B-2 question
Old August 13th 04, 05:16 AM
Kevin Brooks
"BUFDRVR" wrote in message
Billy Preston wrote:
I don't know if you have access to the numbers on logistics, but if you
compare the B-2 with any other bomber, the costs are phenomenal.
I have seen numbers in relation to $ per flying hour. They were shocking.
But aren't those numbers supposed to be coming down quite a bit courtesy of
the new joint covering process? ISTR reading recently that a big part of the
maintenance load for the B-2 was the excessive manhours and materiel needs
for covering all of the joints and fasteners, and the new method is supposed
to radically reduce this?
Brooks
BUFDRVR
"Stay on the bomb run boys, I'm gonna get those bomb doors open if it
harelips
everyone on Bear Creek"
Old August 13th 04, 04:43 PM
BUFDRVR
I'm not sure if the numbers I saw were before or after the improved LO
maintenance procedures.
Very true, but I've never seen anyone boast about this saving money, just how
it will increase FMC rates and turn around jets more easily.
BUFDRVR
"Stay on the bomb run boys, I'm gonna get those bomb doors open if it harelips
Old August 14th 04, 01:05 AM
BUFDRVR
Leslie Swartz wrote:
But again- you have to know "what goes in to" CPFH and how it is calculated-
and then it isn't so shocking anymore.
Well, I assume what goes in to B-2 flying hour cost also goes in to B-1 and
B-52 flying hour cost. It wasn't the total dollar figure per hour that shocked
me, it was the comparison with the other 2 bombers and particularly with the
B-52. Damn we're a bargain!
BUFDRVR
Old August 14th 04, 03:07 PM
David Lentz
calculated-
and
shocked
BUFDRVR
harelips
Update me. The figure that kept getting beat into my head, back in my RBS
days and every time we missed an aircraft, was eight thousand dollars an
hour. Now don't ask how the figure was determined. It just the figure
which was preached over and over. So what is the current figure?
David
Old August 14th 04, 06:15 PM
BUFDRVR
hour.
Hmm, I'll have to find the data because I thought BUFFs were the only bomber in
single digit thousands of dollars/hour???
BUFDRVR
Old August 14th 04, 08:31 PM
Billy Preston
"hobo" wrote
The only reason any B-2s were built at all is because the way the
contracts were structured it would have cost just as much to build 21 as
to build zero. No more will be built because they are too expensive to
build and operate.
Actually, they were built, because the B-1 and B-52 could no longer
penetrate the Moscow defenses. The B-2 was part of Reagan's
bankrupt the Soviets policy. 21 was the number that wouldn't
bankrupt us.
Having worked on the B-2A for 10 years now, I can say it fulfilled
its designed roll, but technology has caught-up with other bombers.
The B-2 was the only plane that could drop the big bridge in Serbia.
It did that with 4 JDAM's hitting the bridge at the same instant. The
B-1 and B-52 didn't have them. Now that they do, the supremacy
of the B-2 is merely stealth. With unmanned bombers, stealth becomes
an option we can do without. Even C-17's can perform the role of
most B-52's that drop cruise missiles from outside the FEBA, and
sometimes outside the theater.
The B-2 should be rounded-up and moved to DM. I work on them,
and I can say without reservation (along with my co-workers), that
the plane will never have an FMC rate that is worth the expense. The
plane is a welfare program for the Northrop conglomerate.
Old August 14th 04, 09:52 PM
Kevin Brooks
"Billy Preston" wrote in message
news:KMtTc.984$ni.679@okepread01...
snip
But we ain't there yet, and won't be for at least a few more years (it has
been hoped to get a baseline UCAV to the USAF *starting* around 2007, but
that may in the end be a bit optimistic). Until such time that we have a
credible, reliable UCAV capability that can match the striking power of the
B-2, I'd just as soon keep that club in my bag--and right now, there is NO
realistic plan to acheive that (being as the B-2 can heft the really big
stuff like the GAM-36 (or is it 37?) that is WAY outside the carrying
capability of the UCAV's under consideration). If you have to go deep, into
denied airspace, against a reasonably hardened target, your UCAV might as
well sit on the tarmac, while the B-2 does the job. Then there is the issue
of range...the UCAV's under development in the near term are not exactly
really long haulers...
Not really. To nitpick, the term you are grasping for there is "FLOT"
(Forward Line Own Troops), not "FEBA" (Forward Edge Battle Area); things can
still get pretty hairy on our side of the FEBA (which can be used to
describe the *limit* of major ground force operations, not necessarily where
they have already secured).
Why don't we wait on that move until after the systems that would replace
their unique capabilities are actually in service, as opposed to being
"vaporware" as they are now?
Brooks
Old August 14th 04, 11:23 PM
Pooh Bear
to build zero.
Defence contractors need an assurance that they'll get loadsa money for
their efforts.
For the government, they need to see some hardware in return.
Graham
Old August 14th 04, 11:26 PM
Pooh Bear
The B-2 was part of Reagan's bankrupt the Soviets policy.
As were the cruise missiles stationed in the UK.
It worked.
Was Reagan actually clever enought to work it out or was it a long running
Pentagon ruse to bankrupt the Soviets by outsmarting them with technology ?
Graham
GPT (Gulfport MS) ILS 14 question A Lieberman Instrument Flight Rules 18 January 30th 05 04:51 PM
Tecumseh Engine Mounting Question jlauer Home Built 7 November 16th 03 01:51 AM
T Tail question Paul Austin Military Aviation 7 September 23rd 03 06:05 PM
