Testing On The Cheap
Old July 3rd 09, 12:36 AM posted to rec.aviation.homebuilt
cavelamb[_2_]
Default Testing On The Cheap
Brian Whatcott wrote:
A striking comment in a wonderful book on engineering design disasters
mentioned casually that the proof load on a particular aluminum airliner
wing would bend it to the vertical at the tips [if buckling did not
occur long before....]
Perhaps you were too hasty to scrub the project?? I have looked out the
window in bumpy conditions to see wingtips flapping a yard or two....
Brian W
I've seen them do that in a 747.
Old July 21st 09, 05:13 AM posted to rec.aviation.homebuilt
Stealth Pilot[_2_]
On Thu, 02 Jul 2009 18:36:18 -0500, cavelamb
Brian W
....and here I was expecting you to post "I've seen them do that in the
texas taildragger"
Stealth :-) Pilot
Old July 21st 09, 02:59 PM posted to rec.aviation.homebuilt
RST Engineering - JIm
When I went through 727 fixit school, they showed us a video of the static
test of that bird. THe wingtips came within about a yard of each other
before the whole thing let go, but when it did it looked like an aluminum
blizzard.
Old July 3rd 09, 01:31 AM posted to rec.aviation.homebuilt
bildan
On Jul 2, 5:11*pm, Brian Whatcott wrote:
bildan wrote:
On Jul 2, 1:37 am, Veeduber wrote:
So... how strong is your wing?
The only sure way to know is to TEST it.
How do we do that? *We roll the airframe over on it's nose, support
the main spar with a structure of some sort... Douglas Fir 2x4's works
okay... then we stack a known weight onto the wing.
Still confused? *No problem; just follow me through. *We already know
what the bird weighs., thanks to all those imaginary flights out to
Catalina and back. *Empty weight is 318 pounds.. *Nine gallons of
gasoline is 54 pounds and one sorta-skinny pilot is 155 pounds, so
we've got 318 + 54 + 155 = 527 pounds... and we wanna see if the wing
will support 527 pounds. *(Yeah, I know... lemme work up to it.)
Start by removing the spinner and the prop, then bolt-on a wooden
bolster that weighs exactly the same as the spinner & prop. *Now we
whistle-up some help and we ever to gently roll the plane forward,
first onto the bolster and then onto the support structure that pokes
up into the cockpit and bears against the main spar about where my
legs would go. *The structure is kinda high because we dont want the
vertical stabilizer to touch the driveway. *But we finally get it
rolled over and supported on the structure we've made (now THERE was a
fun project). *Is it level? *We check it out. *Then we position a
couple of yard-sticks just off each wing tip. Now we cover the wing
with cardboard and start stacking on the weight.
What kinda weight?
Well... back in the Good Ol' Days, whenever that was, our local EAA
chapter would have a couple thousand pounds of lead weights all neatly
marked in matching pairs, and they'd deliver it and bust their backs
helping you do the Static Test (which doesn't have anything to do with
radio). *Nowadays your best bet is probably bags of Portland cement or
other building material ( ...such as Plaster Sand... *) available in
bags, each marked with the weight of the contents. *( Anywhere outside
of the USA it'll probably be marked in kilograms instead of pounds.
Not a probelm; just work it out. )
Now you lay the weights onto the protected surface of the upside-down
wing, starting in the middle and working your way out toward the
tips. *Five hundred and twenty-seven pounds is about six bags of
Portland cement so you'd have three bags per side.
Out at the wing tips, the marker aligned with your yard-sticks (meter
sticks across the pond) probably won't show any deflection at all.
Five hundred and sixty-four pounds ( that is, six times 94 ) equals
one g, which means you are cruizing along in level flight.
So what's your plane rated for? *If it's non-aerobatic it's probably
rated for Utility Class, which is about 3.3g, * Which means 3.3 times
517 or about 1706 pounds. *Which happens to be about 18 bags of
Portland cement, so that's what you stack on, starting at the middle
and working your way out toward the tips, keeping an eye on those yard
sticks.
Odds are, you won't have any problem at 3.3g's -- the wing probably
won't deflect at all. *Now all you've got to do is take a buncha
pictures and get everyone to sign the log. *Or you could keep piling
on the weight until something breaks. *That would indicate the
Ultimate Load for that particular structure but you gotta be careful
dealing with that amount of weight, especially if you're working in
somebody elses hangar, because when something fails it's liable to
flip those bags of cement around like a frisbee.
A lot of times you aren't working with a finished airframe; lots of
times you'll only be working with a part of an airplane, such as it's
horizontal stabilizer, or perhaps an engine mount., *That's when
things can get interesting, because you may be trying to achieve 8 or
9 g's. *That's when you'll want to have a couple of video cameras
running, because when the failure occurs it's liable to happen fast.
Sometimes you may be testing nothing more than a main spar, probably
bolted to a fixture you've designed to support it. *If the main spar
is made of wood there's a good chance that you've fabricated this
sample out of something less expensive than Sitka Spruce and aviation
plywood.
Or you could be testing the strength of a part with the wood at a
different orientation. (Which is what this message was all about to
begin with.) *:-)
Gravity and persistence can teach you a good deal about aeronautics
without ever leaving the ground. *You'll have to fabricate your
supporting structure and line-up a suitable supply of weight, but
having done so you may find there is more to aeronautics than you
realized...
I'll leave the next step up to you because when you get right down to
it, YOU are the mechanic-in-charge.
-R.S.Hoover
Been there, done that. *It answers a lot of nagging questions.
Story:
Brand new (at the time) fiberglass sailplane wing design gets bolted
to the massive hangar corner I-beam where special root fitting adapter
has been welded. *Wing extends horizontally at shoulder height with
the lower surface up. *Shot bags are added spaced according to the
span-wise lift distribution. *Wing tip touches ground at 1.8G *Crap!
No room for back hoe so dig pit by hand with shovels. *Pit under wing
tip *now at grade - 2'. *Add shot bags to 2.6G when tip touches bottom
of pit. *Crap!
Four more hours of digging and pit is grade - 5'. *Shot bags to 3.9G.
Tip touches pit bottom Crap!
It starts raining. *Must remove shot bags and wing to interior of
hangar. *Removing wing in the rain is BIG problem since there is now a
pit where the tip man would have to stand. *Rain continues - pit is
under roof drain so it fills with water. *Crap!
Rethink. *It may be strong enough but is it stiff enough? *Decision -
wing needs to be stiffer. *Project dies. *Better it than the test
pilot.
Brian W
Nope. A 10'+ tip deflection meant the aileron push rods wouldn't
work. Then there was the worry about flutter. The 1st generation
glass sailplanes were built to ~ +-20G just so they would be stiff
enough to avoid flutter. It took the introduction of carbon fiber
composite to finally make the strength and stiffness come out right.
Old July 5th 09, 08:32 PM posted to rec.aviation.homebuilt
Dan[_12_]
How do we do that? We roll the airframe over on it's nose, support
Still confused? No problem; just follow me through. We already know
Catalina and back. Empty weight is 318 pounds.. Nine gallons of
will support 527 pounds. (Yeah, I know... lemme work up to it.)
bolster that weighs exactly the same as the spinner & prop. Now we
legs would go. The structure is kinda high because we dont want the
vertical stabilizer to touch the driveway. But we finally get it
fun project). Is it level? We check it out. Then we position a
What kinda weight?
radio). Nowadays your best bet is probably bags of Portland cement or
other building material ( ...such as Plaster Sand... ) available in
bags, each marked with the weight of the contents. ( Anywhere outside
tips. Five hundred and twenty-seven pounds is about six bags of
So what's your plane rated for? If it's non-aerobatic it's probably
rated for Utility Class, which is about 3.3g, Which means 3.3 times
517 or about 1706 pounds. Which happens to be about 18 bags of
sticks.
won't deflect at all. Now all you've got to do is take a buncha
pictures and get everyone to sign the log. Or you could keep piling
on the weight until something breaks. That would indicate the
horizontal stabilizer, or perhaps an engine mount., That's when
9 g's. That's when you'll want to have a couple of video cameras
bolted to a fixture you've designed to support it. If the main spar
plywood.
begin with.) :-)
without ever leaving the ground. You'll have to fabricate your
realized...
-R.S.Hoover
Been there, done that. It answers a lot of nagging questions.
Story:
has been welded. Wing extends horizontally at shoulder height with
the lower surface up. Shot bags are added spaced according to the
span-wise lift distribution. Wing tip touches ground at 1.8G Crap!
No room for back hoe so dig pit by hand with shovels. Pit under wing
tip now at grade - 2'. Add shot bags to 2.6G when tip touches bottom
of pit. Crap!
Four more hours of digging and pit is grade - 5'. Shot bags to 3.9G.
It starts raining. Must remove shot bags and wing to interior of
hangar. Removing wing in the rain is BIG problem since there is now a
pit where the tip man would have to stand. Rain continues - pit is
under roof drain so it fills with water. Crap!
Rethink. It may be strong enough but is it stiff enough? Decision -
wing needs to be stiffer. Project dies. Better it than the test
pilot.
Brian W
If memory serves the B-707 wig tips had something on the order of 14
feet of flex designed in. I wonder how much flex a B-777 has.
Dan, U.S. Air Force, retired
Old July 5th 09, 08:58 PM posted to rec.aviation.homebuilt
jan olieslagers[_2_]
Dan schreef:
B-707 wig tips
Hm. Tad out of period, no? Gay parades only since 1980's or thereabout?
Old July 5th 09, 09:03 PM posted to rec.aviation.homebuilt
Dan[_12_]
jan olieslagers wrote:
Dan schreef:
B-707 wig tips
I know how old B-707 is, but it was the only figure I could think of
off the top of my head. Senility, nicht wahr?
Old July 8th 09, 12:57 AM posted to rec.aviation.homebuilt
Tim[_8_]
"Dan" wrote in message
http://www.youtube.com/watch?v=pe9PVaFGl3o
Old July 4th 09, 10:41 PM posted to rec.aviation.homebuilt
Charlie[_2_]
What kinda weight?
sticks.
plywood.
begin with.) :-)
realized...
-R.S.Hoover
Load testing a new design is a good thing, but simply stacking the load
across the wing evenly will likely break even a properly designed &
built wing. The load needs to be distributed to match the lift
distribution, which isn't linear. The wing should also be tilted to
match its angle of attack near stall so the load is angled toward the
leading edge, because the loaded wing is actually trying to swing up and
forward (relative to the fuselage) under load.
The next thing is that if something breaks, it can cause a lot of
shrapnel, and the multi-ton load/wing can head in who knows which
direction. If you look at the procedures used by manufacturers &
reputable kit makers, at each step in loading they support the wing,
load it up, slowly release the supports for the specified number of
seconds and immediately re-support the wing.
I did it once the way you describe on a Dragonfly canard I didn't trust
(previously repaired damage) but in retrospect, I could have killed
myself just testing the wing.
Here are a couple of links to Van's A/C testing that hint at what I'm
trying to describe.
http://vansaircraft.com/public/rv-10int3.htm
http://vansaircraft.com/pdf/12_NOVEMBER_UPDATE.pdf
Charlie
CHEAP Los Angeles C-172 Flying Club CHEAP [email protected] Aviation Marketplace 7 May 7th 09 03:32 PM
CHEAP Los Angeles C-172 Flying Club CHEAP [email protected] Owning 1 May 7th 09 03:32 PM
CHEAP Los Angeles C-172 Flying Club CHEAP Sunho Owning 2 May 7th 09 12:13 AM
CHEAP Los Angeles C-172 Flying Club CHEAP xyzzy Owning 0 April 6th 09 03:31 PM
Testing the Testing of Mogas Jay Honeck Piloting 22 July 24th 06 09:38 PM
