On Jul 3, 7:38*am, Surfer! wrote:
In message , Ian writes On 2 July, 20:21, Brian wrote: I totally believe most stall spin accident soccur because the pilot is not thinking about a stall spin and is not on the hair trigger ready to recover, .i.e. they are distracted from this issue. I believe that many of the spin accidents in the UK occur because most pilots are trained ab initio in unspinnable gliders and, whatever their instructors say, end up believing deep down that spins have to be specially provoked in specially prepared or chosen aircraft. What glider has killed most pilots in spins? The K21. However the two recent accidents both involved US pilots, presumably trained in the US. *Is the K21 so ubiquitous over there? BTW have seen folks allowed to fly the K21 solo without spin training, but *not* the Juniors. -- Surfer! Email to: ramwater at uk2 dot net Don't think the accidents had anything to do with training and certainly nothing to do with the K21 or whatever other ships they may have trained in. These were experienced competition pilots. -T8 |
On 3 July, 12:38, Surfer! wrote:
BTW have seen folks allowed to fly the K21 solo without spin training, but *not* the Juniors. Juniors have a complicated spin mode which is generally three turns nose down and recoverable, three flat and unrecoverable, rinse, repeat. If you don't recover in the first three turns (Turn 1: ****, better get the nose up. Turn 2: why didn't that work? Turn 3: What's spin recovery again?) you just have to sweat it out for a few hundred feet or your current altitude, whichever is less. Ian |
We changed our spin training approach based on this thought.
We now have the student enter a thermaling turn at slow speed with about 30 degrees of bank. Keep coaching them to get it slower, sometimes on their own they use a little too much inside rudder and zippity do dah.. spin entry. I had one Grob 103 check out, doing cross controlled stalls at about 15 degrees of bank and it got very slightly uncoordinated. The inside wing started to drop, and the student applied correcting aileron. I saw the nose starting to track to the inside of the very quickly and I just as quickly took the controls and applied spin recovery procedure. The student also saw it and asked if we could do that again... ahh... not intentionally and not this low. We were high enough per FAR for Stalls, but not above for my personal floor for spin recognition / recovery practice. BT "T8" wrote in message ... Okay guys, here's your new thread. Please... Del asks "how well will pilots react if they unexpectedly get into a spin or a spiral dive? Normally you gird your loins up first before doing a deliberate spin!" Answer: this depends on the pilot, of course. By the time you are gaggle flying, thermaling up off ridges or flying in competition it damned well better be automatic, reflexive. The only point to doing deliberate spins by stalling straight ahead and kicking rudder is to get some sense of how the sailplane behaves and what it takes to recover from a fully developed spin. It might also help you develop some sense of spin entry feel, but unintentional spins normally come from some combination of turning, skidding flight, gusts, etc. Oh, there's also the famous pilot who transitioned from 15m to std class and early on charged into a gaggle, pulled up, reached for the "flap" handle and spun out of the gaggle with spoilers deployed. UH, hUH! But I won't mention any names :-). I love that story. What you should practice is realistic spin entries from thermaling turns and simulated pattern turns gone bad. Do 'em in all aircraft configurations. In flapped ships the behavior changes quite a lot. If you are fooling with CG location, check that out too. Your responses can and should become fast and accurate. You should do this until you aren't "girding your loins", you aren't tense. No panic. Aircraft departs controlled flight: so what, you deal with it, get it back. regards, Evan Ludeman / T8 |
I personally am of the opinion that a lot of people thermal too slowly
and put themselves in a position to have an inadvertent stall/spin accident. Most of us are aware that stall speed goes up in a banked turn. But the desire to fly slowly and stay in the thermal keeps us down in the "danger-zone", just above the stall speed. This is unnecessary and can actually be a big hinderance! Why? 1) There's no reason to fly below min-sink speed, as any good glider handbook will tell you. What they don't usually mention is that your min-sink speed is higher in a banked turn than straight-and-level flight! The same G-loading that affects your stall speed also affects your whole glide polar - just as added wing-loading does when you use water ballast. So in a thermal you should already be flying a bit faster than the POH indicates for min-sink. How much faster depends on your bank angle, and the same calculations for stall speed in a banked turn should be applicable to your aircraft. 2) The slower you go, the less control authority you have. This means upsets are tougher to avoid, recovery from an unusual attitude is harder to achieve, and control deflections have to be bigger in order to make normal corrections to maintain your bank & pitch angles. Remember - bigger control deflections equal more drag! 3) Remember that your airframe and wings start to experience localized areas of separated airflow long before you get down to true stall speed. _Any_ dirty or separated airflow is extra drag and can result in a slower overall climb-rate (as you burn some of your energy maintaining speed and countering the drag forces). You want the entire aircraft to be sliding through the air as cleanly as possible to maximize the lift in the thermal! 4) Thermals contain unstable air - turbulence and wind gusts and the shear around the edges of the thermal can all create assymetrical lift conditions across the wings; or cause airflow separation on parts of the wing (if the boundary layer is already close to seaparating). The closer you are to stall speed, the more likely this is to suddenly occur due to gusts or shear effects. (For those of you who are trying to fly fast, add in the effects of your water-ballast to all of this, too) Just some food for thought, --Noel |
On Jul 2, 3:27*pm, "noel.wade" wrote:
I personally am of the opinion that a lot of people thermal too slowly and put themselves in a position to have an inadvertent stall/spin accident. Most of us are aware that stall speed goes up in a banked turn. *But the desire to fly slowly and stay in the thermal keeps us down in the "danger-zone", just above the stall speed. *This is unnecessary and can actually be a big hinderance! *Why? 1) There's no reason to fly below min-sink speed, as any good glider handbook will tell you. *What they don't usually mention is that your min-sink speed is higher in a banked turn than straight-and-level flight! *The same G-loading that affects your stall speed also affects your whole glide polar - just as added wing-loading does when you use water ballast. *So in a thermal you should already be flying a bit faster than the POH indicates for min-sink. *How much faster depends on your bank angle, and the same calculations for stall speed in a banked turn should be applicable to your aircraft. 2) The slower you go, the less control authority you have. *This means upsets are tougher to avoid, recovery from an unusual attitude is harder to achieve, and control deflections have to be bigger in order to make normal corrections to maintain your bank & pitch angles. Remember - bigger control deflections equal more drag! 3) Remember that your airframe and wings start to experience localized areas of separated airflow long before you get down to true stall speed. *_Any_ dirty or separated airflow is extra drag and can result in a slower overall climb-rate (as you burn some of your energy maintaining speed and countering the drag forces). *You want the entire aircraft to be sliding through the air as cleanly as possible to maximize the lift in the thermal! 4) Thermals contain unstable air - turbulence and wind gusts and the shear around the edges of the thermal can all create assymetrical lift conditions across the wings; or cause airflow separation on parts of the wing (if the boundary layer is already close to seaparating). *The closer you are to stall speed, the more likely this is to suddenly occur due to gusts or shear effects. (For those of you who are trying to fly fast, add in the effects of your water-ballast to all of this, too) Just some food for thought, --Noel For this reason and for safety is why I advocate an angle of attack indicator. The AOA indicator will help determine the exact airspeed for minimum sink for your wing loading and bank angle. Then, you can use either instrument as your guide. There's actually quite a large range of AOA between min sink and stall so flying min sink AOA will keep you a safe distance from a stall. I have to think that an AOA indicator 'might' have saved at least one life this summer. |
Our club's DG1000T has a stall warning device that sounds when a certain
angle of attack is reached. However I find the thing a distaction, as it goes off every time you hit a gust (thermals tend to be gusty) and I can comfortably circle at a speed where it is sounding all the time. If Noel Wade came to visit the UK, he would probably not be able to climb at all in our often tiny little thermals using the techniques he suggests. The necessary skill is to be able to fly in accurate well banked turns at not more than about 5 knots over the turning stall speed. Otherwise he will be going round in the sink surrounding the thermal. However I agree that you should not fly so slowly that the glider is buffeting, as that is inefficient and dangerous. By the way, my favourite spin entry for annual checks on our members is out of a well banked turn. All you have to is slow the glider down in a typical thermalling turn until it is just starting to buffet and then feed in a bit of bottom rudder. The glider will depart instantly into a fully developed spin. This demonstrates the need for accurate flying and for not using too much rudder into the turn. If you put in a bit of top rudder it is almost impossible to make the glider spin, however slowly you fly it. Del Copeland At 22:27 02 July 2009, bildan wrote: On Jul 2, 3:27=A0pm, "noel.wade" wrote: I personally am of the opinion that a lot of people thermal too slowly and put themselves in a position to have an inadvertent stall/spin accident. Most of us are aware that stall speed goes up in a banked turn. =A0But the desire to fly slowly and stay in the thermal keeps us down in the "danger-zone", just above the stall speed. =A0This is unnecessary and can actually be a big hinderance! =A0Why? 1) There's no reason to fly below min-sink speed, as any good glider handbook will tell you. =A0What they don't usually mention is that your min-sink speed is higher in a banked turn than straight-and-level flight! =A0The same G-loading that affects your stall speed also affects your whole glide polar - just as added wing-loading does when you use water ballast. =A0So in a thermal you should already be flying a bit faster than the POH indicates for min-sink. =A0How much faster depends on your bank angle, and the same calculations for stall speed in a banked turn should be applicable to your aircraft. 2) The slower you go, the less control authority you have. =A0This means upsets are tougher to avoid, recovery from an unusual attitude is harder to achieve, and control deflections have to be bigger in order to make normal corrections to maintain your bank & pitch angles. Remember - bigger control deflections equal more drag! 3) Remember that your airframe and wings start to experience localized areas of separated airflow long before you get down to true stall speed. =A0_Any_ dirty or separated airflow is extra drag and can result in a slower overall climb-rate (as you burn some of your energy maintaining speed and countering the drag forces). =A0You want the entire aircraft to be sliding through the air as cleanly as possible to maximize the lift in the thermal! 4) Thermals contain unstable air - turbulence and wind gusts and the shear around the edges of the thermal can all create assymetrical lift conditions across the wings; or cause airflow separation on parts of the wing (if the boundary layer is already close to seaparating). =A0The closer you are to stall speed, the more likely this is to suddenly occur due to gusts or shear effects. (For those of you who are trying to fly fast, add in the effects of your water-ballast to all of this, too) Just some food for thought, --Noel For this reason and for safety is why I advocate an angle of attack indicator. The AOA indicator will help determine the exact airspeed for minimum sink for your wing loading and bank angle. Then, you can use either instrument as your guide. There's actually quite a large range of AOA between min sink and stall so flying min sink AOA will keep you a safe distance from a stall. I have to think that an AOA indicator 'might' have saved at least one life this summer. |
On Jul 3, 12:00*am, Derek Copeland wrote:
If Noel Wade came to visit the UK, he would probably not be able to climb at all in our often tiny little thermals using the techniques he suggests.. The necessary skill is to be able to fly in accurate well banked turns at not more than about 5 knots over the turning stall speed. Otherwise he will be going round in thesinksurrounding the thermal. Derek - Thanks for attacking my skills rather than arguing the point from a logical perspective... I trained and fly in places that have both weak lift and narrow lift, and I stay in them just fine - for the record. Now, to actually defend the point: If your argument is that you have to fly slowly in order to stay in a small thermal, you're ignoring an alternate solution: tighten your bank angle. It is true that a slower speed gives you a smaller turning radius at the same bank-angle, but it has a number of drawbacks (many of which I touched on with my post - you're closer to stall speed, you're possibly below min-sink - and therefore not flying the glider as cleanly or efficiently as you could be). If you simply keep your speed up and tighten your bank angle, you'll achieve a smaller turning radius and you won't be in danger of stalling. I urge you to do the math, as I have done (or at least look it up online, there are webpages that illustrate this - such as: http://www.soarns.ca/crclmotn.html)... Down around the speeds we're talking about, you will have a _smaller_ turn radius at a 45-degree bank-angle than at a 30-degree bank-angle, EVEN if you add 5 - 7 knots of speed in the higher bank-angle turn. AND the additional G-loading does not increase your sink rate by that much (around 20 ft/min in my DG-300). Even in a small 2-knot thermal you're really only giving up a small percentage of performance in order to be a lot safer. And there are plenty of ways that the average pilot can "make up" that performance, by flying more cleanly in other phases of flight. Finally, if you _have_ been flying below min-sink speed (for a given bank-angle), you may actually find _improved_ climb performance by keeping your speed up and tightening your bank-angle. Take care, --Noel |
yes.. but the idea is to train spin recognition and recovery..
and why it is not good to thermal too slowly.. but how if the pilot is not attentive to his speed.. he can get into trouble.. not fun in a thermal with others below BT "noel.wade" wrote in message ... I personally am of the opinion that a lot of people thermal too slowly and put themselves in a position to have an inadvertent stall/spin accident. Most of us are aware that stall speed goes up in a banked turn. But the desire to fly slowly and stay in the thermal keeps us down in the "danger-zone", just above the stall speed. This is unnecessary and can actually be a big hinderance! Why? 1) There's no reason to fly below min-sink speed, as any good glider handbook will tell you. What they don't usually mention is that your min-sink speed is higher in a banked turn than straight-and-level flight! The same G-loading that affects your stall speed also affects your whole glide polar - just as added wing-loading does when you use water ballast. So in a thermal you should already be flying a bit faster than the POH indicates for min-sink. How much faster depends on your bank angle, and the same calculations for stall speed in a banked turn should be applicable to your aircraft. 2) The slower you go, the less control authority you have. This means upsets are tougher to avoid, recovery from an unusual attitude is harder to achieve, and control deflections have to be bigger in order to make normal corrections to maintain your bank & pitch angles. Remember - bigger control deflections equal more drag! 3) Remember that your airframe and wings start to experience localized areas of separated airflow long before you get down to true stall speed. _Any_ dirty or separated airflow is extra drag and can result in a slower overall climb-rate (as you burn some of your energy maintaining speed and countering the drag forces). You want the entire aircraft to be sliding through the air as cleanly as possible to maximize the lift in the thermal! 4) Thermals contain unstable air - turbulence and wind gusts and the shear around the edges of the thermal can all create assymetrical lift conditions across the wings; or cause airflow separation on parts of the wing (if the boundary layer is already close to seaparating). The closer you are to stall speed, the more likely this is to suddenly occur due to gusts or shear effects. (For those of you who are trying to fly fast, add in the effects of your water-ballast to all of this, too) Just some food for thought, --Noel |
If may, I would like to get off on a bit of a tangent, i.e. the
original subject stated in the title of this thread. One of the problems that I have observed with students and a few high time pilots alike is the following: when presented with a spin or a spiral dive, mis-diagnosing the problem and applying the wrong recovery. To some who experience these maneuvers infrequently, they appear similar enough to bring about confusion and as you know, applying the wrong recovery can get grim. I believe airspeed, sound and G are the keys with the latter two very important. Some are so confused by the ground spinning around that they don't think about looking at the airspeed indicator. But they do seem to sense if it is relatively quiet or loud and if they are experiencing more than 1G. A thorough ground briefing on the differences and then demonstrating both on the same flight really helps. Then follow that with a lesson where they must make the diagnosis and apply the proper recovery. This has worked for me. I would enjoy hearing from others who have thoughts on this very important subject. Paul ZZ 8 wrote: Okay guys, here's your new thread. Please... Del asks "how well will pilots react if they unexpectedly get into a spin or a spiral dive? Normally you gird your loins up first before doing a deliberate spin!" Answer: this depends on the pilot, of course. By the time you are gaggle flying, thermaling up off ridges or flying in competition it damned well better be automatic, reflexive. The only point to doing deliberate spins by stalling straight ahead and kicking rudder is to get some sense of how the sailplane behaves and what it takes to recover from a fully developed spin. It might also help you develop some sense of spin entry feel, but unintentional spins normally come from some combination of turning, skidding flight, gusts, etc. Oh, there's also the famous pilot who transitioned from 15m to std class and early on charged into a gaggle, pulled up, reached for the "flap" handle and spun out of the gaggle with spoilers deployed. UH, hUH! But I won't mention any names :-). I love that story. What you should practice is realistic spin entries from thermaling turns and simulated pattern turns gone bad. Do 'em in all aircraft configurations. In flapped ships the behavior changes quite a lot. If you are fooling with CG location, check that out too. Your responses can and should become fast and accurate. You should do this until you aren't "girding your loins", you aren't tense. No panic. Aircraft departs controlled flight: so what, you deal with it, get it back. regards, Evan Ludeman / T8 |
I have already been flamed once for bringing up this subject in the
original Parowan accident thread, as being irrelevant to highly experienced competition pilots! However for those of them who are not also instructors, that experience consists of many hundreds or thousands of hours of either flying straight or circling in thermals! How well would they cope in the event of a sudden and unexpected upset? It is important to be able to differentiate between a spin and a spiral dive because the recovery actions are quite different. In a spin, the nose will often go well down, despite the fact you are stalled, the ground will rotate in front of you, and there will be very little build up of g. The ASI is likely to totally misread due to the amount of yaw present; it may even go back though zero and show a very high reading. In a spiral dive, the nose may remain fairly well up, despite the fact you are not stalled, and airspeed and g will build up rapidly and continue to do so. In many ways spiral dives are more dangerous as you risk going through Vne and breaking up the glider. Spins in themselves are not dangerous at all, at least as long as you recover before hitting the deck. Just a quick reminder of the standard recovery actions: Spin: 1) Centralise the ailerons 2) Apply full outspin rudder 3) Move the stick steadily and progressively forward until the spin stops 4) Centralise the rudder and ease out of the dive Spiral dive: 1) Keep the stick fairly well back and use the controls normally to reduce the angle of bank - a spiral dive is just a very overbanked turn. IMHO spins and spiral dives should be a part of periodic check flights. Derek Copeland (UK Gliding Instructor) At 04:15 04 July 2009, ZZ wrote: If may, I would like to get off on a bit of a tangent, i.e. the original subject stated in the title of this thread. One of the problems that I have observed with students and a few high time pilots alike is the following: when presented with a spin or a spiral dive, mis-diagnosing the problem and applying the wrong recovery. To some who experience these maneuvers infrequently, they appear similar enough to bring about confusion and as you know, applying the wrong recovery can get grim. I believe airspeed, sound and G are the keys with the latter two very important. Some are so confused by the ground spinning around that they don't think about looking at the airspeed indicator. But they do seem to sense if it is relatively quiet or loud and if they are experiencing more than 1G. A thorough ground briefing on the differences and then demonstrating both on the same flight really helps. Then follow that with a lesson where they must make the diagnosis and apply the proper recovery. This has worked for me. I would enjoy hearing from others who have thoughts on this very important subject. Paul ZZ 8 wrote: Okay guys, here's your new thread. Please... Del asks "how well will pilots react if they unexpectedly get into a spin or a spiral dive? Normally you gird your loins up first before doing a deliberate spin!" Answer: this depends on the pilot, of course. By the time you are gaggle flying, thermaling up off ridges or flying in competition it damned well better be automatic, reflexive. The only point to doing deliberate spins by stalling straight ahead and kicking rudder is to get some sense of how the sailplane behaves and what it takes to recover from a fully developed spin. It might also help you develop some sense of spin entry feel, but unintentional spins normally come from some combination of turning, skidding flight, gusts, etc. Oh, there's also the famous pilot who transitioned from 15m to std class and early on charged into a gaggle, pulled up, reached for the "flap" handle and spun out of the gaggle with spoilers deployed. UH, hUH! But I won't mention any names :-). I love that story. What you should practice is realistic spin entries from thermaling turns and simulated pattern turns gone bad. Do 'em in all aircraft configurations. In flapped ships the behavior changes quite a lot. If you are fooling with CG location, check that out too. Your responses can and should become fast and accurate. You should do this until you aren't "girding your loins", you aren't tense. No panic. Aircraft departs controlled flight: so what, you deal with it, get it back. regards, Evan Ludeman / T8 |
Any Spins Lately?? | Ol Shy & Bashful | Piloting | 28 | September 6th 07 10:22 PM |
Found on another site 08-747 Spiral stairs to lounge 08.jpg (1/2) | Just Plane Noise[_2_] | Aviation Photos | 0 | August 10th 07 02:39 PM |
Found on another site 08-747 Spiral stairs to lounge 08.jpg (2/2) | J.F. | Aviation Photos | 0 | August 10th 07 02:14 PM |
Spiral Dives Explanation. | Sandy Stevenson | Soaring | 6 | August 26th 05 12:34 PM |
Paraglider spiral dive, throws chute and ends up in the trees | Stewart Kissel | Soaring | 8 | March 1st 05 10:04 PM |
