#21
"Steven P. McNicoll" wrote in
nk.net: I guess the next question is, "reported to whom?". To ATC. No, to the pilot. ATC doesn't necessarily get weather reports, because they're not the National Weather Service. We have weather observers in lots of places, and their reports don't necessarily get into the system, especially if we call up and ask for the weather at odd times. If your FBO has a certified weather observer on staff ATC will have that observation. Not necessarily, and in some cases, not even likely. Weather is not reported to ATC, it's reported to the NWS, if anyone. ATC isn't at the front of the line. In fact, my home base has weather reporting via ASOS and much of the time ATC is far behind on the weather. They don't even know when it goes from VMC to IMC and vice versa unless we tell them. -- Regards, Stan "They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." B. Franklin |
![]() "Ron Rosenfeld" wrote in message ... Steve, What's your take on this situation? There was an accredited weather observer on the ground at KEPM. KEPM rarely in the past would report weather to Bangor Radio, but did not on this particular day. I contacted this observer on 122.8 and obtained the visibility from him. I then relayed this information to ATC and told them it was from an accredited observer. I was then cleared for a contact approach. My take is there's no point in making an observation and not reporting it. If an observation is made but not reported then the requirement for reported ground visibility has not been satisfied. |
![]() "Stan Gosnell" wrote in message ... You just tell him that you have the weather. I do this all the time, flying approaches to slimeholes in the backwaters of south Louisiana, using weather from company observers, under Part 135. They're certified, and do make supplemental observations to the NWS, but mostly they just do observations for us when needed. It's the same as any other weather report, and the same as if you get it from a tower. The ATC specialist doesn't care where the weather came from, or how you got it. All he cares about is that you can get on the ground and out of his airspace. Tell him you have the Podunk weather, want to fly the approach, and he'll give you a clearance. That's not good enough for a contact approach. The reported ground visibility must be at least one mile for the controller to issue a clearance for a contact approach. There's no minimum visibility required to issue clearance for an IAP. |
![]() "Stan Gosnell" wrote in message ... No, to the pilot. No, to ATC. Really. ATC doesn't necessarily get weather reports, because they're not the National Weather Service. We have weather observers in lots of places, and their reports don't necessarily get into the system, especially if we call up and ask for the weather at odd times. The subject is contact approaches. Where ATC does not get weather reports contact approaches are not available. Not necessarily, and in some cases, not even likely. Weather is not reported to ATC, it's reported to the NWS, if anyone. ATC isn't at the front of the line. In fact, my home base has weather reporting via ASOS and much of the time ATC is far behind on the weather. They don't even know when it goes from VMC to IMC and vice versa unless we tell them. That is unlikely. |
nk.net: The subject is contact approaches. Where ATC does not get weather reports contact approaches are not available. That may well be. I'm prohibited from requesting or flying contact approaches, so I've never done it, nor studied the requirements that closely. Not necessarily, and in some cases, not even likely. Weather is not reported to ATC, it's reported to the NWS, if anyone. ATC isn't at the front of the line. In fact, my home base has weather reporting via ASOS and much of the time ATC is far behind on the weather. They don't even know when it goes from VMC to IMC and vice versa unless we tell them. That is unlikely. No, that's the everyday reality. -- Regards, Stan "They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." B. Franklin |
Yes,
Ground visibility should be at least 1 SM and the pilot have to request the contact approach. Raf "Steven P. McNicoll" a écrit dans le message de news: t... "Stan Prevost" wrote in message ... Can ATC clear an aircraft for a contact approach to an airport which has no weather reporting? No, a contact approach requires a reported ground visibility of at least one mile. |
![]() "Stan Gosnell" wrote in message ... That may well be. It's a certainty. No, that's the everyday reality. You do not appear to be in a position to know the everyday reality. |
On Fri, 11 Feb 2005 04:48:05 GMT, "Steven P. McNicoll"
wrote: My take is there's no point in making an observation and not reporting it. If an observation is made but not reported then the requirement for reported ground visibility has not been satisfied. It was reported. The pilot was the conduit. Where is it written that this is not allowed? |
#29
Well, somewhere along the line ATC has to get the reported weather in
order to issue the clearance. On 11 Feb 2005 04:41:54 GMT, Stan Gosnell wrote: "Steven P. McNicoll" wrote in ink.net: I guess the next question is, "reported to whom?". To ATC. No, to the pilot. ATC doesn't necessarily get weather reports, because they're not the National Weather Service. We have weather observers in lots of places, and their reports don't necessarily get into the system, especially if we call up and ask for the weather at odd times. If your FBO has a certified weather observer on staff ATC will have that observation. Not necessarily, and in some cases, not even likely. Weather is not reported to ATC, it's reported to the NWS, if anyone. ATC isn't at the front of the line. In fact, my home base has weather reporting via ASOS and much of the time ATC is far behind on the weather. They don't even know when it goes from VMC to IMC and vice versa unless we tell them. |
#30
Thiw may be true of SIAP's, since ATC often doesn't know or care about
what the weather is when they clear you for an approach. We are discussing contact approaches, however. It's a different animal. On 11 Feb 2005 04:36:52 GMT, Stan Gosnell wrote: You just tell him that you have the weather. I do this all the time, flying approaches to slimeholes in the backwaters of south Louisiana, using weather from company observers, under Part 135. They're certified, and do make supplemental observations to the NWS, but mostly they just do observations for us when needed. It's the same as any other weather report, and the same as if you get it from a tower. The ATC specialist doesn't care where the weather came from, or how you got it. All he cares about is that you can get on the ground and out of his airspace. Tell him you have the Podunk weather, want to fly the approach, and he'll give you a clearance. -- Regards, Stan |
GPS approach question | Matt Whiting | Instrument Flight Rules | 30 | August 29th 08 03:54 AM |
Contact approach question | Paul Tomblin | Instrument Flight Rules | 114 | January 31st 05 06:40 PM |
VOR/DME Approach Question | Chip Jones | Instrument Flight Rules | 47 | August 29th 04 05:03 AM |
Why is ADF or Radar Required on MFD ILS RWY 32 Approach Plate? | S. Ramirez | Instrument Flight Rules | 17 | April 2nd 04 11:13 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
