Another sailplane lost!
Old February 3rd 10, 12:54 AM posted to rec.aviation.soaring
Tony V
Default Another sailplane lost!
Frank Whiteley wrote:
......The knots are multiple half hitches drawn up tight against
the glider.
Always use a Truckers hitch, IMHO:
http://www.ehow.com/video_2355281_ti...itch-knot.html
Tony V LS6-b
Old February 3rd 10, 02:44 AM posted to rec.aviation.soaring
Darryl Ramm
the glider.
Always use a Truckers hitch, IMHO:http://www.ehow.com/video_2355281_ti...itch-knot.html
Tony V LS6-b
What if we don't have a piano?
Darryl
Old February 3rd 10, 04:32 PM posted to rec.aviation.soaring
The critical, but often neglected aspect of keeping a ship on the
ground, undamaged is to reduce the angle of attack, both while tied
down and during ground handling. This dramatically reduced the load
on the tiedowns, as was very well documented in the old Red Schweizer
Soaring manual.
As a working example, Skylark North in Tehachapi (and formerly the
brutally windy CalCity) has never lost a tied down ship in 40+ years
(and only 1 while being ground handled) in a very windy environment
using this technique. Caracole in CalCity keeps their fleet safe
using this method as well.
Short of a tornado or similar extreme event, properly tied down ships
should never be lost. Of course, "never" is a very long time
Creating adequate tiedowns in a landout or safari situation is
problematic but getting the AOA down is not that hard (flaps full
negative, constrained tail dolly, inverted wash buckets, wood, or a
mound of dirt for tailwheel and dig hole for main gear).
I believe the best "combat" landout mode for keeping a glider on the
ground in high winds is to orient the glider 90 degrees to the wind
and expend all resources on keeping the upwind wing on the ground. I
have seen it used to good effect in extreme wave/rotor conditions
using a tractor tire, tiedown kit, rocks, and the pilot's body.
Old February 3rd 10, 05:22 PM posted to rec.aviation.soaring
Gary Boggs
And another one bites the dust while tied down!
http://bit.ly/btNFm4
Old February 3rd 10, 06:04 PM posted to rec.aviation.soaring
Mike the Strike
This is possibly the 2-33 of the Prescott Soaring Club that was lost
in the same storm as the California Blanik.
I should note that we have twenty or so gliders tied down under shade
hangars at the Tucson Soaring Club and we haven't had any serious
damage lately.
Old February 3rd 10, 06:39 PM posted to rec.aviation.soaring
Bob Kuykendall
Naw, just a nibble. Jim Phoenix could have that ship flying in a week.
Old February 3rd 10, 11:12 PM posted to rec.aviation.soaring
Bob Whelan[_3_]
"orient the glider 90 degrees to the wind and...keep... the upwind wing
on the ground" was what I was taught 'way back when' (in the good old
days learning on 2-33's and 1-26's...and I think it's Great Advice for
low-wingloaded ships. I mean - absent a real tiedown, of course.)
Since then, I've come to believe there's a better approach for
15-meter-span plastic ships. I've used it (when I've had to) in the
Rocky Mountain West since the mid 1980's for my 15-meter-span Zuni. Note
the HUGE CAVEAT (which no lawyer made me put in).
HUGE CAVEAT: This assumes wind from a constant direction!!!
I put the UPwind wing UP.
Short of a wind strong enough to actually lever the ship up and over its
downwind wing (in which case I don't want to be anywhere *near* gliders,
tied down or otherwise!), this is the stable position, as critical
assessment at many windy gliderports will (usually, quickly) show.
The most severe test ever given my ship was on an outlanding at a
deserted airport in a wind exceeding 30 knots, with gusts almost
certainly over 45; while I was waiting for my crew, a chain-reaction
fatal interstate accident happened nearby, induced by blowing dust and
inappropriate driver reactions. Though in July, with ground temps above
90F when I landed, well before sunset, concern over hypothermia induced
me to abandon the ship for the shelter of a fuel truck cab.
Thanks to the zephyr, the most difficult aspect was extracting myself
from the cockpit without damaging the (~5' long, removable)
canopy...which is why I made no attempt to stay with/in the ship after
trekking for a phone. I watched the ship until it got dark; beyond
'floppy-wing-assisted' rocking, it never budged.
YMMV,
Bob W.
Old February 3rd 10, 11:59 PM posted to rec.aviation.soaring
Tony V
the glider.
Then use the harpsichord!
Exactly! Then, tie the other end to the wing tie down point. I've found
that harpsichords rarely move in a hurricane.
Tony V
The FAA has just lost it HilldaBeast Piloting 1 November 15th 07 02:49 AM
Lost stories here Danny Deger Piloting 68 January 12th 07 12:43 AM
Lost stories here Larry Dighera Instrument Flight Rules 3 January 12th 07 12:43 AM
We lost in Nam. But not Rasimus Lisakbernacchia Military Aviation 12 June 12th 04 06:30 AM
fw-200 not "lost" old hoodoo Military Aviation 0 December 22nd 03 07:16 PM
