#201
#202
Bertie the Bunyip writes:
And if you find everyone so tedious, why stay? I don't find everyone here tedious. There are lots of stupid people in the world, but that doesn't mean I should write off the entire species. I have a lot of patience. |
#203
#204
On Jun 16, 12:46 pm, Mxsmanic wrote:
writes: The intitial velocity limitation says 'vertical'. I don't care what size the 'walnut' is, it will be impacted given there was no horizontal velocity component. There is always a horizontal component, although one isn't really necessary. Even if there was, by the way, the Newtonian physics demand the path will cross the starting point, and the implication to most readers would be that was on a surface. If there's a surface in the way, the starting point and ending point will be different. Care to write an equation or two to demonstrate that? It's a two body problem, one massive with respect to the other. The initial conditions are a vertical impulse from the surface, of a massive sphere. That's high school physics. |
#205
In rec.aviation.piloting Mxsmanic wrote:
El Maximo writes: It's called orbital velocity http://electronics.howstuffworks.com/satellite3.htm Any object following a ballistic trajectory (disregarding aerodynamic effects) is in orbit. Stardate 1369.000001 The starship Redundant has just come out of warp and is approaching Fjukktard IV. On the bridge... Captain: Helmsman, assume a standard orbit around the planet. Helmsman: Aye, Aye, sir. (Sounds of engines adjusting) Captain: Tactical! We're heading straight for the planet! Have the inhabitants locked on to us with some sort of tractor beam? Tactical: Negative sir, Helmsman Mxsamanic has put us on a collision course with the planet. Captain: Mr Mxsmanic, what the hell is going on? Helmsman: Well, sir, you said assume an orbit and any object following a ballistic trajectory (disregarding aerodynamic effects) is in orbit, so I... (Anything further from Mr Mxsmanic is unintelligible as the Captain has both hands firmly around his neck) Captain: Navigator, take the helm and put us in a real orbit! Security, throw Mr Mxsmanic out off the nearest airlock! -- Jim Pennino Remove .spam.sux to reply. |
#206
Why would you want to throw Mx from an airlock? If you did it after
adjusting the orbit, he'd contribute to space junk after getting his black belt in Internet Pest. The airlock idea for storage is a good idea though. Don't do a bleed to space, that would mess up the insides of the airlock as badly as the insides of some microwave ovens. On Jun 16, 3:05 pm, wrote: In rec.aviation.piloting Mxsmanic wrote: El Maximo writes: It's called orbital velocity http://electronics.howstuffworks.com/satellite3.htm Any object following a ballistic trajectory (disregarding aerodynamic effects) is in orbit. Stardate 1369.000001 The starship Redundant has just come out of warp and is approaching Fjukktard IV. On the bridge... Captain: Helmsman, assume a standard orbit around the planet. Helmsman: Aye, Aye, sir. (Sounds of engines adjusting) Captain: Tactical! We're heading straight for the planet! Have the inhabitants locked on to us with some sort of tractor beam? Tactical: Negative sir, Helmsman Mxsamanic has put us on a collision course with the planet. Captain: Mr Mxsmanic, what the hell is going on? Helmsman: Well, sir, you said assume an orbit and any object following a ballistic trajectory (disregarding aerodynamic effects) is in orbit, so I... (Anything further from Mr Mxsmanic is unintelligible as the Captain has both hands firmly around his neck) Captain: Navigator, take the helm and put us in a real orbit! Security, throw Mr Mxsmanic out off the nearest airlock! -- Jim Pennino Remove .spam.sux to reply. |
#207
"Mxsmanic" wrote in message
... El Maximo writes: I'm sure there are enough definitions of orbit for you to choose from that you wouldn't bother learning, only arguing. In other words, I am not in error. No, in other words, you do not understand. |
#208
#209
#210
Read the post -- it specified vertical. It may be your concept of
vertical is different than the one commonly accepted. If your throw was vertical you had aerodynamic effects, disallowed earlier in your earlier post. I would have suspected you did finish high school some time ago. That you have forgotten what you learned is obvious. On Jun 16, 4:16 pm, Mxsmanic wrote: writes: Care to write an equation or two to demonstrate that? You need an equation? I throw a baseball into the air. It lands twenty feet away. The starting point and ending point are different. It's a two body problem, one massive with respect to the other. The initial conditions are a vertical impulse from the surface, of a massive sphere. That's high school physics. I finished high school a long time ago. |
Dispelling the Myth: Hillary Clinton and the Purple Heart | Otis Willie | Naval Aviation | 0 | February 21st 06 05:41 AM |
Impossible to ditch in a field (almost) | mindenpilot | Piloting | 29 | December 11th 04 11:45 PM |
bush: impossible to be AWOL (do vets give a sh!t) | B2431 | Military Aviation | 7 | September 8th 04 04:20 PM |
cheap, durable, homebuilt aircrafts- myth or truth? | -=:|SAJAN|:=- | Home Built | 27 | January 8th 04 09:05 AM |
The myth that won't die. | Roger Long | Piloting | 7 | December 19th 03 06:15 PM |
