#241
On Tue, 1 Aug 2006 07:18:09 -0600, "Jeff Crowell"
wrote in : [...] You have been claiming that the speed of the USAF flight was "480 knots (550 mph) at impact" (your post, 7/14), when actual recorded speed at impact was 356 KCAS per the accident report. [That would be Message-ID: ] AIB Report mentions the 480 knot closure speed twice: AIB Report: "The closure rate of Cessna 829 and Ninja 1 based on radar-measured conflict alert data just prior to the collision was approximately 480 KTAS." "Based on their closure rate of approximately 480 knots," ... With regard to your 356 KCAS airspeed at the time of impact, that is not given as Ninja 2's speed in the AIB nor NTSB reports. Here's the only reference to that number I was able to find in either document: AIB Report: "Ninja 1’s displayed airspeed at the time of the midair was 356 KCAS" ... You'll recall that Ninja 1 was not the aircraft that impacted the Cessna. (I find the fact that the AIB report equates 'displayed airspeed' with calibrated air speed a bit puzzling. Do F-16 airspeed indicators actually display calibrated airspeed?) So, lacking evidence to the contrary, I used the closing speed as the speed at the time of impact. That may be incorrect, but lacking better information, it seems reasonable to me, and not an exaggeration nor hyperbole. [...] The USAF Accident Investigation Board's report: "Ninja flight's mistake was in transitioning to the tactical portion of their flight too early, unaware that they were in controlled airspace." That was President, Accident Investigation Board Robin E. Scott's opinion. It is not fact. Despite the fact that Parker failed to brief terminal airspace prior to the flight as regulations require, I personally find it difficult, if not impossible, to believe Parker was unaware, that the 60 mile diameter Tampa Class B terminal airspace lay below him at the time he chose to descend below 10,000' into it. That's opinion, too, annit? I suppose it is my reasoned opinion. If you disagree, perhaps you could explain how Parker could have been unaware of a chunk of terminal airspace 60 miles in diameter and 10,000' feet high on a clear day; I can't. He surely must have been able to see the large international airport beneath him. Every pilot knows there is controlled terminal airspace around such airports. Additionally, Parker was attempting to contact ATC to obtain a clearance to enter the Class B airspace immediately before he chose to descend with out the required ATC clearance. Given those facts, how could Parker possibly have been unaware of what he was doing? Lacking an answer to that question, in light of the circumstances, logic and reason demand, that I conclude, that Parker deliberately chose to violate regulations prohibiting his descent into congested terminal airspace without the required ATC clearance. Per the F-16 Dash 1 he was allowed to be at 350 knots at that altitude, and was traveling only slightly faster at the time of the collision. What about that statement (from the accident investigation) do you not understand? Jeff, I understand that 450 knots within congested terminal airspace is about one third faster than the 350 knot speed limit you state above. One third is not 'slightly faster'. It is _significantly_ faster. (The 450 knot figure is quoted from the AIB report at the beginning of this follow up article.) Perhaps you can provide the reasoning you used in arriving at your conclusion. Speed of the F-16 at impact was 356 KCAS. Limiting the discussion to your 356 KCAS speed at the time of impact figure disregards this fact: Final NTSB Report MIA01FA028A: http://www.ntsb.gov/NTSB/brief2.asp?...A028A &akey=1 "Speeds of up to 450 knots were noted during the descent." Why would you overlook that 450 knot speed? Does the F-16 Dash 1 only pertain to the speed at time of impact? :-) |
#242
![]() Larry Dighera wrote: Actually, there is quite a bit of Class G airspace in the US. It's ceiling is just 700' or 1,200' AGL. Come on out West, we have lots of class G and you are not limited to a measly 1200 AGL. |
#243
On Wed, 02 Aug 2006 15:40:54 -0600, Newps wrote
in : Larry Dighera wrote: Actually, there is quite a bit of Class G airspace in the US. It's ceiling is just 700' or 1,200' AGL. Come on out West, we have lots of class G and you are not limited to a measly 1200 AGL. I am out west, southern California. Not much Class G above 1,200' around here. |
#244
Jose wrote:
The deconfilction task rests on two pilots, the high performance one (who should be so trained) and the low performance one (who was, in the example, the one hit). To expect a typical 172 pilot to be able to deconflict at F16 speeds is ludicrous, but that is what is being asked when an F16 at full bore is the conflicting traffic. The problem is that the 172-pilot's motivation doesn't match the threat. Why is that, you ask? Because of inadequate information about the threat, primarily. It comes down to training and the emphasis placed on the problem by the FAA (very minimal, in both instances). The fact that by choosing to fly a 172 the pilot severely limits his ability to visually clear the airspace is fodder for another thread. Jack |
#245
Please provide a quote of my words in which I espouse ceding control of airspace to the military and commercial interests. You have in multiple instances advocated making the military totally responsible for traffic conflicts/separation on MTR's. That certainly requires control of the airspace. In the spirit of cooperation, I have suggested that MTR's be made Restricted airspace in order to facilitate such a scheme. You find that an unsatisfactory solution, apparently. Feel free to restate your position. Jack |
#246
You might consider this quote from a naval fighter pilot: http://www.iasa.com.au/folders/Safet...perhornet.html Of his career as a Navy aviator, Webb told him: "Mike, I love this so much I can't believe they're paying me to do it. I'd do it for free." And that makes your nebulous case, how? They certainly wouldn't do it if they didn't love it, considering all the downsides of the life. You only get fighter pilots so cheaply for that reason. Sorry if you hate your life. Jack |
#247
I don't understand what you are saying. If an F16 were flying full bore on a head-on collision course with a 172, it may well be that the F16 pilot's superior training and superior eyesight could pick out the 172 in enough time. To expect the same thing of a 172 pilot, who merely passed a class III exam, and has not had training in high speed combat is ludicrous. For this reason and others like it (including the VFR visibility minima), there is a speed limit in the 172's normal territory: 250 knots, or the slowest safe speed in your aircraft, whichever is higher. If military pilots have a sterile area where they can play, these limits need not apply, since they are superior pilots with superior eyesight, superior training, and superior experience. But it's like driving 90 mph. Do it on the highway or the race track, but don't do it on a residential street. And don't call a residential street a highway for your convenience, and then blame the kid playing ball in the street when you smash him at 90 mph. It comes down to training and the emphasis placed on the problem by the FAA (very minimal, in both instances). Partly. If the 172 pilots were trained to military standards, we could probably raise the speed limit. But there's be no pilots left who have the AMUs to pay for it. The fact that by choosing to fly a 172 the pilot severely limits his ability to visually clear the airspace is fodder for another thread. All aircraft have blind spots. Airliners aren't known for great visibility either. Jose -- The monkey turns the crank and thinks he's making the music. for Email, make the obvious change in the address. |
#248
On Wed, 02 Aug 2006 15:43:18 GMT, 588 wrote in : Scared of Mid-Airs? Me too, so I stay away from 'em. It's easier if you know where they are. Another inane remark like that, and you'll find yourself without my readership. That would be a heart-breaker, LD, but I'm just not a humorless, one-note, obsessive kind of guy -- so I can live with it. It is easier to avoid MAC's if you know under what conditions they usually occur. Yet you recommend letting somebody else handle that responsibility for you. And, you think you can give that responsibility away and still retain your own freedom of action. That seems arrogant. Jack |
#249
Jose wrote:
...there is a speed limit in the 172's normal territory: 250 knots, or the slowest safe speed in your aircraft, whichever is higher. If military pilots have a sterile area where they can play, these limits need not apply.... ...don't call a residential street a highway for your convenience, and then blame the kid playing ball in the street when you smash him at 90 mph. Keep the kid off the racetrack and everybody's happy. Responsible adults do that. The fact that by choosing to fly a 172 the pilot severely limits his ability to visually clear the airspace is fodder for another thread. Airliners aren't known for great visibility either. And yet they have so few MAC's. Why is that? Jack |
#250
588 wrote: ...don't call a residential street a highway for your convenience, and then blame the kid playing ball in the street when you smash him at 90 mph. Keep the kid off the racetrack and everybody's happy. Responsible adults do that. Responsible adults know where they are Responsible adults don't turn a sidestreet into a racetrack. The fact that by choosing to fly a 172 the pilot severely limits his ability to visually clear the airspace is fodder for another thread. Airliners aren't known for great visibility either. And yet they have so few MAC's. Why is that? ATC Radar TCAS Big ugly airplanes are easy to spot Not a lot of fighter aircraft flying around lost at the altitudes where airliners spend most of their flight time. -- Bob Noel Looking for a sig the lawyers will hate |
UBL wants a truce - he's scared of the CIA UAV | John Doe | Aviation Marketplace | 1 | January 19th 06 08:58 PM |
The kids are scared, was Saddam evacuated | D. Strang | Military Aviation | 0 | April 7th 04 10:36 PM |
Scared and trigger-happy | John Galt | Military Aviation | 5 | January 31st 04 12:11 AM |
