#251
#252
#253
So, it might be a safety issue - using FM would effectively filter out
the weakest stations that could be heard if AM was used. Under what conditions would you need to hear really weak AM stations? Let me think. If my radio died and all I had was a handheld I would really want to be heard... even with this tiny antenna. Mind you, this is just a theory. Most of my time in the air (and 100% of my solo time) was in gliders with no radio at all. I just happen to know a bit about the technical side of radio :-) Bartek |
#255
"Mxsmanic" wrote in message
... Which means that a single break in a single wire disables multiple aircraft systems. Brilliant. Versus a break in a wire causing a spark that could result in a fire? I could never find a justification for those home remote control systems that used house wiring, and they weren't always reliable, anyway. Completely different scenario... With the home remote control systems, you're still using the larger diameter 110VAC wiring... There are two many other things on the line for it to handle signals very well... I've tried them before and I often has lights that wanted to turn on even if there was no command initiated to tell them to go on... A properly designed system is no more complex than the wiring to the headlights of your car... You are basically operating the equivalent to a relay, except that instead of a lower amperage current going to the switch, the "switch" sends a message to the light in a particular format to tell it to go on... |
#256
"Grumman-581" writes:
Versus a break in a wire causing a spark that could result in a fire? Anything that carries electricity can create sparks, even at low voltages. And you can use low-voltage for control systems even without TCP/IP. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#257
Emily writes:
Do you know what an NDB is? Yes. How many commercial flights use NDB routing today? And who suggested using FM for an NDB? -- Transpose mxsmanic and gmail to reach me by e-mail. |
#258
#259
Roger (K8RI) writes:
For voice communications you want the frequency response narrow. Probably from a low of 200 or 300 HZ to a high or 2500 or 3,000 Hz. This is where the majority of the intelligence is located. You need up to 7 KHz or so for sibilants and some other phonological features which are occasionally phonemic. This high-end response makes it possible to distinguish between 'f' and 's' in communications. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#260
B A R R Y writes:
How about VOR ID's, RCO's, distant TWEBs and FSS stations? For automated signals (not voice), distance is important. For voice, I'm not sure that distance matters that much, since if they are far enough away to be hard to hear, they are probably not an immediate hazard, and controllers have facilities that provide adequate coverage for the area that they control. Do you fly? As a pilot, only in simulation. As a passenger, only when absolutely necessary. -- Transpose mxsmanic and gmail to reach me by e-mail. |
UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 06:58 PM |
Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 04:40 AM |
terminology questions: turtledeck? cantilever wing? | Ric | Home Built | 2 | September 13th 05 09:39 PM |
I Hate Radios | Ron Wanttaja | Home Built | 9 | June 6th 05 05:39 PM |
AirCraft Radio Communications | [email protected] | Rotorcraft | 0 | November 13th 03 12:48 AM |
