#241
![]() cjcampbell wrote If the car's airspeed indicator said 60 then the speedometer will indicate 120. But the car would then need to expend the same energy to accelerate to 60 as it would to accelerate to 120 on a stationary road. An aircraft would need no additional power to accelerate to 60 on a treadmill. To which I'll note that you're on the right track, but remember kinetic energy varies as velocity squared: it takes 4 times the energy (at non relativistic velocities) to get to 120 as it does to 60: actually a lot more than that because windage losses and the like are not linear, either. |
#242
"Travis Marlatte" wrote:
Accelerating the mass to the same velocity requires the same energy regardless of what the surface is doing but wheel drag cannot be totally ignored. True. Another factor that I ignored as being insignificant (and this applies to the plane or car) is the extra energy it takes to provide the angular acceleration of the wheel to higher rotational velocities. E.g, at speed, one car includes 4 flywheels spinning with rim velocities of 60mph, while the other car has 4 flywheels spinning with rim velocities of 120mph. This additional energy need will cause slower acceleration if the same power is available. Why did you suggest that the car is providing the energy for the conveyor? We've had one recent poster who apparently thought that the power source for moving the conveyer was key to the problem. I'm not suggesting THAT the car was providing the energy, but only examining what IF it did. This would imply wheels with normal friction behavior but a frictionless conveyor with a brake. Not needed. As long as the conveyer has less friction and mass than the car, and has a brake to control its speed, the car can power it. And how much power that absorbs will determine how much the car's acceleration is lowed down. At the limit, it is CJ's speculation of the car's acceleration to 120 (on the speedometer) matching a regular road acceleration to 120. A conveyor that is motor driven but controlled makes a more consistent model. Agreed. I agree that very little additional thrust is necessary (either from the wheels of a car or from the propeller of a plane) to counteract the counter-moving conveyor. But some additional energy will be needed due to the additional drag provided by the faster spinning wheels (both for the car and the plane). And to accelerate the wheels to a higher angular velocity, assuming they are not massless. -- Alex -- Replace "nospam" with "mail" to reply by email. Checked infrequently. |
#243
"Tony" wrote:
cjcampbell wrote If the car's airspeed indicator said 60 then the speedometer will indicate 120. But the car would then need to expend the same energy to accelerate to 60 as it would to accelerate to 120 on a stationary road. An aircraft would need no additional power to accelerate to 60 on a treadmill. To which I'll note that you're on the right track, Not really. Except for minor factors (having to do with wheel friction and mass), getting a car to 60 (ground speed) on the treadmill takes no more energy than getting it to 60 on a regular road. but remember kinetic energy varies as velocity squared: it takes 4 times the energy (at non relativistic velocities) to get to 120 as it does to 60: actually a lot more than that because windage losses and the like are not linear, either. -- Alex -- Replace "nospam" with "mail" to reply by email. Checked infrequently. |
#244
oups.com... What an inane thread! I am amazed at how many people are arguing about such a silly subject. There's nothing wrong with being interested in a brain-teaser. Get a life people! Oddly, your own busy life leaves you time not only to read a thread you're not even interested in, but also to post here announcing your lack of interest. --Gary |
#245
Gary wrote:
What an inane thread! I am amazed at how many people are arguing about such a silly subject. There's nothing wrong with being interested in a brain-teaser. Get a life people! Oddly, your own busy life leaves you time not only to read a thread you're not even interested in, but also to post here announcing your lack of interest. It is just another way for Dean to tell us that his life is much more fulfilling than ours Gary. lol The Monk |
#246
An idea that popped into my mind...
ywo subject question lines... 1. Can a plane on a treadmill take off? 2. Can a plane take off from a treadmill? In the first instance, the airplane is attached to the treadmill and would have to lift the weight and shape of the treadmill. In the second, the airplane would behave differntly depending on whether the treadmill was powered or just a belt on rollers. a. If just a belt on rollers, the engine thrust would drive the airplane forward until it was not on the treadmill anymore, thus it would have air movement over the wings and would take-off. If the brakes were not locked, either or both the tires and treadmill would "roll." If the brtakes were set, the treadmill would roll and the airplane would likely come to a stop when it departed the treadmill unless it was alrady at flying speed. b. If the treadmill was powered [and everything was timed in sync] the belt would be accelerating rearward and the engine thrust would be pulling forward at the same rate, thus the airframe mounted wigs would have near zero airspeed and lift and would not fly. b1. If the treadmill was powered and ran forward, it would act as a catapult and launch the airplane or at least assist. Hey, let's build a really big treadmill and try several different airplane types, such as a Helio, a Maule, a Cessna Caravan, and a C5 [a really big treadmill] and see what happens. -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "Flyingmonk" wrote in message oups.com... | Gary wrote: | What an inane thread! I am amazed at how many people are arguing about | such a silly subject. | | There's nothing wrong with being interested in a brain-teaser. | | Get a life people! | | Oddly, your own busy life leaves you time not only to read a thread you're | not even interested in, but also to post here announcing your lack of | interest. | | It is just another way for Dean to tell us that his life is much more | fulfilling than ours Gary. lol | | The Monk | |
#247
"Jim Macklin" wrote:
b. If the treadmill was powered [and everything was timed in sync] the belt would be accelerating rearward and the engine thrust would be pulling forward at the same rate, thus the airframe mounted wigs would have near zero airspeed and lift and would not fly. Just to "set the hook" here, are you saying that it will be possible to have the conveyer move backwards fast enough that the plane remains still, even under full power, and with no brakes on? -- Alex -- Replace "nospam" with "mail" to reply by email. Checked infrequently. |
#248
"alexy" wrote in message
news ![]() Just to "set the hook" here, are you saying that it will be possible to have the conveyer move backwards fast enough that the plane remains still, even under full power, and with no brakes on? I thought you had already established that it would be possible, and that the treadmill speed is "somewhat below the speed of light"? You didn't appear to solve the "materials integrity" aspect of the problem, but that seems like a minor quibble. ![]() Pete |
#249
"Peter Duniho" wrote:
"alexy" wrote in message news ![]() Just to "set the hook" here, are you saying that it will be possible to have the conveyer move backwards fast enough that the plane remains still, even under full power, and with no brakes on? I thought you had already established that it would be possible, and that the treadmill speed is "somewhat below the speed of light"? You didn't appear to solve the "materials integrity" aspect of the problem, but that seems like a minor quibble. ![]() No fair; that's the next question, not to be asked out of order!! ;-) -- Alex -- Replace "nospam" with "mail" to reply by email. Checked infrequently. |
#250
Another pilot slips into the tar pit.
"alexy" wrote in message news ![]() "Jim Macklin" wrote: b. If the treadmill was powered [and everything was timed in sync] the belt would be accelerating rearward and the engine thrust would be pulling forward at the same rate, thus the airframe mounted wigs would have near zero airspeed and lift and would not fly. Just to "set the hook" here, are you saying that it will be possible to have the conveyer move backwards fast enough that the plane remains still, even under full power, and with no brakes on? -- Alex -- Replace "nospam" with "mail" to reply by email. Checked infrequently. |
Passenger crash-lands plane after pilot suffers heart attack | R.L. | Piloting | 7 | May 7th 05 11:17 PM |
Navy sues man for plane he recovered in swamp | marc | Owning | 6 | March 29th 04 12:06 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | October 1st 03 07:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | September 1st 03 07:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | August 1st 03 07:27 AM |
