The Home-made Home-builders Engine
Old May 29th 09, 03:15 PM posted to rec.aviation.homebuilt
Veeduber[_2_]
Default The Home-made Home-builders Engine
To All:
For those of us who own a lathe and milling machine, somewhere in our
past there is probably a tiny steam engine. Indeed, there's probably
more than than one. A company in England provides the basic castings
as a kit. As the machinist, you are expected to provide all else,
from the machine to do the work to the KNOWLEDGE needed to operate the
machine.
Producing such an engine, from the basic one-cylinder model to larger
engines of remarkable complexity, serves as silent testimony as to our
abilities.
It strikes me as little more than a step along the way to produce a
FULL SIZE engine such as the Pobjoy. The crankshaft calls for a
professional piece of goods, probably obtainable from a Chinese
manufacturer, but the cylinders, being identical, call for much less
in the way of skills and tooling. With cast-iron cylinder barrels and
cast aluminum heads, the bulk of the engine can be produced on the
tooling found in the shops of literally thousands of amateur
machinists found in every country around the world.
While the copyright to the engine is presently held by the same
company that produces the Rotax, there are enough example of the
Pobjoy in aviation museums that it would be a relatively minor chore
to produce a set of drawings. Indeed, knowing the engine's bore &
stroke even a good PHOTOGRAPH gives a wealth of data leading to a
usable drawing. So long as those drawings contained significant
differences from the original there should be no question as to
violation of those rights. Such differences could be calling out
parts and bearings NOT used in the original Pobjoy.
With suitable drawings in hand we could produce the required molds
needed to produce the required castings. The drawings will also tell
us what gears and bearings are required, allowing us to order them
from suppliers who deal in such components. The drawings will also
show what type of valve guides are needed and even the valves, springs
and rocker-arms. With a bore of 75mm and a stroke of 87, we can
determine what EXISTING pistons my be used as well as the size of the
carburetor that is required.
The 'Experiment- Amateur-built' licensing category exists to promote
aeronautical education in America. Learning how radial engines work
and even building one yourself is no more difficult, in my opinion,
than building your own airframe.
-Robert S. Hoover
Another home-made helicopter Dave Whiley Aviation Photos 0 November 19th 07 11:45 PM
Home Made Helicopter J.F. Aviation Photos 0 November 17th 07 02:02 PM
Good news for scratch builders of metal airplanes - Home Depot rents bending brakes flybynightkarmarepair Home Built 7 January 6th 07 04:22 PM
Home made plane crashes Bill Smith Piloting 0 August 7th 06 06:07 AM
Home made aviation websites are cool! CFLav8r Piloting 2 January 21st 04 05:31 AM
