Grease recommendation
Old April 2nd 10, 08:57 PM posted to rec.aviation.soaring
Whiskey Delta
Default Grease recommendation
On Mar 28, 6:29*pm, Bob Backer wrote:
+1 used the stuff for years. *works grea
Herb
What do folks put on nuts and bolts (as opposed to wing pins,
bearings) that may be showing a little surface corrosion. Same stuff
as above (super lube, lithium grease, etc)? Is there any concern
about the anti-corrosion treatment causing the nuts to loosen up?
WD
PDA recommendation alex8735 Soaring 8 March 22nd 08 08:29 AM
HSI Recommendation? randall g Owning 6 June 13th 07 09:22 PM
2.4 hours - no oil/grease on prop/windshield Jay Honeck Owning 8 September 30th 06 01:25 PM
ELT Recommendation Dean Owning 3 April 26th 06 09:08 AM
ASW 20 Recommendation? Eric Greenwell Soaring 1 August 11th 03 06:56 AM
