xcsoar
Old July 28th 09, 05:12 AM posted to rec.aviation.soaring
Adam
Default xcsoar
On Jul 26, 1:46*pm, "
just revisited this software in its current version 5.2
Have to say this software has really matured and I was most impressed
with it whilst flying with it yesterday.
I particularly liked the custom terrain and waypoint downloading when
setting it up.
Check outhttp://xcsoar.org
Cheers
Al
I've been using it for 2 years now and like it a lot.
However, with my latest install (5.2.2?) in a newer pocket PC, I
cannot get the wind alorithm to work (ie, perform the calculation and
show me the vector based on circling drift, it always read "0").
Ideas on that??
/Adam
Old July 28th 09, 06:47 AM posted to rec.aviation.soaring
Uncle Fuzzy
Default xcsoar
setting it up.
Cheers
Al
Ideas on that??
/Adam
Page 5 "Glide Computer" ... is you're 'Auto wind' set to "Both"? The
options a
Manual
Circling
ZigZag
Both
Cheers
Old July 28th 09, 08:27 AM posted to rec.aviation.soaring
Bryce
Default xcsoar
setting it up.
Cheers
Al
Ideas on that??
/Adam
Page 5 "Glide Computer" ... is you're 'Auto wind' set to "Both"? *The
options a
Manual
Circling
ZigZag
Both
Cheers- Hide quoted text -
- Show quoted text -
For you guys looking for a cable solution for the PNA's..........Make
one out of a simle car cell phone charger. It steps 12V down to 5V
for most cell phones. For club ships we have a small gel cell comitted
to the PNA that get's moved between gliders.
XCSoar Rocks! I've had it on Ipaq's, a MIO Moov (that got stolen), and
now a teletype 7060 with a 7" screen. I am convinced however that the
HP310 is the way to go, and it's great help to have the PNA on a
ground retrieve too.
We're all looking forward to the OLC problem getting worked out!!
Old July 28th 09, 10:38 AM posted to rec.aviation.soaring
sisu1a
Default xcsoar
one out of a simle car cell phone charger. *It steps 12V down to 5V
Ipaq 31x chargers output 3.3vdc on pins 2 and 3 in addition to 5v and
neg on pins 1 and 5. Failure to feed it that will allow it to continue
draining internal power while in use. USB pins are limited to 500mA
and the 310 eats 700-800mA on full brightness so a standard single pin
5v arrangement is not adequate. The extra voltage kicks it into 'fast
charge mode' and allows it to drink external power while preserving
it's internal battery...
Having a loose gelcell sounds like a potential missile or control
jamming hazard (assuming the club ships do not have a proper battery
box to mount it in...). There are slick/small/cheap and readily
available 5-5.5vdc lithium-ion backup batteries around that even come
with their own chargers and work quite well (get one that can
discharge at 700mA or better for a 31x...) for this purpose. Commonly
the 3500mAh model is used for this, which is smaller than a deck of
cards but provides some 5 hours of power for a 31x on full brightness.
I have a 7200mAh (almost exactly the size of a card deck) unit for
using it outside my own ship which is equipped with a 12Ah 12v SLA
batt to a 5v converter.
All the 31x external battery solutions still require a cord with pins
2 and 3 jumped to the 5v pin, either bridged with the appropriate
resistors (my preference) or resistor network, or even just straight
bridged so they all have 5v (others have told me this is OK for power,
but not communicating data). The stock car charger/cig lighter cord
for the 31x already has this built in of course, should one want to
use 12v batteries and keep life simple (which goes completely against
being a glider pilot , although not as elegant or safe of a solution
for portability as the 5v options using a modded cord...
-Paul
Old July 28th 09, 04:30 PM posted to rec.aviation.soaring
Brian Bange[_2_]
Default xcsoar
To charge my 310, I carefully sawed the end off the car charger, then
soldered on two wires, strain reliefed them with a zip tie and hooked them
to the 12V ships power. The 310 "on" button glows orange for a few
minutes while charging off ships power, then turns green when the internal
battery is charged and the unit starts running off ships power. I was
taking it out of the ship and hooking it to the AC charger after flying,
but found that things worked better if I just left it in the ship. I run
the 310, a radio and a transponder off (2) 7AH lead acid batteries tied in
parallel and generally fly for 5 - 6 hours. So far everything is performing
great. XCSoar is wonderful on the 310.
BTW, we have 2 ClearNav's at my club now. It is the brightest display
that I have ever seen. Standing behind the wing before takoff in bright
sunlight, it was clearly readable. Wow!
Brian
-Paul
Old July 28th 09, 01:34 PM posted to rec.aviation.soaring
Paul Remde
Default xcsoar
Hi,
I sell a very popular cable for connecting a Socket Mobile Power Pack to an
iPAQ 310. You can see details he
http://www.cumulus-soaring.com/godda...mini-USB-Pwr-1
I also sell one for use with the Goddard PS-5a 12V to 5V power converter.
It has also been quite popular.
http://www.cumulus-soaring.com/goddard.htm#I310-PS5a-1
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
"Bryce" wrote in message
On Jul 27, 9:47 pm, Uncle Fuzzy wrote:
On Jul 27, 8:12 pm, Adam wrote:
On Jul 26, 1:46 pm, "
setting it up.
Cheers
Al
Ideas on that??
/Adam
options a
Manual
Circling
ZigZag
Both
HP310 and XCSoar Jim White[_3_] Soaring 2 January 14th 09 07:15 PM
XCSOAR Travis Beach[_2_] Soaring 3 May 24th 08 04:36 PM
XCSoar vs SoarPilot? Frank Soaring 0 December 16th 06 09:07 PM
XCSoar jorgie Soaring 2 November 2nd 04 01:05 AM
XCSoar Robert Danewid Soaring 2 February 7th 04 02:30 PM
