#201
"Paul J. Adam" wrote:
In message , Kevin Brooks writes Plus it never ceases to amaze me the number of folks who think that (a) bringing in enough aluminum matting (and we don't use PSP anymore) to build a fighter strip is a piece of cake (and trying to support a C-5 on one is a mean proposition), (b) installing the matting is all there is to it (no cut/fill, drainage work, or subbabse and base course prep required), getting the requisite engineer equipment and units into the site is an easy matter, and (d) this will all happen over a matter of a day or two. Laying in a fighter-length strip from scaratch is a *major* engineer operation, and quite different from that required to construct a minimum length rough field C-130 strip. Compare this with the effort needed to create HMS Sheathbill in the Falklands (which was a basic "land, refuel, leave or GLI" strip). Uh-huh. Minimum size for a C-130 capable airstrip is considered to be 3,000' x 60'. AM-2 weighs 140 lb. for a 12' x 2' strip, not counting attachments and holddowns. HMS Sheathbill was relatively convenient, being almost right on the shoreline. It was recce'd by the head of the Engineer Squadron on D+1 (he'd also examined an old Auster strip at San Carlos settlement, but it was too soft for Harriers even with AM-2), the 11,000 AM-2 planks needed were unloaded from RFA Stromness beginning on D+2, and it was finished on D+12. It was only 860 feet long with two VL pads and a parking/fueling loop for 4 a/c, and fuel bladders both on shore and floating in San Carlos Water, topped up from the RFAs (the rest of the AM-2 matting to expand the runway/parking area, as well as much a/c spares etc. went down in Atlantic Conveyor). It's *much* easier to pick a stretch of highway, fly in fuel bladders and maybe ordnance & first-line servicing - than to build a fixed-wing CTOL strip from scratch (lots of supplies and equipment needed just to build the runway before anything else arrives) To be precise, quoting now from the MEF Planning Manual Staff Planning Factors: ----------------------------------------------------------------------- "Expeditionary Airfield (EAF). The EAF consists of two hundred and eighty containers of equipment and provides the capability to build a notional EAf 2000. This capability is designated to include: 96 foot wide by 3,850 ft. long runway, 75 parking spaces for tactical aircraft, 3 parking spaces for tactical aircraft, fueling area and revetments, airfield lighting and visual landing aids, and arrester gear. The EAF is normally spread to three ships in the [pre-positioning] squadron in three modules, which support the following: "Ship 1: 471,683 SQFT. Parking, R/W [Guy: Rotary wing] Fuel Pit, Runway to support 18 CH-53s, 18 MV-22s/CH-46s, 24 A/UH-1s. "Ship 2: 445,000 SQFT. Parking, R/W Fuel Pit, Runway to support 12 CH-53s, 12 MV-22s/CH-46s, 12 A/UH-1s. "Ship 3: 445,000 SQFT. Parking, F/W [Fixed-wing] Fuel Pit, Runway to support 20 AV-8Bs, 14 F-18. "Any reduction in the equipment identified will result in an equivalent reduction in capability (e.g. shorter/narrower runway, less parking, or no arrester gear). Three ships together can be configured to support C-5 aircraft." ----------------------------------------------------------------------- Going all-STOVL a/c means no need for arrester gear. It took the brits a couple of weeks to install arrester gear at Port Stanley airfield in the immediate aftermath of the war, owing to the mud, lack of drainage, and cold weather. And how long does it take to put a FARP/FOB together, if they have to lay a runway? Let's take a representative example, one for AV-8Bs: ------------------------------------------------------------------------- 72' x 960' runway with 2 integral 96' x 96' VTOL pads. Parking hides for 11 AV-8B (designed for 32' x 56'). Net explosive weight of 3,000 lb. considered for each a/c. Subgrade prepared to a minimum of CBR 25. Requires (1 each) F70 - Field Tool Kit (267 pieces) F71 - 12' AM2 Mat (267) pieces F72 - 6' AM2 Mat. (6 sets) Anchors and Accessories (6 sets) F77 - H-connectors Site preparation: A crew of 15 working 10 hrs per day can complete in 5 days with: 2 graders 2 dump trucks 2 compactors 1 D7 dozer 2 TRAMs w/buckets 3 6-10k forklifts Installation: A crew of 36 working 10 hrs a day can complete in 3 days. Note: The EAF concept allows for an infinite number of configurations. The three configurations used in this table [I've left out the other two] do not represent any standard airfield configuration. There is no standard EAF configuration. Per the AM-2 Tech Manual, a 16 man crew can install 3,300 ft.^2 per hour. --------------------------------------------------------------------- You could go somehat narrower for a FARP and do without the hides, but needless to say laying down a runway and parking pads boosts the logistic and time burden, which is why you don't want to do it if you don't have to. This is one reason why the Marines are looking at a V/STOL transport with the load capability of a C-130. The USMC's AV-8Bs did this to very good effect in 1991, for instance. Using a helicopter airfield with a 6,000 foot runway in very poor repair, about half of which was usable. They also operated from poor condition forward airfields in Iraq this past year, with fuel, weapons and sparesapparently brought in mostly by truck. Guy |
#202
#203
Guy Alcala wrote:
snip To be precise, quoting now from the MEF Planning Manual Staff Planning Factors: ----------------------------------------------------------------------- "Expeditionary Airfield (EAF). The EAF consists of two hundred and eighty containers of equipment and provides the capability to build a notional EAf 2000. This capability is designated to include: 96 foot wide by 3,850 ft. long runway, 75 parking spaces for tactical aircraft, 3 parking spaces for tactical aircraft, That last should read "3 parking spaces for transport aircraft". Guy |
#204
#205
Pooh Bear wrote in message
... JL Grasso wrote: On Fri, 27 Feb 2004 10:43:07 -0800, "Tarver Engineering" wrote: The A-320 which crashed into the trees in France was performing a fly-by demonstration, by a line pilot, not an Airbus test or demo pilot. The profile was to fly by at 500 feet. The pilot was making a scheduled revenue flight with passengers and came up with the low slow fly by all on his own. Actually, it was a charter flight. And not to split hairs, but the low/slow fly-by was discussed by airline officials and both captains in a prior briefing that day. The accident was officially caused by descent below obstacle height combined with a delayed application of TOGA power to exit the fly-by. The F.O. was also declared mentally ill for demurring from the above 'explanation'. You are aware that the DFDR presented in court to substantiate the official story was NOT the DFDR from the crashed aircraft, yes? Paul Nixon |
#206
JL Grasso wrote:
So you're telling us that autothrottle won't work below 100 ft and to get TOGA below 100 ft you must apply it manually?... No. I am saying that if you are at 100 feet AGL, 122 KIAS, 15 degrees nose up, sinking at 600 FPM, engines at 29% N2, apply TOGA power and then strike the trees 5 seconds later, you obviously applied it too late, eh. The engines responded as they should have and autothrottles had nothing at all to do with the accident. So (to use your methods here), you're telling me that there was absolutely noting wrong with the configuration that the crew put that aircraft in? Jerry No Jerry, I'm not...on rereading my post it did sound confrontational, sorry. I was looking for info there and you seem to have a good handle on the incident. -- -Gord. |
#207
#208
![]() "Gord Beaman" wrote in message ... (John Alger) wrote: The crew expected it, but it was not there becaue they were too low. When he realized his error, the captain manually applied TOGA power. This absolutely floors me...WHY wouldn't he intimately KNOW this?...I find it almost unbelievable that he wouldn't. What was the cojo doing all this while?...had they never heard of CRM over there?... -- The CVR transcript is on line at http://aviation-safety.net/cvr/cvr_acf296.shtml Keith |
#209
"Tarver Engineering" wrote in message ...
The pilot was past the end of the runway by then and into an unmapped part of the A-320's flight control system. bwahahahhahahahhahhahahhhahahhahhahahahahahhahahah ahahahahahahha every ****ing aircraft goes past the end of a runway. its called takeoff |
#210
"John Alger" wrote in message m... "John R Weiss" wrote in message news:S08%b.58709$4o.76896@attbi_s52... "Tarver Engineering" wrote... Since my servers seldom get me all the newsgroup messages and Google.groups can't seem to find the begining of this thread, please allow me to ask a question and pose some answers. And I apologize if any of this has been discussed previously. From the bits I have read subsequent to John's message above, I assume we are discussing the A-320 crash at Habshiem. If so, let me present some information relevant to the discussion, as I have not read anything as yet that indicates any of the posters knows much if anything about Airbus flight control systems. I do believe I am qualified to speak on the subject as I teach A-330 systems, which has a flight control system identical to the A-320. The A-320 which crashed into the trees in France was performing a fly-by demonstration, by a line pilot, not an Airbus test or demo pilot. The profile was to fly by at 500 feet. The pilot was making a scheduled revenue flight with passengers and came up with the low slow fly by all on his own. nope. it was a revenue flight. though the pilot was requested to do the low fly past by AF. |
Replace fabric with glass | Ernest Christley | Home Built | 38 | April 17th 04 11:37 AM |
Why not use the F-22 to replace the F/A-18 and F-14? | Guy Alcala | Military Aviation | 265 | March 7th 04 09:28 AM |
Why not use the F-22 to replace the F/A-18 and F-14? | Guy Alcala | Naval Aviation | 2 | February 22nd 04 06:22 AM |
RAN to get new LSD class vessel to replace 5 logistic vessels ... | Aerophotos | Military Aviation | 10 | November 3rd 03 11:49 PM |
Air Force to replace enlisted historians with civilians | Otis Willie | Military Aviation | 1 | October 22nd 03 09:41 AM |
