IFR use of handheld GPS
Old May 11th 06, 07:43 PM posted to rec.aviation.ifr
Default IFR use of handheld GPS
"Sam Spade" wrote in message
news:OlJ8g.176145$bm6.85233@fed1read04...
I never said it governs tracking of airways. It does govern the ground
facilities you must use to track the airway; i.e., from "VOR ABC to VOR
DEF." Apparently, you don't understand that.
Apparently you don't understand those ground facilities are also outside the
subject of discussion.
That is your statement of opinion, which is not shared by everyone,
including those at the FAA who control this stuff.
Saying there are no regulations that prohibit the use of a non-certified GPS
in IFR flight is a statement of fact, not of opinion. That there are some
in the FAA that don't understand that fact should surprise nobody.
  #222
Old May 11th 06, 08:41 PM posted to rec.aviation.ifr
It is your opinion.
  #223
Old May 11th 06, 08:53 PM posted to rec.aviation.ifr
news:hrM8g.176161$bm6.112176@fed1read04...
It is your opinion.
Clearly you cannot differentiate fact from opinion.
  #224
Old May 12th 06, 01:51 AM posted to rec.aviation.ifr
It is your opinion.
Oh, I think it is you who cannot.
Do you have any experience with civil legal proceedings?
Such as,
findings of facts, and conclusions of law.
Clearly, your assertions of fact do not rise to the level of civil
adjudication by a court of compentent jurisdiction, although I will
never be able to convince you of that FACT.
  #225
Old May 12th 06, 04:03 AM posted to rec.aviation.ifr
Ok. We agree that Part 95 does not govern tracking airways.
It also does not govern the ground facitilities that must be used to track
airways. The only thing Part 95 does is refer to the airways and that is
only to allow the use of GPS in areas when it is impossible to use VORs to
track the airways.
I'm still missing the part where a regulation requires me to use a certified
GPS.
As a few examples of clarity, 91.181 requires that, during IFR flight, I fly
(a) on a airway or (b) a straight line to a fix. Note that it does not
stipulate the equipment I must use to accomplish that.
91.171 prohibits IFR navigation by reference to a VOR receiver unless it has
been checked.
91.205 requires that I have the appropriate equipment for the ground
facilities to be used.
The point that many people are trying to make in this discussion is that
there is no similarly explicit statement about using certified GPS receivers
for enroute navigation.
You have stated that this is only an opinion. Actually, it is not an
opinion. It is an observation that has yet to be refuted.
Please understand that I am only debating the explicit regulation to use
certified GPS receivers. It is fact only in that no one has been able to
cite a regulation to the contrary. You have stated an opinion that GPS
receivers must be certified for IFR enroute navigation but you have not
cited a regulation to back up that opinion.
Travis
Lake N3094P
PWK
Travis Marlatte wrote:
As you say, part 95 governs IFR altitudes - not tracking airways. It does
not define airways nor how to track them. It defines altitudes to be used
when on and off airways.
Part 95 is irrelevant to the discussion at hand. There are no regulations
that prohibit the use of a non-certified GPS in IFR flight.
  #226
Old May 12th 06, 04:32 AM posted to rec.aviation.ifr
news:z_Q8g.176186$bm6.58825@fed1read04...
I'm sure you do. You're wrong.
  #227
Old May 12th 06, 10:13 AM posted to rec.aviation.ifr
Interesting thast you chose to ignore the bulk of my post.
  #228
Old May 12th 06, 10:21 AM posted to rec.aviation.ifr
track the airways.
That is simply incorrect. Airways are described in great detail on
individual Forms 8260.16, which include the VOR stations, the IFR
altitudes, and the COPs. Each such amendment to an airway is an
amendment to Part 95, which is incorporated into the regulation through
the federal register by reference. This is virtually the same
rule-making procedure used to enact and amend instrument approach
procedures under Part 95.
GPS.
been checked.
And, what constitutes a VOR (Victor) Airway.
It is a body of TSO, ACs, and FAA policy postions. The FAA would never
feel the need to issue a regulation that states VFR GPS cannot be used
for IFR navigation. They see no reason for it, since the body of
directives make it clear that only IFR certified avionics can be used
for IFR operations.
  #229
Old May 12th 06, 02:22 PM posted to rec.aviation.ifr
Are the forms 8260.16 available to the public somewhere?
Dave
  #230
Old May 12th 06, 04:46 PM posted to rec.aviation.ifr
Google is your friend!
Damn, that's empowering to say!!
Karl
ATP CFI EC
"Curator" N185KG
"Dave Butler" wrote in message
news:1147439954.376983@sj-nntpcache-5...
Sam Spade wrote:
Airways are described in great detail on individual Forms 8260.16,
Dave
HANDHELD RADIO [email protected] Soaring 22 March 17th 16 03:16 PM
Navcom - handheld VS panel ? [email protected] Home Built 10 October 31st 05 08:08 PM
GPS Handheld Kai Glaesner Instrument Flight Rules 2 November 16th 04 04:01 PM
Upgrade handheld GPS, or save for panel mount? [email protected] Owning 7 March 8th 04 03:33 PM
Ext antenna connection for handheld radio Ray Andraka Owning 7 March 5th 04 01:10 PM
