Hi, do any gliders have full-span flaperons that also act as airbrakes
(say at 70-90 degree), or do you lose all aileron authority when the flaperons are that deflected? |
Bert,
All the sailplanes, I am aware of, that use flaps for glide-slope control also have ailerons. (PIK-20B, 1-35, Concept 20, the entire Schreder series, etc.) None of the mentioned models' wing control surfaces are full-span flaperons. Wayne http://www.soaridaho.com/Schreder "Bret" wrote in message ... Hi, do any gliders have full-span flaperons that also act as airbrakes (say at 70-90 degree), or do you lose all aileron authority when the flaperons are that deflected? |
Wayne Paul wrote:
Bert, All the sailplanes, I am aware of, that use flaps for glide-slope control also have ailerons. (PIK-20B, 1-35, Concept 20, the entire Schreder series, etc.) None of the mentioned models' wing control surfaces are full-span flaperons. Wayne http://www.soaridaho.com/Schreder "Bret" wrote in message ... Hi, do any gliders have full-span flaperons that also act as airbrakes (say at 70-90 degree), or do you lose all aileron authority when the flaperons are that deflected? Kestrel 19m (Slingsby T59D) has full span flaperons with the same mixer capability of the ASW20 - the correct procedure is to put the flaps into negative territory, then apply the landing flap lever. That way you have wonderful roll authority, ailerons slightly drooped and ~35 degrees of landing flap. Flaps and ailerons are separate - The mixer applies proportional flap deflection to the ailerons - so - If you do it wrong the ailerons go to almost full down deflection and you only (effectively) have upward movement on one to cause roll. Makes turns onto finals interesting with those long heavy wings. I don't know of any sailplane design that uses full span single surface flaperons. --- news://freenews.netfront.net/ - complaints: --- |
On Mar 7, 12:17*pm, Bruce wrote:
I don't know of any sailplane design that uses full span single surface flaperons. LS6 & 10 have full span flaperons. Actually, built in two pieces and hinged separately (due to a kink in the trailing edge), but linked together and driven by one pushrod per side. No fancy mixer, landing flaps puts the entire training edge down about 15 degrees which adds a useful about of drag while keeping good aileron control. But the 6's landing flap in no way compares to the ASW-20, Ventus B, HP, PIK, etc. Those are FLAPS! Kirk 66 |
Bruce,
Your Kestrel seems to have a different setup from mine. I have a Series 1 bird, so maybe Slingsby changed the layout with later models? Tow release is under the left inner thigh, rudder pedal adjustment is under the right inner thigh. Drogue deploy is on the left cockpit sidewall above the air vent, just in front of the panel; drogue jettison is in the centre pedestal of the panel to the right of the landing flap handle (with the nose vent control pull-knob between them). For me, it's a quick movement of the hand from the spoiler lever forward to the drogue deploy; the drogue jettison is a bit further since I have to reach the panel just to the right of my stick. My spoliers only add 1 kt of sink, so I have to judge my location and height for when to put on full flap. I like the comment in my POH (sorry, can't quote it just now) about the spoilers being ineffective. |
To try and keep on point here, LS-6, LS-10, LS-3, PIK 20 D, Ventus C,
ASW-17 come to mind as having full span flaperons. The entire trailing edge moves the same amount when moved as flap or aileron. ASW-20, PIK 20B, Zuni, SGS 1-35, HP Series, 301 Libelle, Diamants, Ventus A/B, Kestrel, etc do NOT have full span flaperons. They have flaps and ailerons, and varying degrees of interconnection between the two. Only plane I know of that had a full span flap that was used at large deflections (greater than 30 degrees) was the HP-17. Notice, it did not have full span flaperons. It had spoilers for roll control. And I understand the contestants had a great time watching Schreder take off with it, as he went from tip to tip, side to side on the runway until he finally got the plane into the air. This was likely due to the fact that you could only reduce the lift a bit on the high wing and add drag to it to try and pick up the down wing. Full span, large deflection flaperons will likely provide very poor roll control at any deflection beyond about 30-45 degrees, as the flap will be likely be stalled, and the main thing you will get is differential drag or a yawing moment when you moved the stick to try and roll the plane. Oh, and I don't consider the Ventus A/B, Mini Nimbus, or Mosquito to have drag flaps. They have cruise flaps and trailing edge air brakes. Drag flaps have you looking out the top of the canopy at where you are going to land when you put them full on. You are still looking out the front of the canopy at where you are going to land with trailing edge air brakes. The ASW-20 was the first to get the ailerons back up as the flaps went on down, getting the plane into what a previous poster said is called "crow mode" in the model world. I think the biggest thing it does is makes it so the ailerons won't stall once you are on the ground in two point, tail low attitude. I don't think it was done for added drag or improved in flight handling. You already get ENORMOUS geometric twist when your inboard flap is down 50 degrees and your ailerons are still down 8. However, these flapped ships like to have the ailerons up when sitting two point on the ground in order to have aileron authority, and Schleicher got this (among so many other things) right by putting them back up so you can leave the flaps all the way down after you land. That way, your left hand doesn't have to keep jumping around in the cockpit grabbing different handles. Set the flaps, use the dive brakes and land. No more needed hand changes. Steve Leonard |
Steve Leonard wrote:
To try and keep on point here, LS-6, LS-10, LS-3, PIK 20 D, Ventus C, ASW-17 come to mind as having full span flaperons. The entire trailing edge moves the same amount when moved as flap or aileron. ASW-20, PIK 20B, Zuni, SGS 1-35, HP Series, 301 Libelle, Diamants, Ventus A/B, Kestrel, etc do NOT have full span flaperons. They have flaps and ailerons, and varying degrees of interconnection between the two. Only plane I know of that had a full span flap that was used at large deflections (greater than 30 degrees) was the HP-17. Notice, it did not have full span flaperons. It had spoilers for roll control. And I understand the contestants had a great time watching Schreder take off with it, as he went from tip to tip, side to side on the runway until he finally got the plane into the air. This was likely due to the fact that you could only reduce the lift a bit on the high wing and add drag to it to try and pick up the down wing. Full span, large deflection flaperons will likely provide very poor roll control at any deflection beyond about 30-45 degrees, as the flap will be likely be stalled, and the main thing you will get is differential drag or a yawing moment when you moved the stick to try and roll the plane. Oh, and I don't consider the Ventus A/B, Mini Nimbus, or Mosquito to have drag flaps. They have cruise flaps and trailing edge air brakes. Drag flaps have you looking out the top of the canopy at where you are going to land when you put them full on. You are still looking out the front of the canopy at where you are going to land with trailing edge air brakes. The ASW-20 was the first to get the ailerons back up as the flaps went on down, getting the plane into what a previous poster said is called "crow mode" in the model world. I think the biggest thing it does is makes it so the ailerons won't stall once you are on the ground in two point, tail low attitude. I don't think it was done for added drag or improved in flight handling. You already get ENORMOUS geometric twist when your inboard flap is down 50 degrees and your ailerons are still down 8. However, these flapped ships like to have the ailerons up when sitting two point on the ground in order to have aileron authority, and Schleicher got this (among so many other things) right by putting them back up so you can leave the flaps all the way down after you land. That way, your left hand doesn't have to keep jumping around in the cockpit grabbing different handles. Set the flaps, use the dive brakes and land. No more needed hand changes. Steve Leonard And unfortunately Schleicher patented the mixer - so one of the more effective safety innovations has not been widely used. Relying on a manual process as per T59D is a busy solution and error prone. So it looks like the industry went to more powerful airbrakes and dump the flaps on the ground run. Pity really. --- news://freenews.netfront.net/ - complaints: --- |
flaperons. I know I'm getting in late on this but the original LS-3 had one full- span control surface per wing panel. It was fairly flexible (said anyone who ever removed one from the wing for maintenance) and apparently required a fair amount of lead to mass balance (IIRC, 40 lbs. was mentioned, probably split between left and right). The result was that the wings were not only quite heavy (175 lbs.each) but the balance was biased towards the trailing edge, making it more awkward to handle during rigging. Maximum flap settings were -7 to +10 degrees, probably to prevent the one-piece surface from distorting or even splitting/buckling at the trailing edge at higher wing deflections. The wing itself was very stiff (probably another reason for its weight since this was pre-carbon fibre) so the deflection in turbulence was low (read: it was a rough ride on the ridge). It sounds a little odd but the glider was a joy to fly and both climbed and ran very well when new. Alas, LS-3s experienced shrinkage over the spar caps over time, which hurt the cruise performance though they still climbed well. Some owners (including me) sanded and/or added gel coat/ filler to restore the original profile and the glider was transformed, making it equal to the ASW 20, Ventus, and LS-6 of its day. It's still a great, wonderfully strong airplane with a lot of performance that gives its owners a great deal (for one with a good finish). Not to be confused with the LS-3a or LS-3 17, both of which had more conventional flap/aileron control surfaces and lighter wing panels. Chip Bearden ASW 24 "JB" USA |
On Mar 19, 2:58*pm, Chip Bearden wrote:
I don't know of any sailplane design that uses full span single surface flaperons. I know I'm getting in late on this but the original LS-3 had one full- span control surface per wing panel. It was fairly flexible (said anyone who ever removed one from the wing for maintenance) and apparently required a fair amount of lead to mass balance (IIRC, 40 lbs. was mentioned, probably split between left and right). The result was that the wings were not only quite heavy (175 lbs.each) but the balance was biased towards the trailing edge, making it more awkward to handle during rigging. Maximum flap settings were -7 to +10 degrees, probably to prevent the one-piece surface from distorting or even splitting/buckling at the trailing edge at higher wing deflections. The wing itself was very stiff (probably another reason for its weight since this was pre-carbon fibre) so the deflection in turbulence was low (read: it was a rough ride on the ridge). It sounds a little odd but the glider was a joy to fly and both climbed and ran very well when new. Alas, LS-3s experienced shrinkage over the spar caps over time, which hurt the cruise performance though they still climbed well. Some owners (including me) sanded and/or added gel coat/ filler to restore the original profile and the glider was transformed, making it equal to the ASW 20, Ventus, and LS-6 of its day. It's still a great, wonderfully strong airplane with a lot of performance that gives its owners a great deal (for one with a good finish). Not to be confused with the LS-3a or LS-3 17, both of which had more conventional flap/aileron control surfaces and lighter wing panels. Chip Bearden ASW 24 "JB" USA And due to the lead in the wings, the German speakers in this group will understand why the "LS-Drei" was referred to as the LS-Blei"... Ray Lovinggood Carrboro, North Carolina, USA |
I've heard the LS-Blei joke many times, and laughed ruefully.
![]() Interestingly, however, while the wings ARE heavy (my entire ASW 24 wing weighs as much as the root end of my LS-3 wing!), they're comparable to those of the ASW 20B, a much more highly thought of glider with almost identical performance (when the LS-3 wings are profiled properly, that is). Pursuant to the original poster's question, I should have added that the LS-3 has large, very effective conventional dive brakes and does not rely on the flaps for glide path control. Also, while the ailerons are light and very effective when the flaperons are set at 0 to 10+ degrees, the stick is very stiff with the flaperons at -7 degrees (at least in my old glider). I didn't have much ridge time in my LS-3 but I recall on more than one occasion yanking the flaps down when encountering a strong rolling motion so that I could apply countering aileron. This also had the effect of lifting me off the ridge at the same time. It was a nice combination but I would have prefered just being able to roll a little easier. Pilots with more ridge time might disagree this was necessary but the ailerons were still very stiff. I presume this was from the geometry of the mixer since much of it was apparent even on the ground. I hope I'm not making the LS-3 out to be unpleasant in any way. It was a great glider that I flew happily for many years. Chip Bearden ASW 24 "JB" USA |
D.C. anti-war rally on C-SPAN today at 8:15 AM on the west coast of US and at 11:15 AM on east coast - President Carter at Brandeis on C-SPAN 2's 'Book TV' today at 12:30 PM (on the west coast and at 3:30 PM on the east coast): | [email protected] | Naval Aviation | 0 | January 27th 07 02:18 PM |
Airbrakes Pop Out at 115 kts | ContestID67 | Soaring | 13 | May 10th 05 01:50 PM |
ASW19b best descent rate on approach (full airbrakes) | Robert Sharpe | Soaring | 1 | April 30th 05 11:41 AM |
Radio protocol regarding full stops on full stop only nights | Ben Hallert | Piloting | 33 | February 9th 05 07:52 PM |
Flaperons | Lou Parker | Home Built | 26 | November 15th 04 04:40 AM |
