Alternative to welding aluminum frame of Komet?
Old October 19th 09, 07:40 PM posted to rec.aviation.soaring
Bruno
Default Alternative to welding aluminum frame of Komet?
I just noticed that a few of the welds on the top aluminum framework
of my Komet trailer have broken. Maybe I am just lazy but I am
concerned about getting the welds redone with the fiberglass top right
next to it. Does anyone have any suggestions for a good bonding agent
to use on the broken welds?
Bruno - B4
Old October 19th 09, 08:15 PM posted to rec.aviation.soaring
Brad[_2_]
of my Komet trailer have broken. *Maybe I am just lazy but I am
next to it. *Does anyone have any suggestions for a good bonding agent
Bruno - B4
A friend has the same problem with his Komet. We were talking to a
welding guy and he mentioned that it could be Stitch Welded, dunno
what that means, but worth a try.
Brad
Old October 19th 09, 08:25 PM posted to rec.aviation.soaring
Uncle Fuzzy
Bruno - B4
Brad
That's a technique of doing a lot of short welds, spread way apart,
letting those cool, then doing another series of short welds between
the first batch, and repeating until the weld is continuous. Keeps you
from cooking the fiberglass.
Old October 19th 09, 08:23 PM posted to rec.aviation.soaring
Uncle Fuzzy
Bruno - B4
Now I'm going to have to look at my trailer more closely. I know all
the structure of the bottom half is steel, and I had assumed the top
was too! (My trailer is late 70's vintage). Where are your welds
cracked? If there is access, it can be re-welded. Otherwise, gussets,
epoxy, and rivets. IMO, just putting epoxy (or any type of glue/
cement/bonding agent) in the places the welds have cracked won't take
care of the problem.
Old October 19th 09, 08:48 PM posted to rec.aviation.soaring
Tim Mara[_2_]
if you're afraid of welding heat and don't want to remove the top (I would
dare to say they is a pretty big job, why not look at adding a few aluminum
sheet gussets where the cracks are...typically mechanical fasteners can be
as strong or stronger than the welded aluminum joints if properly done. Even
(good) high strength Pop-Rivets could be use easily to attached the gussets.
tim
Please visit the Wings & Wheels website at www.wingsandwheels.com
"Bruno" wrote in message
Bruno - B4
Old October 19th 09, 10:23 PM posted to rec.aviation.soaring
Udo
I agree with Tim, alu welds are much weaker.
Gussets and bolts are much stronger.
The most likely reason the weld broke, vibration.
Udo
tim
Please visit the Wings & Wheels website atwww.wingsandwheels.com
Bruno - B4- Hide quoted text -
- Show quoted text -
Old October 19th 09, 10:49 PM posted to rec.aviation.soaring
Udo
tim
- Show quoted text -- Hide quoted text -
Agree with Udo
..060 aluminum gussets, Cherry Max rivets.
Good for life
UH
Old October 20th 09, 12:32 AM posted to rec.aviation.soaring
Bruno
Udo
tim
Agree with Udo
Good for life
UH
Thanks all for the replies. I was hoping that someone would say JB-
Weld would work great but I think I am going to have to bite the
bullet and try my hand at doing a few rivets and aluminum gussets. I
am glad I saw the broken welds when I did last night. They are on
both sides of the bar that holds my stabilizer to the roof. I only
had a few screws attached to the ceiling holding that half of the
stabilizer holder up into the roof. Yikes! I would recommend
everyone the next time they are in their trailer to look at the welds
up in the corners of their trailer roof for breaks.
Bruno - B4
Old October 20th 09, 02:12 AM posted to rec.aviation.soaring
Dave Nadler
Udo
tim
Agree with Udo
Good for life
UH
Thanks all for the replies. *I was hoping that someone would say JB-
bullet and try my hand at doing a few rivets and aluminum gussets. *I
am glad I saw the broken welds when I did last night. *They are on
both sides of the bar that holds my stabilizer to the roof. *I only
stabilizer holder up into the roof. *Yikes! *I would recommend
Bruno - B4
Note that UH says Cherry-Max - these are not cheapo pop-rivets !
Old October 19th 09, 09:47 PM posted to rec.aviation.soaring
John Smith
Considering what a trailer is meant to bear and how long it will
hopefuly remain in use, I would bite the bullet, remove the top and have
the welding job done by a pro without compromises.
Gas Welding Aid 1 - welding clamp 1.JPG (0/1) Stealth Pilot[_2_] Aviation Photos 1 March 26th 09 07:20 AM
gas welding aid 2 - welding clamp 2.JPG (1/1) Stealth Pilot[_2_] Aviation Photos 0 March 26th 09 03:58 AM
gas welding aid 2 - welding clamp 2.JPG (0/1) Stealth Pilot[_2_] Aviation Photos 0 March 26th 09 03:57 AM
aluminum rib, aluminum spar, holes drilled but screws broken off jls Home Built 13 January 3rd 07 08:06 AM
Aluminum welding Ernest Christley Home Built 5 April 24th 06 11:47 AM
