Question to Mxmanic
Old April 17th 07, 06:25 PM posted to rec.aviation.piloting,rec.aviation.student
Default Question to Mxmanic
In rec.aviation.piloting Mxsmanic wrote:
rq3 writes:
Anthony, my boy, your interpretation is incorrect. At Mach, the air has
compressed as much as it can, which is why it takes so much energy to
force a solid object through Mach.
If it were compressed as much as it could be, it would be a liquid.
Yet another (almost) true but worthless statement and semantic game.
You are really good at playing semantic games.
Jim Pennino
Remove .spam.sux to reply.
  #245
Old April 17th 07, 06:46 PM posted to rec.aviation.piloting,rec.aviation.student
swag
On Apr 17, 9:10 am, Mxsmanic wrote:
Tim writes:
An interesting dilemma - either MSFS is bogus or Mx is wrong... has hell
frozen over?
Many of the MSFS developers are pilots, for better or for worse.
I believe that the explanation to why all pilots have experienced this
is that the vortices of a tight turn descend much more slowly than the
vortices generated in straight flight. All of the experimental data
that I can find on vortex descent rate has been done on planes in
straight flight (or in wind tunnels which is the same thing). All of
the reasons espoused in this thread for vortices to have any downward
velocity can be used to explain why numbers should change when the
wings aren't level.
The other factor that has been ignored is how fast a steep turn
executes. A 2g coordinated turn at 100 knots will complete in 19
seconds. (That's close to a 45 degree bank angle in most small
planes.) The formula to play with different loading factors and
speeds is:
rate of turn= omega = g*sqrt(n^2-1)/V
  #246
Old April 17th 07, 07:12 PM posted to rec.aviation.piloting,rec.aviation.student
rq3
Wrong yet again! Wow, you're batting 1000! Most of the gases in air
require cooling in addition to compression to liquefy.
Rip
Mxsmanic wrote:
rq3 writes:
  #247
Old April 17th 07, 07:17 PM posted to rec.aviation.piloting,rec.aviation.student
rq3
Wrong again! Water is respirable at ambient pressures sufficiently high
to provide sufficient PO2 (that's partial pressure of oxygen, my boy).
Unfortunately, the problem is carbon dioxide solubility, which makes
water unusable. However, liquid respiration IS successfully done with
various fluorocarbon compounds.
Come now, Anthony. Try to get at least one fact straight.
Rip
Mxsmanic wrote:
writes:
And no, it is not possible to breathe water, you can only breathe
gases, if you want to be pendantically, semantically correct.
Water is breathable if there is enough oxygen in it, although the effect on
lung tissue over long periods of breathing a liquid has not been determined.
There are some therapeutic uses for techniques similar to this.
  #248
Old April 17th 07, 07:19 PM posted to rec.aviation.piloting,rec.aviation.student
rq3
Wrong again, Anthony! There is no King of England.
Rip
Mxsmanic wrote:
writes:
I am an engineer and have the degree to prove it and I totally agree
with him, so stuff it.
I'm actually the King of England.
Finally, the light comes on...
The light was always on, but it's hard to see through heavily tinted glasses.
  #249
Old April 17th 07, 07:40 PM posted to rec.aviation.piloting,rec.aviation.student
Judah
Mxsmanic wrote in
That's not what the engineers say.
Name 3.
  #250
Judah
Mxsmanic wrote in
Name 3
I want to ask you the most important question of your life. The question is: Are you saved? It is no gasman Soaring 0 August 26th 05 06:39 PM
