Running dry?
Old August 25th 05, 12:53 PM
Thomas Borchert
Icebound,
Once having embarked upon it, however, we would like to get through it as
safely as possible. :-)
Frankly, that's most definitely not my primary goal in life. And it would
make for an extremely boring life if it was.
Thomas Borchert (EDDH)
  #252
Old August 25th 05, 03:09 PM
Jay Honeck
With NO changes in engine horsepower, NO changes in wing design, NO
changes in nothing else except a net NEGATIVE CHANGE in rudder area ...
How (in an engineering sense) did they do that?
Jim, it's an FAA thing.
'Nuff said.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
  #253
Old August 25th 05, 04:05 PM
Dylan Smith
On 2005-08-25, RST Engineering wrote:
With NO changes in engine horsepower, NO changes in wing design, NO changes
There was another change - limiting the flap extension (IIRC) from 40
degrees to 30 degrees. Part of what decides gross weight is go around
performance with full flaps. You can get a 100lb gross weight increase
in some models of C172 just by limiting the flap extension to 30 degrees
with a plate that prevents you moving the flap switch past the 30
degrees setting.
Dylan Smith, Castletown, Isle of Man
Flying: http://www.dylansmith.net
Frontier Elite Universe: http://www.alioth.net
"Maintain thine airspeed, lest the ground come up and smite thee"
  #254
Old August 25th 05, 04:39 PM
Dale
They got out their little engineers eraser and engineers pencil and
changed the numbers.
The 30 degree flaps didn't come along until way late in the 182's
life...gross was up over 3000 pounds, IIRC, before the flaps were
limited.
Dale L. Falk
There is nothing - absolutely nothing - half so much worth doing
as simply messing around with airplanes.
http://home.gci.net/~sncdfalk/flying.html
  #255
Old August 25th 05, 10:20 PM
Newps
No 182 is limited to 30 degrees.
  #256
Old August 26th 05, 02:18 AM
Roger
On Wed, 24 Aug 2005 08:17:01 -0700, "Matt Barrow"
snip
It is, but the 33 is still 2 1/2" wider than the 35, yet still more
The 33's envelope goes two inches farther aft but starts two inches
farther aft too because the tail weighs more.
Gotcha...I was thinking of something else and did a reference fart.
There are 33s and then there are 33s and there is a big difference
between useful load and CG. Early 33s (prior to 74) had roughly a
100# useful load while those after had a 1400# useful load. I don't
know about the ones near the end of the production run.
With the early ones you didn't have much worry about CG change with
fuel burn either.
www.rogerhalstead.com
  #257
Old August 26th 05, 06:55 AM
Roger
On Thu, 25 Aug 2005 21:18:25 -0400, Roger
snip
Oops... That 1000# versus 1400#, but I'd guess every one figured that
out any way:-))
fuel burn either.
  #258
Old August 26th 05, 03:47 PM
Matt Barrow
"Roger" wrote in message
snip
out any way:-))
I understand the 33's with a IO-550 and Turbonormalizer max out at something
like 3750 MTOW and have about 1350 useful load. The heavier weight from the
engine & turbo do nice things for the CG, too. Add an oxygen system
(installed under the co-pilots) seat and it's even better.
Matt
Matthew W. Barrow
Site-Fill Homes, LLC.
Montrose, CO
Time, running out of fuel and fuel gauges Dylan Smith Piloting 29 February 3rd 08 07:04 PM
Engine running again, the good, bad and ugly Corky Scott Home Built 34 July 6th 05 05:04 PM
It's finally running! Corky Scott Home Built 19 April 29th 05 04:53 PM
Rotax 503 won't stop running Tracy Home Built 2 March 28th 04 04:56 PM
Leaving all engines running at the gate John Piloting 12 February 5th 04 03:46 AM
