#191
Either that or I'm paying for fuel and
merely imagining I go to work :-) Maybe you're imagining that you're getting something done. g,d,rlh Jose -- Money: what you need when you run out of brains. for Email, make the obvious change in the address. |
#192
You're right that pressure itself is a momentum change, but that
doesn't appear to be what the momentum change advocates are, ah, advocating. They (and I too) are talking about local effects. It's fine to say no =net= downard motion, of course there is no net downward motion - the earth gets in the way, and the increasing pressure pushes the air back up. Suppose the earth wasn't really there... we have an infinite field of air in all directions, and no gravity. A airplane comes through. It will (at the proper AOA) experience lift, and will accelerate upwards (upwards being defined wrt the wings on a cessna, downwards being defined wrt the wings on a piper). Newton requires that air be accelerated downwards. If we introduce plane gravity (that is, gravity that magically only attracts airplanes and leaves air molecules alone), then this gravity will pull the airplane down, and will prevent it from accelerating upwards. However, air will still have to be accelerated downwards to keep the airplane from succumbing to gravity. There will be localized high pressure below the wing, and localized low pressure above the wing, and there will be a vortex as the air rushes around the wingtips, but the air that is accelerated downwards will not have anything to stop it (except other air, which molecule by molecule accepts the transfer of momentum). If we let gravity work on the air molecules too, then there will also be a gravitationally induced acceleration of air downwards, since there is nothing to stop it. The air will be in free fall (and pretty soon the airplane will not be able to keep up). It's only when you put the earth itself in the picture that it all comes together. With a hard surface below the air, (momentum from) molecules that have been "thrown down" by the wing will get transferred to the earth, and the air molecules will bounce back upwards again. THIS causes the pressure that feeds the upwash (and helps keep the earth from accelerating upwards towards the airplane). If we let the system stabilize, the air molecules will pile up near the earth, and be sparser further up. However, the pressure change below the wing isn't downwash. If there is a technical meaning to that word, I am not using it that way. Jose -- Money: what you need when you run out of brains. for Email, make the obvious change in the address. |
#193
Remember, Time flies like an arrow...
Fruit Flies Like a Banana... Al "JJS" jschneider@remove socks cebridge.net wrote in message ... "Jose" wrote in message t... snip Feathers are not magical, they operate by strict scientific principles and an insufficient amount of feathers won't even make a fruit fly. snip Fruit flies have feathers? ----== Posted via Newsfeeds.Com - Unlimited-Unrestricted-Secure Usenet News==---- http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups ----= East and West-Coast Server Farms - Total Privacy via Encryption =---- |
#194
Al wrote:
Remember, Time flies like an arrow... Fruit Flies Like a Banana... Grouch Marx! |
#195
![]() Bryan Martin wrote: I don't know if it was the first time, but it happened once back in the early '80s in, I think, Arizona. I believe it was a PSA DC-9. A disgruntled ex-employee snuck a gun on board and forced his way into the cockpit and shot the flight crew and then dove the plane into the ground. Of course in that case the hijacker had a real weapon and about the only thing that might have stopped him was someone else with a gun. Then of course there is the case of the FedEx DC-10 where the crew barely managed to prevent a nut case soon to be ex-employee from doing the same. The 9-11 hijackers weren't even armed. No mater what anybody says, a box cutter is not a weapon. I am not disagreeing with the other stuff you wrote but a box cutter is indeed a very dangerous weapon in the wrong hands and you could easily kill a person with one swing, not to mention multiple attacks. I wonder, if 911 was an inside job and nobody takes box cutters seriously, why wouldn't the perpetrators plant other weapons in the planes so the story would be more believable? |
#196
![]() Jose wrote: You're right that pressure itself is a momentum change, but that doesn't appear to be what the momentum change advocates are, ah, advocating. Wrong. Momentum change is momentum. The time rate of momentum change is Force. Neither is pressure. They (and I too) are talking about local effects. It's fine to say no =net= downard motion, of course there is no net downward motion - the earth gets in the way, and the increasing pressure pushes the air back up. Suppose the earth wasn't really there... we have an infinite field of air in all directions, and no gravity. A airplane comes through. It will (at the proper AOA) experience lift, and will accelerate upwards (upwards being defined wrt the wings on a cessna, downwards being defined wrt the wings on a piper). Newton requires that air be accelerated downwards. Why does Newton require that air be accelerated downwards? If we introduce plane gravity (that is, gravity that magically only attracts airplanes and leaves air molecules alone), then this gravity will pull the airplane down, and will prevent it from accelerating upwards. However, air will still have to be accelerated downwards to keep the airplane from succumbing to gravity. There will be localized high pressure below the wing, and localized low pressure above the wing, and there will be a vortex as the air rushes around the wingtips, but the air that is accelerated downwards will not have anything to stop it (except other air, which molecule by molecule accepts the transfer of momentum). If we let gravity work on the air molecules too, then there will also be a gravitationally induced acceleration of air downwards, since there is nothing to stop it. The air will be in free fall (and pretty soon the airplane will not be able to keep up). It's only when you put the earth itself in the picture that it all comes together. With a hard surface below the air, (momentum from) molecules that have been "thrown down" by the wing will get transferred to the earth, and the air molecules will bounce back upwards again. THIS causes the pressure that feeds the upwash (and helps keep the earth from accelerating upwards towards the airplane). If we let the system stabilize, the air molecules will pile up near the earth, and be sparser further up. What color is the sky on your planet? However, the pressure change below the wing isn't downwash. If there is a technical meaning to that word, I am not using it that way. OK. -- FF |
#197
change is Force. Neither is pressure. What I wrote (or intended to write) is that pressure is manifested by many momentum changes. Each molecule that collides with a wall transfers momentum to that wall, and the net force caused by all those momentum changes (over time) manifests itself as pressure, (which is force divided by area). The essential point is that pressure arises from momentum transfer on a molecular level. Why does Newton require that air be accelerated downwards? To counterbalance the wing being accelerated upwards due to lift. The wing is at an AOA which generates lift. If we let the system stabilize, the air molecules will pile up near the earth, and be sparser further up. What color is the sky on your planet? Blue. Why? Do you not concur with the observation that on Earth the air is denser near the ground, and less dense at higher altitudes? Gravity is what holds the earth's atmosphere in place. Jose -- Money: what you need when you run out of brains. for Email, make the obvious change in the address. |
#198
#199
Bryan Martin wrote:
Bryan, Ex-nay! Or wander over to alt.politics to feed the loons... I brought up this whole Bernouli mess just to get rid of these guys. It worked quite well. Now don't screw it up again! Richard |
#200
Richard Lamb wrote:
Bryan Martin wrote: Bryan, Ex-nay! Or wander over to alt.politics to feed the loons... I brought up this whole Bernouli mess just to get rid of these guys. It worked quite well. Now don't screw it up again! Richard Isn't a Bernouli what an Arab wears? Dan, U.S. Air Force, retired |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 02:26 PM |
GAO: Electronic Warfa Comprehensive Strategy Needed for Suppressing Enemy | Mike | Naval Aviation | 0 | December 27th 05 06:23 PM |
Washington DC airspace closing for good? | tony roberts | Piloting | 153 | August 11th 05 12:56 AM |
Sport Pilot pilots not insurable? | Blueskies | Piloting | 14 | July 12th 05 05:45 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
