#231
On Apr 17, 11:06 am, Mxsmanic wrote:
In a turn, a portion of the lift produced by the wings must be used to accelerate the aircraft laterally, and this portion of the lift is no longer available to maintain the aircraft's altitude. Thus, without any adjustment of pitch or power to compensate, any turn will result in a loss of altitude. All pilots know this and assume that a "turn" includes compensation, unless they specifically say "descending" or "climbing". So when you keep saying "a turn will always descend", you just confuse your readers... especially the ones who don't follow threads closely. You're in a pilot newsgroup, which means the prevailing terminology is that of pilots, not necessarily engineers, civilians, or whomever. Kev |
#232
Just spoke to a friend with 26,000 hours. He confirmed that DC-8 and 707
heavies certainly do get a bump as they fly through their own wake during a 360 degree constant altitude turn. He also said that some Category D simulators include the effect in their motion repertoire. Rip Kev wrote: On Apr 16, 10:22 am, Jose wrote: My wake _should_ descend about 150' during that time (300 fpm). I can't imagine a C172 wake being tall enough to stay in my way... I can. 150 feet is not tall at all for a wake. Remember, the air around the wake is also being dragged by the wake vortex. Hmm. We're going to have to define a wake, methinks. I can't find anything about body wakes, for example. Do they give much of a bump? Glider pilots, are you listening? On the other hand, wingtip vortices are a well-researched topic, and if a Boeing 727's is only 9' in radius, it would be hard to imagine a vortex being more than 5 feet in radius for a C172, if that much. Even if larger, and sinking very slowly, it should still be 50-150' below the aircraft if the other parameters (altitude, wind) are static. Regards, Kev |
#233
In rec.aviation.piloting Mxsmanic wrote:
Thomas Borchert writes: Can't follow you there. That's as useful a statement as "airplanes tend to be stationary objects..." In a turn, a portion of the lift produced by the wings must be used to accelerate the aircraft laterally, and this portion of the lift is no longer available to maintain the aircraft's altitude. Thus, without any adjustment of pitch or power to compensate, any turn will result in a loss of altitude. Yet another true but worthless statement. One of the first things real pilots are taught in real training in real airplanes is how to maintain a constant altitude in a turn. Ergo any real turns by real airplanes will be constant altitude unless the PILOT has a reason to do otherwise. Since most 360 turns are done as practice to establish and maintain the skill, most 360 turns will be at a constant altitude +/- 100 feet. -- Jim Pennino Remove .spam.sux to reply. |
#234
writes: If air truely behaved like an incompressilble fluid at low air speeds, it would be difficult, if not impossible, to breathe while jogging. It's possible to breathe water, which is indeed incompressible for all practical purposes. And yet another factoid that is only applicable under a very contrained set of circumstances you are trying to arm wave into a generallity to prove yourself correct. And no, it is not possible to breathe water, you can only breathe gases, if you want to be pendantically, semantically correct. -- Jim Pennino Remove .spam.sux to reply. |
#235
Yes, they do. I just asked a friend with 26,000 hours. He confirmed that
DC-8's and 707's do get a bump as they cross their own wake in a 360 degree constant altitude turn. He also said that some Category D simulators include this effect in their motion repertoire. Rip Tom L. wrote: On 16 Apr 2007 06:37:13 -0700, "Kev" wrote: On Apr 14, 4:27 pm, "george" wrote: I always maintained altitude and rate of turn in steep turns with the end result being hitting my own slipstream. As have we all on nice days, and students like to brag about it. Yet Mx is correct, in theory we should not be able to do this. I seem to recall recent magazine (web?) articles where the idea that you can hit your own wake while actually holding altitude, should be downplayed nowadays. You _have_ to descend a little bit to do so, which means that, while you might be within the +/- 100' test scenario, you are NOT holding the same exact altitude. Hmm. Or else it means that the wake doesn't necessarily descend as we're taught. On a warm clear day (which is when I've hit my own wake), I betcha that the wake is being held upward a tiny bit by the heat from the ground. Cheers, Kev The big question is "why does the wake turbulence descend?" Is the air volume inside the vortices denser than surrounding air? Probably not. So the descent is probably not due to gravitational force. I am no expert on fluid dynamics and have no access to texts that answer the question (if there are any), but figure 7-3-5 in AIM is interesting - it shows a wake sinking at several hundred fpm immediately after an aircraft, but than stabilizing at several hunderd feet below the flightpath, i.e. no further sink. This might indicate that the sink is due to wing downwash. If that is the case, than 1. Wake turbulence in steep turns will not move just downward, but down and out, that is: opposite lift. 2. The speed at which it moves will depend on downwash - it's speed, intensity, strength (?) I don't know which term would be appropriate here. Whatever it is, it might be much smaller for GA aircraft than for large aircraft. It would be interesting to do the following flight test: On a nice day (meaning: perfectly still air) fly turns at different bank angles and speeds and note when you do and don't experience the bump at the end of the turn. Do this in different aircraft - low/high wing, small/large/... Does anyone know whether big aircraft experience the bump at the conclusion of their steep 360s? - Tom |
#236
Anthony, you've got the issue of compressibility precisely backwards. No
surprise. Rip Mxsmanic wrote: Rip writes: I don't know, but I'm going to find out! I can envision an aircraft with light wing loading, like a Cessna for instance, compressing the air locally as it creates lift. After passage of the wing, the lift created downwash would rebound upward, kind of like skipping a stone on the water. Virtually no compression occurs at the speeds of a Cessna. Compression is only an issue at high speeds. At low speeds, air behaves very much like an imcompressible fluid. The end result is that the downwash stays at a constant altitude, or sinks MUCH more slowly than theory would indicate. The downwash does not stay at a constant altitude. It sinks. It has to, otherwise the aircraft couldn't stay in the air. |
#237
Anthony, my boy, your interpretation is incorrect. At Mach, the air has
compressed as much as it can, which is why it takes so much energy to force a solid object through Mach. You have the concepts reversed in your head. Rip Mxsmanic wrote: writes: Did you use Microsoft Air Simulator to do this? You haven't answered my question. OK, now wave your hand through a real fluid, I'd suggest water. Did it feel the same as waving your hand through air? If you look in books on aerodynamics, you'll find that air is effectively an incompressible fluid at low speeds, such as those encountered in small aircraft. It isn't until you get to the transonic range that compression starts to be an issue, and the rules change substantially at and beyond the speed of sound. |
#238
And it's darned difficult, just like the man said.
Hey, here's an idea, why don't you go get us some empirical data from personal experimentation, and then get back to us with some actual information! Rip Mxsmanic wrote: writes: If air truely behaved like an incompressilble fluid at low air speeds, it would be difficult, if not impossible, to breathe while jogging. It's possible to breathe water, which is indeed incompressible for all practical purposes. |
#239
writes: Air does not behave very much like an imcompressible fluid at low air speeds. Not even close. That's not what the engineers say. I am an engineer and have the degree to prove it and I totally agree with him, so stuff it. Under some conditions, low air speeds is one of them, air can be treated like it is an imcompressible fluid. The difference between TAS and EAS is only about 13% even at Mach 1. Since small aircraft come nowhere near to Mach 1, for all practical purposes air is incompressible for most calculations. Word salad that shows you don't get the concept. At low airspeed, the equations for incompressible fluid flow are close enough to what actually happens that they can be used for practical calculations. This does not mean that air "acts like an incompressible fluid" in any way, shape, or form. Obviously air, being a gas, can be compressed, but taking that into account at low speeds greatly complicates the calculations, and the final result isn't significantly different. Finally, the light comes on... Well, gee-whiz, you backed into a place where you are finally correct. Aren't you great? -- Jim Pennino Remove .spam.sux to reply. |
#240
rq3 writes:
Anthony, my boy, your interpretation is incorrect. At Mach, the air has compressed as much as it can, which is why it takes so much energy to force a solid object through Mach. If it were compressed as much as it could be, it would be a liquid. -- Transpose mxsmanic and gmail to reach me by e-mail. |
I want to ask you the most important question of your life. The question is: Are you saved? It is no | gasman | Soaring | 0 | August 26th 05 06:39 PM |
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good | Excelsior | Home Built | 0 | April 22nd 05 01:11 AM |
Question about Question 4488 | [email protected] | Instrument Flight Rules | 3 | October 27th 03 01:26 AM |
