On Tue, 22 Sep 2009 07:58:33 -0700, Ron Wanttaja
wrote: Stealth Pilot wrote: I could be jaundiced here but surely the drugs were prescribed. was the real failure a failure of the american medical system to diagnose and correctly treat his blocked anterior artery? Certainly, I'd say the drugs were prescribed. As far as failure to diagnose the problem, check the NTSB report again: "The pilot’s most recent application for airman medical certificate in May 2007 noted a “precautionary” coronary angiogram in 2006 which “showed no blockage.” ... Records obtained from the pilot’s cardiologist regarding the angiogram (performed September 25, 2006) noted a “totally occluded” small left anterior descending coronary artery with “good collaterals” and otherwise normal coronary arteries." So the diagnosis had been made. Phillips knew he had a problem; this angiogram was performed over a year before his death. We don't know if there had been any treatment other than drugs. I suspect not; his cardiologist would probably have noted it on his records and it would have been mentioned in the NTSB report. There could have been many reasons why Phillips didn't have surgery to alleviate the problem. Denial is common enough... "I feel fine...there isn't a problem!" Another factor is that surgery is hard to hide. Your friends know, your enemies find out, and there's always that fear that one of the latter will inform the FAA and get your medical canceled. All of us know friends who have gone through the tremendous hoops necessary to get their medicals back after heart surgery. btw if you have been taking medications for some time the body adapts. it is possible to have high levels of medications in the blood stream that have next to no cognitive effect on the individual. Certainly the body adapts, when exposed to large doses of drugs or alcohol over a long period. We've heard stories of drunk drivers with BACs above the line that would put most people unconscious. These people can outwardly seem normal. But this isn't just an issue of "Monkey Skills," as Phillips called them. This is an issue of reaction time and decision making, especially decision-making under stress with a less-than-nominal. cardiovascular system. The NTSB didn't just note high levels of a cocktail of drugs (vicodin, valium, paracodine, cardura, morphine derivatives, etc.)...the term used was "acute mixed drug intoxication". Ron Acute in the medical sense is quite different from our usual meaning. typically we laymen use acute to mean serious. In medical terms acute just means 'of short duration' we laymen also use chronic to mean serious whereas in medical terms chronic just means 'of long duration' so the term "acute mixed drug intoxication" just means a situation that hadnt occurred for a long period. it doesnt mean that he had a huge mixed drug intoxication problem, just one that had occurred at the time.(unless of course the report was written by laymen) we have little way of knowing what impairment that may have caused because as others have commented he took lots. rat poison is probably the warfarin that is used to break up blood clots. so yes the canopy was the direct cause, but long before that the heart problem. if we were honest the draconian aviation medical assessment for pilots also played a part in the accident. maybe if it wasnt so draconian, people would get the medical treatment they needed. in australia we see lots of pilots change to ultralights and self assessment during a clear period and go on to fly lots of hours that would be denied to them all without much problem. pilot medicals are after all a throwback to the days when governments kept civil pilots as a fighting reserve and wanted them to be fit to military standards. it is largely irrelevant now. if we were really interested in civil aviation safety we wouldnt bar pilots from flying, we'd more actively treat them. the other aspect that comes from this fatal accident is that the canopy design on that aircraft isnt fail safe. the slide back canopy on the Jodel aircraft (as an example) can pop open or even be deliberately opened in flight and the worst that happens is that it flies itself shut. The Thorp T18 has a similar style of fail safe canopy. I'll bet not many people would have the intelligence to change the canopy design on that design to something that was fail safe. so yes there are lots of lessons that can be learnt from bill's prang. the question is "will we actually learn them?" Stealth Pilot |
![]() "Stealth Pilot" wrote in message ... ------------------much snipped--------------- Ron Acute in the medical sense is quite different from our usual meaning. typically we laymen use acute to mean serious. In medical terms acute just means 'of short duration' we laymen also use chronic to mean serious whereas in medical terms chronic just means 'of long duration' so the term "acute mixed drug intoxication" just means a situation that hadnt occurred for a long period. it doesnt mean that he had a huge mixed drug intoxication problem, just one that had occurred at the time.(unless of course the report was written by laymen) we have little way of knowing what impairment that may have caused because as others have commented he took lots. rat poison is probably the warfarin that is used to break up blood clots. so yes the canopy was the direct cause, but long before that the heart problem. if we were honest the draconian aviation medical assessment for pilots also played a part in the accident. maybe if it wasnt so draconian, people would get the medical treatment they needed. in australia we see lots of pilots change to ultralights and self assessment during a clear period and go on to fly lots of hours that would be denied to them all without much problem. pilot medicals are after all a throwback to the days when governments kept civil pilots as a fighting reserve and wanted them to be fit to military standards. it is largely irrelevant now. if we were really interested in civil aviation safety we wouldnt bar pilots from flying, we'd more actively treat them. the other aspect that comes from this fatal accident is that the canopy design on that aircraft isnt fail safe. the slide back canopy on the Jodel aircraft (as an example) can pop open or even be deliberately opened in flight and the worst that happens is that it flies itself shut. The Thorp T18 has a similar style of fail safe canopy. I'll bet not many people would have the intelligence to change the canopy design on that design to something that was fail safe. so yes there are lots of lessons that can be learnt from bill's prang. the question is "will we actually learn them?" Stealth Pilot I agree with you on both points, and really doubt that there is much real reason for medical certification unless passengers are being carried for hire--and even then a case could be argued that the requirement is currently more stringent than needed except in single pilot operation. As to the canopy, the only defense of the tilt forward designs that I have ever been able to understand is that they do make it much easier to enter and exit the aircraft under normal conditions, and much the same could be said of the side hinged designs. Personally, both have made me just a little nervous when I have sat in them on the ground at shows and I would prefer to stay with the many sliding canopy designs--with the addition of hand holds on the windshield hoop or on the underside of the glare shield and also a ridge across the floor, if one is not already present, in order to easily heave myself up to a standing position in the case of the tailwheel types. BTW, so far, all of the RV builders who I know personally have stayed with the sliding canopies. Peter |
On Fri, 25 Sep 2009 05:30:52 +0000 (UTC), Clark
wrote: Stealth Pilot wrote in : [snip] Ron Acute in the medical sense is quite different from our usual meaning. typically we laymen use acute to mean serious. In medical terms acute just means 'of short duration' [snip] Nope. It means of severe and short duration so far. Don't minimize this one. Bill was obviously way over the line to be flying a plane. If we try to hide it behind fancy words then we are doing ourselves a disfavor. that's the problem. bill wasnt obviously anything. he could have had a pair of knickers over his face or have been blinded by something in his eyes. you leap to the drugs aspect as the cause. the stupid canopy design used on the aircraft was a greater factor in the accident than his blood chemistry. ymmv Stealth Pilot |
Stealth Pilot wrote: I could be jaundiced here but surely the drugs were prescribed. was the real failure a failure of the american medical system to diagnose and correctly treat his blocked anterior artery? I don't see how any other medical system would have guaranteed finding and fixing the problem. The autopsy noted "a 'totally occluded' small left anterior descending coronary artery with 'good collaterals² and otherwise normal coronary arteries". This is no indication of significant reduced cardiac function; the loss of blood flow through the "small anterior artery" would be at least partially offset by the "good collaterals", and frankly was probably completely asymptomatic. It might not even have been noted through a cardiac stress test, although is also probably an early precursor of further cardiac degradation a decade or two down the road. Perhaps some other national medical system routinely requires periodic CAT scans of all adults through life? Because nothing less would be likely to have found that problem. Earlier this year, my wife had a stent installed in her right coronary artery, which was ~95% blocked. That is a major artery, and in her case, without "good collateral" development to carry part of the load. We only figured out there was a problem while hiking at the top of Mt. Haleakala (we were visiting our daughter and son-in-law who live on Maui) that she was more short of breath than expected. A couple months later, she was showing similar symptoms working around the house, and we dropped everything and got it looked at. Failed treadmill test, etc. led to getting the stent installed a couple days later. And she's fine now, getting better, and we're back to cycling more/farther/harder than we have for a couple three years. The point being that her condition was worse than his, and not noticeable until it had progressed well beyond what was reported by the NTSB. |
what amazes me is how fast that blockage built up in his heart after
having an angiogram in '06 that showed his heart clear. I had one in '97 that was clear and I've been thinking I was good to go for who knows how long. Now I see how fast that stuff can build up inside there. A good heads up on that one. In his case, the drugs probably had more to do with this accident rather than his heart. But it will be interesting to see their final report. On Mon, 21 Sep 2009 07:42:22 -0700, Ron Wanttaja wrote: The NTSB has released the factual report: http://www.ntsb.gov/ntsb/brief2.asp?...LA016& akey=1 This is the usual precursor to the final report, which usually contains the same information with the addition of the NTSB's Probable Cause. Ron Wanttaja |
rich wrote:
what amazes me is how fast that blockage built up in his heart after having an angiogram in '06 that showed his heart clear. Re-read the NTSB report. The angiogram *didn't* show his heart was clear, though that's what he told the FAA: "The pilot’s most recent application for airman medical certificate in May 2007... also noted a “precautionary” coronary angiogram in 2006 which “showed no blockage.” ... Records obtained from the pilot’s cardiologist regarding the angiogram (performed September 25, 2006) noted a “totally occluded” small left anterior descending coronary artery...." Others have stated that the occlusion mentioned may not have been that impacting. But I don't think it justified Phillips claiming that it "showed no blockage." Ron Wanttaja |
On Tue, 22 Sep 2009 18:57:04 -0700, Ron Wanttaja
wrote: rich wrote: what amazes me is how fast that blockage built up in his heart after having an angiogram in '06 that showed his heart clear. Re-read the NTSB report. The angiogram *didn't* show his heart was clear, though that's what he told the FAA: "The pilot’s most recent application for airman medical certificate in May 2007... also noted a “precautionary” coronary angiogram in 2006 which “showed no blockage.” ... Records obtained from the pilot’s cardiologist regarding the angiogram (performed September 25, 2006) noted a “totally occluded” small left anterior descending coronary artery...." Others have stated that the occlusion mentioned may not have been that impacting. But I don't think it justified Phillips claiming that it "showed no blockage." Ron Wanttaja in your entire life you've never told a lie in a situation of great duress???????? you wouldnt be human if you hadn't. Stealth Pilot |
![]() "Stealth Pilot" wrote in message ... On Tue, 22 Sep 2009 18:57:04 -0700, Ron Wanttaja wrote: rich wrote: what amazes me is how fast that blockage built up in his heart after having an angiogram in '06 that showed his heart clear. Re-read the NTSB report. The angiogram *didn't* show his heart was clear, though that's what he told the FAA: "The pilot's most recent application for airman medical certificate in May 2007... also noted a "precautionary" coronary angiogram in 2006 which "showed no blockage." ... Records obtained from the pilot's cardiologist regarding the angiogram (performed September 25, 2006) noted a "totally occluded" small left anterior descending coronary artery...." Others have stated that the occlusion mentioned may not have been that impacting. But I don't think it justified Phillips claiming that it "showed no blockage." Ron Wanttaja in your entire life you've never told a lie in a situation of great duress???????? you wouldnt be human if you hadn't. Stealth Pilot Providing information that isn't true to a bureacrat is not lying. It is just expediency. Stu Fields |
On Tue, 22 Sep 2009 18:57:04 -0700, Ron Wanttaja wrote: Others have stated that the occlusion mentioned may not have been that impacting. But I don't think it justified Phillips claiming that it "showed no blockage." in your entire life you've never told a lie in a situation of great duress???????? I've only told a lie twice in my life. Uhhh, three, if you count now. Uhhh...four? :-) We're not talking a mere "lie," here, we're talking about a criminal act. Lying on an FAA medical is good for a quarter-million-dollar fine and/or a five-year prison sentence. you wouldnt be human if you hadn't. And I'm not catching the "duress" here. Phillips had nine months after his angioplasty to decide what to say on his next medical. He did not fly for hire; his livelihood did not depend on retaining his medical. He didn't even *have* to take the medical... he could have let it expire and continue to fly as a Sport Pilot. So there was no "great duress." His option was to commit a felony, fly without a medical, or not fly. I don't want to come over all priggish here; there's probably a good chance I'd continue to fly, with the same sort of conditions. The difference would be that I don't think I'd commit perjury to do it, and I wouldn't risk a passenger's life. There's a lot of peace of mind, in flying a single-seat airplane.... From another posting... so the term "acute mixed drug intoxication" just means a situation that hadnt occurred for a long period. it doesnt mean that he had a huge mixed drug intoxication problem, just one that had occurred at the time. I'm not a medical person...you may be right. A guy on the POA forum who claims he's an MD said that the levels of Vicodin was in the "high toxic to low lethal range," and the codine was "at the top of Therapeutic and approaching Toxic." One would hope this wasn't a daily occurrence. The accident occurred in late October as Phillips and his wife were coming home from their cabin in the mountains of Utah. It's possible, given the lateness of the year, that they had been closing out the cabin for the winter. Phillips may have overdone it; he may have thrown his back out and started chugging pills. Ron Wanttaja |
![]() "Ron Wanttaja" wrote in message ... Stealth Pilot wrote: On Tue, 22 Sep 2009 18:57:04 -0700, Ron Wanttaja wrote: Others have stated that the occlusion mentioned may not have been that impacting. But I don't think it justified Phillips claiming that it "showed no blockage." in your entire life you've never told a lie in a situation of great duress???????? I've only told a lie twice in my life. Uhhh, three, if you count now. Uhhh...four? :-) We're not talking a mere "lie," here, we're talking about a criminal act. Lying on an FAA medical is good for a quarter-million-dollar fine and/or a five-year prison sentence. you wouldnt be human if you hadn't. And I'm not catching the "duress" here. Phillips had nine months after his angioplasty to decide what to say on his next medical. He did not fly for hire; his livelihood did not depend on retaining his medical. He didn't even *have* to take the medical... he could have let it expire and continue to fly as a Sport Pilot. So there was no "great duress." His option was to commit a felony, fly without a medical, or not fly. I don't want to come over all priggish here; there's probably a good chance I'd continue to fly, with the same sort of conditions. The difference would be that I don't think I'd commit perjury to do it, and I wouldn't risk a passenger's life. There's a lot of peace of mind, in flying a single-seat airplane.... From another posting... so the term "acute mixed drug intoxication" just means a situation that hadnt occurred for a long period. it doesnt mean that he had a huge mixed drug intoxication problem, just one that had occurred at the time. I'm not a medical person...you may be right. A guy on the POA forum who claims he's an MD said that the levels of Vicodin was in the "high toxic to low lethal range," and the codine was "at the top of Therapeutic and approaching Toxic." One would hope this wasn't a daily occurrence. The accident occurred in late October as Phillips and his wife were coming home from their cabin in the mountains of Utah. It's possible, given the lateness of the year, that they had been closing out the cabin for the winter. Phillips may have overdone it; he may have thrown his back out and started chugging pills. Ron Wanttaja Well, actually, he could not have [legally] flown that aircraft as a sport pilot; but your basic point is well taken and I am really more than a little dissappointed there seems to be so little new to learn. If the presumed doctor on the POA forum is correct, then it would appear that BWB might have taken some more medication just before departure--almost in the manner of a college freshman chugging beer--and that his ability to fly was becomming more degraded from moment to moment. All of that could be a dfpretty good explanation of at least one way the the canopy latch might not have been operated correctly and also how a noise level distraction might have gained priority over simply "flying the airplane" and even suggests the possibility that he might well have become incapacitated during the flight if the takeoff and climb had been uneventfull. BTW, all of this makes it seem almost appropriate to ask: does anyone here know how Mrs Phillips got her nickname? Peter Staying with sliding and not hinged canopies! |
Badwater Bill - Janice Phillips contact | BobR | Home Built | 1 | October 24th 08 02:46 PM |
NTSB report - ILS and ATC. How does it all come together? | Montblack | Piloting | 1 | June 19th 06 11:26 PM |
NTSB report - ILS and ATC. How does it all come together? | Montblack | Instrument Flight Rules | 1 | June 19th 06 11:26 PM |
Preliminary NTSB report on Walton accident | ChuckSlusarczyk | Home Built | 11 | July 12th 05 04:23 PM |
Prelim NTSB report, Pilatus accident in PA | vincent p. norris | Piloting | 15 | April 11th 05 02:52 PM |
