Since we're talking electronic sensors...
Old May 16th 09, 03:56 AM posted to rec.aviation.homebuilt
Brian Whatcott
Default Since we're talking electronic sensors...
Charlie wrote:
on most light private aircraft just how critical is the weight anyway?
do you think it might be a solution in search of a problem?
Stealth Pilot
While I'd agree with that last pair of rhetorical questions if all
pilots exercised some semblance of good judgment, perusal of accident
records will quickly reveal how critical excess weight can be.
Charlie
As I recall, FARs use 170 lbs as the standard passenger weight for
airline weight & balance calcs. It's been a while since I've seen
many males at 170 lbs.
Women at that weight can be hard to find in these parts too....
Brian W
Old May 16th 09, 10:13 AM posted to rec.aviation.homebuilt
Michael[_6_]
I agree. I would suspect that centre of gravity is more likely to cause
problems than weight for light aircraft.
Absolutely Like the AoA sensor, pilots can get by perfectly well
without this. But it's just another tool which can add to safety, and I
enjoy thinking about this stuff... especially when I should be working on
assignments. Like right now
Old May 16th 09, 04:52 PM posted to rec.aviation.homebuilt
Peter Dohm
"Michael" wrote in message
The balance problem is not at all confined to light aircraft.
Actually, I suspect the ligh aircraft are less sensitive to balance problems
because of their relatively short fuselages and (usually) small capacity as
a fraction of gross weight.
The main advantage of heavy aircraft is that they are much more likely to
have their loads planned and secured--and also calculated for all of the
fuel distributions that might reasonably occur during the flight.
Old May 17th 09, 02:15 AM posted to rec.aviation.homebuilt
Dan D[_2_]
"Stealth Pilot" wrote in message ...
I've heard a discussion of this and the point made was that the wings
are still flying while parked on the ground. in still air the system
would work but with a breeze, or worse in gusts, the system may never
sense the actual aircraft weight.
the other problem was calibrating the weighing (certifying the thing)
and finding really horizontal ground all the time.
Stealth Pilot
In a truly integrated aircraft, the air data computer would sense the 'levelness' of the aircraft and factor out any
gust accelerations. The computer should be able to derive the weight fairly easily...
Old May 18th 09, 01:03 AM posted to rec.aviation.homebuilt
Peter Dohm
"Dan D" wrote in message
Stealth Pilot
'levelness' of the aircraft and factor out any gust accelerations. The
It is not quite that simple. The system you describe would still not
eliminate the steady state component of the wind.
Peter
Old May 18th 09, 02:34 AM posted to rec.aviation.homebuilt
Jim Logajan
On 14 May 2009 10:37:08 GMT, Michael
"The issue is that you need to certify the thing, or you can't use it
for any flight crew annunciations. So, to certify it, you need to be
able to guarantee performance. And, if you can't certify it, you can't
take any credit for it being there. Still a potential safety
improvement, but not nearly as cost effective as beating on the flight
crew and dispatches to make sure they actually put in the real
weight."
So the system could incorporate signals from strain gauges(gages?)
attached to the wings and rudder. Then those forces could be included in
the computation. A nice side benefit of such instrumentation is that one
can view and have recorded a history of the forces on the aircraft during
flights. All your landings where you had a nice squeaker (or dropped it
in) precisely quantified and forever preserved, if you so desire! :-)
Could also incorporate a signal from a gravity attitude sensor (e.g.
damped plumb bob). Can't think of any useful side benefit to that extra
sensor, though.
C.G. is the useful thing on all size aircraft.
Some homebuilders are putting $10k++ instrument panels in their
experimentals that are often expensive solutions in seach of problems, so
I don't see any problem at all in experimental minded builders playing
around in such an underlooked area. Compared to experimenting with things
like engines, attaching sensors is a relatively benign area to experiment
in. (Not entirely benign of course - e.g. one could badly place sensor
wire runs that interfere with controls.)
Old May 19th 09, 04:57 AM posted to rec.aviation.homebuilt
Bob Fry
"JL" == Jim Logajan writes:
JL Could also incorporate a signal from a gravity attitude sensor
JL (e.g. damped plumb bob). Can't think of any useful side
JL benefit to that extra sensor, though.
Good grief. Just average the landing gear weight data over 10 seconds
or so.
Almost all absurdity of conduct arises from the imitation of those
whom we cannot resemble.
~ Samuel Johnson
Old May 19th 09, 05:28 AM posted to rec.aviation.homebuilt
cavelamb[_2_]
or so.
Nope.
You could have a very accurate wrong answer...
Old May 21st 09, 03:48 AM posted to rec.aviation.homebuilt
Bob Fry
"cl" == cavelamb writes:
sensor
seconds or so.
cl Nope.
cl You could have a very accurate wrong answer...
Why?
If it were all so simple! If only there were evil people somewhere
insidiously committing evil deeds, and it were necessary only to
separate them from the rest of us and destroy them; but the line
dividing good and evil cuts through the heart of every human
being. And who is willing to destroy a piece of his own heart?
~ Aleksandr Solzhenitsyn
Old May 21st 09, 07:33 AM posted to rec.aviation.homebuilt
cavelamb[_2_]
sensor
seconds or so.
cl Nope.
Why?
ALWAYS, Always, I tell you my son...
close the hanger doors before weighing.
Information on Gas sensors [email protected] Owning 1 July 2nd 06 07:30 AM
Ethanol & capacitance fuel-level sensors Adam Aulick Home Built 4 May 20th 06 04:28 PM
effectiveness of infra red sensors at detecting aircraft Fe Military Aviation 4 June 6th 04 12:38 PM
FS: BEI Systron Donner QRS11 GyroChip Sensors Jup06 Aviation Marketplace 0 February 11th 04 09:41 PM
oxygen sensors for aircraft Air Methods Corporation Home Built 0 September 21st 03 08:16 PM
