Before First Solo? | [email protected] | Piloting | 16 | September 9th 07 03:48 AM |
Spin Recovery Training Before First Solo? | [email protected] | Piloting | 1 | September 5th 07 09:51 PM |
SR22 Spin Recovery | gwengler | Piloting | 9 | September 24th 04 07:31 AM |
inverted spin recovery explanation | Alan Wood | Aerobatics | 18 | August 19th 04 03:32 PM |
Edelweiss - Spin recovery procedures | Uri Saovray | Soaring | 7 | March 15th 04 12:41 AM |
