Transponder article updated with Trig info
Old February 13th 10, 12:59 AM posted to rec.aviation.soaring
Tony V
Default Transponder article updated with Trig info
Darryl Ramm wrote:
If the threat aircraft you are worried about are on flight following
(i.e. they have a transponder and can be seen on radar by ATC and have
bothered to actually contact ATC for flight following) then by
definition you are both likely to be in radar coverage and ATC should
be able to provide traffic advisories under flight following.
The above phrase "should be able to" is correct. ATC in the U.S. is only
required to provide VFR traffic advisories on a "workload permitting"
basis. If the controller has his hands full with IFR traffic, you lose.
Remember that lots of people file IFR on perfectly good VFR days.
Tony
Old February 13th 10, 04:16 AM posted to rec.aviation.soaring
Eric Greenwell
Hagbard Celine wrote:
When it came to the battery part of the article there was still
nothing on an specific NiMH or LiLon batteries. I was wondering if
anyone has tried either of the batteries from this company:
http://www.atsipowermanagement.co.uk/lynx.html 10 A/H in a PS1270 size
would be nice if it works.
It looks like it would be a good choice, but I was unable to find a
supplier or cost. You would have to buy it's charger, also, so the total
cost for this "aviation" battery might be breathtaking. Let us know if
you do find a supplier. It still might be a good option for some people,
even if it is costly.
If you use a Trig TT21, the power drain should be low enough that a 4 to
5 ah battery would be adequate - not ideal, but adequate for 8-10 hour
flights in cold weather. That size is small and light enough, almost
everyone should be able to mount a battery just for the transponder, if
needed. Pilot reports on the Trig power consumption, anyone?
On Page 15 of the article, I detail why I do not recommend Li batteries
for gliders. Here's what I say:
" IF you can find a 12 to 14 volt, commercially produced lithium battery
pack, AND rated for operation to 18,000’ (or your
highest operating altitude) AND with a matching charger, THEN you might
consider using it. I couldn’t find any that met all these conditions
(Dec. 2007), the best matches I could find cost several hundred dollars,
and they wouldn’t fit a standard glider battery mounting."
If you use a battery ONLY for the Trig TT21, you don't need to have a 12
volt battery. It could be up to 30 volts. That relaxed voltage
specification might make it easier to find a suitable nimh or Li
battery. Still, the standard lead acid battery works well, it's cheap,
it's easy to charge, and it's safe. The weight isn't really an issue in
most cases, given the 500+ pound weight of a glider.
Eric Greenwell - Washington State, USA (netto to net to email me)
- "Transponders in Sailplanes - Jan/2010" also ADS-B, PCAS, Flarm tinyurl.com/yg76qo9
- "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what you need to know tinyurl.com/yfs7tnz
Old February 14th 10, 04:11 AM posted to rec.aviation.soaring
Eric Greenwell
In response to the questions about batteries and couple outdated remarks
Paul Remde caught, there is a new update "B" available from:
* http://tinyurl.com/ylbu7a9
*Besides the updates, it now uses vertical lines to the left of any
paragraph with significant changes to make it easier to spot them.
It will also be on the soaringsafety.org website as soon as they can
update it (might be a few days)
Eric Greenwell wrote:
This article, originally in Soaring (Feb 2002) was updated recently to
include information on the Trig TT21 transponder.
- "Transponders in Sailplanes 2010B" also ADS-B, PCAS, Flarm *http://tinyurl.com/ylbu7a9*
Old February 15th 10, 06:55 PM posted to rec.aviation.soaring
Mike Schumann
On 2/12/2010 12:18 PM, Frank Whiteley wrote:
On Feb 12, 8:10 am, wrote:
Somehow we all need to get transponders in our gliders.
Bob
Lobby for stimulus money.
We don't need money. What is needed is for the FAA to permit the
commercialization of MITRE's low cost ADS-B transceiver. We are making
SLOW progress on that front. The FAA & SSA are going to do a
demonstration project this summer in the DC area.
If we can get ADS-B transceivers to be available at the same price point
as FLARM in Europe, we will see a similar explosion in deployment rates,
which will make soaring (and GA) a much safer environment.
Mike Schumann
New Trig TT22 Transponder Paul Remde Soaring 1 January 14th 10 07:27 PM
TRIG TT21NOW IN STOCK Tim Mara[_2_] Soaring 5 September 29th 09 10:29 PM
Trig TT21 Transponder receives FAA TSO approval Paul Remde Soaring 12 September 19th 09 02:47 PM
Trig TT21 Transponder Thoughts? jcarlyle Soaring 16 June 23rd 09 04:38 PM
Seeking KT-79 transponder install/operational info [email protected] Owning 7 July 26th 06 01:11 PM
