On May 16, 12:18*pm, wrote:
On May 16, 2:00*pm, wrote: On May 15, 8:13*pm, wrote: On May 15, 8:02*pm, ContestID67 wrote: Interesting idea which I had thought about for automotive use. *Of course there is increased power draw but it would be a poor man's ClearNav. *Does only the Dell's provide you VGA out? *How about IPAQs. *Thanks. A number of PDAs have VGA displays. I just happened to see the VGA cable advertisement and realized the Dell did not need any other components to drive a VGA display. I would think the other PDS could also do this, although I am not sure. I have found a document for the DELL pin outs, which would allow you to construct a cable with interfaces to the VGA, GPS and a power source. Yes, sticking together a bunch of off-the-shelf components does look like a poor-man solution, but more like the Craggy Aero design approach. I understand the ClearNav design focused on ergonomics and NK designed all new hardware and software components to achieve this goal The price of both systems is very close, however, and much higher then this poor- man approach would cost - if it worked. It's hard to believe someone has not experimented with this already. Here is the Dell pin out map. Look at the bottom of the page.http://www.handhelds.org/moin/moin.c...ximX50Hardware Actuall the Craggy Aero Design focused on performance and value to the customer. *It has 1" larger on the diagonal screen, 3 to 4 times the processor speed, 4 times more resolution 640X480 , State of the art Software SeeYou Mobile or WinPilot and a very erogonomic hand held ball track mouse. No messy boards on the back and $300 less than a Clear Nav. Richardwww.craggyaero.com hmmm ... ok, so looking at the mix of off the shelf components, how come it is only 300 less ... shouldn't it be half the cost of a ClearNav? Or is the difference reflective of a higher mark-up?- Hide quoted text - - Show quoted text - Jim, If you look at the mix of components: Tthe Craggy Aero Ultimate has 4 times more screen resolution that the ClearNav, three to 4 times better faster processor, a larger screen, a brighter screen and state of the art fully developed software. So it should cost more that the ClearNav but as I said before it is $300 less. Richard www.craggyaero.com |
Screen Luminance | [email protected] | Soaring | 11 | October 14th 08 08:04 AM |
U.S. Soaring on the Small Screen (sort of...) | Bob Whelan[_2_] | Soaring | 0 | June 21st 08 05:49 PM |
Screen shots in OS2 | Michael Baldwin, Bruce | Products | 0 | November 9th 06 07:18 AM |
Screen freezing. | W.Lindsay | Simulators | 3 | May 10th 06 09:03 PM |
Dual screen in FS9 | John Mullen | Simulators | 2 | September 29th 03 12:59 AM |
