#11
On Mon, 22 Jun 2009 11:45:02 +0000, Del C wrote:
Generally it is OK to make 180 or 360 degree turns in a modern gliders, as long as you start at at least 300ft and keep the airspeed up to a safe manoeuvring speed. The failure to do the latter seems to have been the probably cause of this accident. I'm really curious about the field layout: I've never flown a winch launch from a flat land field where it wasn't possible to land ahead from a low break or to fly an abbreviated circuit from a higher one, but then again I've never flown from a site where the winch was positioned off the end of the runway. I believe there are fields in Germany and at least one in NZ with a remotely positioned winch. I can imagine situations on that type of field where landing ahead may not be a good option, so does Sandhill have this type of field layout? -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
Andreas Maurer wrote:
Completely wrong for a winch launch. In case of a rope-break, you are either able to land straight-on on the airfield, or you have sufficient altitude(300 ft+) to fly a *safe* pattern. Or, at some places, when you are too high for a straight landing but too low for a complete circuit, you do a safe 180 and make a safe downwind landing. The crucial point is a thorough departure briefing. |
I will never understand why some people think that *two* 180 at low
altitude are safer than *one*. Where does this downwind landing taboo originate? |
We are speculating which is wrong.It could be a very experienced P2
reacting inapropiately and P1 not able to take over in time.The more experienced "bloggs" the clever the traps they create for the instructor.I think it unlikely that they made a basic land ahead/pattern mistake, ,more likely failed to take over in time because P2 was nearly right.Lets not insult the guys they paid a terrible price in the name of a sport we all love. At 12:20 22 June 2009, John Smith wrote: Andreas Maurer wrote: Completely wrong for a winch launch. In case of a rope-break, you are either able to land straight-on on the airfield, or you have sufficient altitude(300 ft+) to fly a *safe* pattern. Or, at some places, when you are too high for a straight landing but too low for a complete circuit, you do a safe 180 and make a safe downwind landing. The crucial point is a thorough departure briefing. |
![]() "John Smith" wrote in message . .. Where does this downwind landing taboo originate? What downwind landing taboo? Here in the US, the 180 degree "rope break" downwind landing is part of the standard pre-solo curriculum. Vaughn |
We don't know exactly what happened, but there are 3 main causes of
winching accidents. A wing down on the ground run, causing the glider to cartwheel. Too steep, too soon, resulting in a stalled wing and the start of a spin. Both of these happen VERY fast. Not achieving and maintaining a safe airspeed after a launch failure, resulting in a stall or spin. Here in the UK the BGA has been addressing winching accidents, and put out good advice. It is worth looking at. Dave At 13:00 22 June 2009, Jonathon May wrote: We are speculating which is wrong.It could be a very experienced P2 reacting inapropiately and P1 not able to take over in time.The more experienced "bloggs" the clever the traps they create for the instructor.I think it unlikely that they made a basic land ahead/pattern mistake, ,more likely failed to take over in time because P2 was nearly right.Lets not insult the guys they paid a terrible price in the name of a sport we all love. At 12:20 22 June 2009, John Smith wrote: Andreas Maurer wrote: Completely wrong for a winch launch. In case of a rope-break, you are either able to land straight-on on the airfield, or you have sufficient altitude(300 ft+) to fly a *safe* pattern. Or, at some places, when you are too high for a straight landing but too low for a complete circuit, you do a safe 180 and make a safe downwind landing. The crucial point is a thorough departure briefing. |
On Jun 22, 6:15*am, Martin Gregorie
wrote: On Mon, 22 Jun 2009 11:45:02 +0000, Del C wrote: Generally it is OK to make 180 or 360 degree turns in a modern gliders, as long as you start at at least 300ft and keep the airspeed up to a safe manoeuvring speed. The failure to do the latter seems to have been the probably cause of this accident. I'm really curious about the field layout: I've never flown a winch launch from a flat land field where it wasn't possible to land ahead from a low break or to fly an abbreviated circuit from a higher one, but then again I've never flown from a site where the winch was positioned off the end of the runway. I believe there are fields in Germany and at least one in NZ with a remotely positioned winch. I can imagine situations on that type of field where landing ahead may not be a good option, so does Sandhill have this type of field layout? * -- martin@ * | Martin Gregorie gregorie. | Essex, UK org * * * | Google Earth 42.4417017 / -84.0666186 for the layout. The winch run, ~3300ft, should be fairly clear. |
On Jun 22, 5:45*am, Del C wrote:
Generally it is OK to make 180 or 360 degree turns in a modern gliders, as long as you start at at least 300ft and keep the airspeed up to a safe manoeuvring speed. The failure to do the latter seems to have been the probably cause of this accident. Also US glider pilots, mostly trained on aerotows, may not have properly thought through the options available after a winch launch cable break. Derek Copeland (UK gliding instructor) At 10:48 22 June 2009, Scott wrote: The club in question probably winch launches more than any other in the US. I'm not aware on any current winch operation not training to an acceptable standard. There was one several years ago selling endorsements in about six launches. That operation is now out of business in the aero tow world also. |
On Jun 22, 7:43*am, "vaughn"
wrote: "John Smith" wrote in message . .. Where does this downwind landing taboo originate? What downwind landing taboo? *Here in the US, the 180 degree "rope break" downwind landing is part of the standard pre-solo curriculum. Vaughn Since many critical facts are still unknown, it's impossible to comment on this particular crash except to offer our deepest sympathy and condolences to all concerned - especially the pilot. One can only imagine the burden he carries. But, speaking generally about winch launch failures, if you are high enough that landing straight ahead is impossible, then you will have plenty of altitude for a closely linked pair of 180 turns which will end with the gilder lined up with the runway for an into-the-wind landing. The last 180 to final approach should never be below 200 feet AGL which is comparable to the 200' 180 turn to a downwind landing taught aero tow students. Even on short runways, the straight ahead option and the circle to land option overlap by several hundred feet, depending on things like spoiler effectiveness and wind speed, making the decision not particularly critical. Nonetheless, a pilot is encouraged to estimate a "critical altitude" above which a straight ahead landing would be problematical before beginning the launch. This mental preparation makes it easier to decide which way to go. What IS critical is getting the nose down without the slightest delay. Push the nose as far below the horizon as it was above it at the point of failure then WAIT until you see a safe airspeed with an increasing trend before deciding on which option to execute. The top priority is always the same - FLY THE GLIDER! If the decision is circle to land, just as with the aero tow 180 turn at 200', the glider must be flown with precise airspeed and coordination control. The intent is NOT to stop at the launch point - just to make a safe landing anywhere on the airfield. Managing a winch launch failure is neither difficult nor unsafe but it does require some training and forethought. Launch failures have been managed safely many millions of times just using basic glider instrumentation. However, I think significantly fewer accidents would have happened if angle of attack indicators were universally installed. |
On Jun 22, 4:05*am, Dave Doe wrote:
In article , says... At 04:03 19 June 2009, Dave Doe wrote: In article , says... Who knows details about this? http://www.mlive.com/news/annarborne...news-32/124507.... There is some more info here... http://www.stuff.co.nz/national/2515...wi-pilot-named United States police today released the name of a New Zealand pilot killed last Sunday when the glider in which he was a passenger crashed.. Timothy John Moxham, 29, was a pilot for an air ambulance, Midwest Medflight. Police said a delay in releasing details of his identity was because of the difficulty in reaching his parents in New Zealand. Mr Moxham died in a glider owned by the Sandhill Soaring Club and flown by the club president when it crashed near Ann Arbor, Michigan. Preliminary investigation indicated a winch cable used to help the aircraft take flight may have failed on takeoff, police chief William Cook of the nearby Unadilla Township told the Daily Press and Argus newspaper. The Federal Aviation Administration is investigating. The glider pilot, Orrin Burns Beckham, 63, of Ann Arbor, is in a serious condition in a local hospital. A colleague of the New Zealander, Medflight paramedic Andrew King said Mr Moxham took his job to heart. "Not only did Tim love flying and love being a pilot, but he loved being a part of the (team) and getting people to the appropriate hospitals." Mr King said Mr Moxham's desire to go gliding was recent. He said prior to the trip, Moxham told him: "This is true flying. It's just you and (nature)." The New Zealander had been flying for more than 15 years, starting at the age of 13 when his father taught him, and had logged more than 3000 hours of flight time, including flying offshore, corporate work and flight instruction. He also held certification to an FAA standards on airframe construction and engine mechanics. "People say we've lost a pilot, but he was so much more than that," said another colleague, Medflight nurse Doug Berry. "He had such compassion for the job and the people we transported. He cared about people. "He touched the lives of hundreds of people," Mr Berry added, choking back tears. "He was amazing." - NZPA -- Duncan NTSB prelim is at * * http://www.ntsb.gov/ntsb/brief.asp?e...15X13631&key=1 Thanks Ron. I see... " Witnesses reported that the glider was launched with a winch and during the procedure the winch cable broke. The pilot executed a 180-degree turn apparently in an attempt to return to the airport. However, near the completion of the turn, the nose of the glider dropped and it impacted the terrain. " How many times!!! - *don't* try to return to the field! *OK, I don't know the altitude (AGL) nor what was ahead of the field, but hey, we all know, this is generally regarded as a no-no. -- Duncan I suggest you take a look at the Private Pilot Glider Practical Test Guide. 180 (really 270) turns to a downwind landing are SOP for gliders after a aerotow rope break. 180 turns to a downwind landing are NOT SOP for a winch launch failure since at 200 feet the glider is still very near the approach end of the runway - a 180 turn will leave you with nowhere to land. Downwind landings are not necessary or even advisable with winch launch failures. |
Pay out winch launch to 2500ft agl.. | WAVEGURU | Soaring | 8 | June 5th 07 07:06 AM |
Winch Launch Videos | Mike Schumann | Soaring | 2 | January 19th 06 11:27 PM |
LIppmann reports a 950 meter winch launch with their Dynatec winch line - anything higher? | Bill Daniels | Soaring | 20 | December 27th 04 12:33 AM |
Electric winch fatality story in August Soaring | Bill Daniels | Soaring | 0 | August 14th 04 02:37 AM |
Winch launch | M B | Soaring | 0 | October 30th 03 07:33 PM |
