Hi,
I've put some lecture slides on the following topics: * Principles of glider flight * Glider instruments onto the web site: http://www.carrotworks.com/ Regards, Richard |
On Apr 14, 9:18*am, (Richard Lancaster)
wrote: Hi, I've put some lecture slides on the following topics: * Principles of glider flight * Glider instruments onto the web site: http://www.carrotworks.com/ Regards, Richard You might want to check on the accuracy of the oft-repeated myth that wings develop lift because of the pressure difference between the upper and lower surfaces. My understanding of the physics is that this component is negligible compared to the second mechanism you mention of the downward deflection of the airflow. If you think I am mistaken, then please explain how symmetrical airfoils develop lift! Mike |
airfoils develop lift! Mike angle of attack. |
Richard and Mike, you're both a little bit wrong.
I like the slide showing the airflow around the airfoil section, few illustrations show how the streamlines change on the lower surface. A lot just keep them flat. However, if I'm to interpret the length of the vectors as the local velocity in the flow field, then the vectors on the lower surface look in error. They also typically accelerate to a velocity greater than freestream. Which brings me to the problems I have with the chart on page 8. The pressure forces on the lower surface are not acting in the direction as shown. Because the air also has to accelerate around the lower surface, it too is a lower pressure than ambient and is therefore acting positive to the surface normal. Or in the diagram, downward. However, the net difference between the upper and lower surface yields a positive lifting force. This site has very good diagrams that show the direction and magnitude of the pressure forces on an airfoil. It also shows how the pressures react for symmetric airfoils. http://www.dynamicflight.com/aerodyn...pres_patterns/ Mike, I think the common mis-understanding to which you are referring to is the oft stated quote that because the surface is longer on the top than the bottom, the air has to travel faster to meet at the end. Geometrically, this difference is near 1%, and clearly any velocity delta driven by the distance would not be significant. However, no such rule requires that they meet at the end, and in reality they don't. There are two ways to look at how an airfoil creates lift. And both are correct. The Pressure theorists look at the difference between the upper and lower surface and calculate lift. If you integrate the pressures on the airfoil you'll end up with the same calculation that you get from momentum theory which looks at the imparted change in momentum of the airmass which is deflected downward. Both are correct and both happen. The difference is how you look at the problem. You can examine it near field in which case you look at the pressures on the surface, or you can examine it far field and examine the change in airmass movement imparted by the airfoil as it moves through the air. As for symmetric airfoils, they won't produce lift at an angle of attack = 0. But as Tony says, change the angle of attack and it produces lift. And now you know why. -Kevin |
Mike the Strike wrote:
You might want to check on the accuracy of the oft-repeated /myth/ that wings develop lift because of the pressure difference between the upper and lower surfaces. My understanding of the physics is that this component is negligible compared to the second mechanism you mention of the downward deflection of the airflow. If you think I am mistaken, then please explain how symmetrical airfoils develop lift! Mike Amusing how partisans grow zealous for their chosen explanation! :-) Brian W |
On Apr 15, 5:14*pm, brian whatcott wrote:
Mike the Strike wrote: You might want to check on the accuracy of the oft-repeated /myth/ that wings develop lift because of the pressure difference between the upper and lower surfaces. *My understanding of the physics is that this component is negligible compared to the second mechanism you mention of the downward deflection of the airflow. If you think I am mistaken, then please explain how symmetrical airfoils develop lift! Mike Amusing how partisans grow zealous for their chosen explanation! :-) Brian W Actually, we physicists get annoyed when people get the science wrong. Mike |
On Apr 15, 5:14 pm, brian whatcott wrote: Mike the Strike wrote: You might want to check on the accuracy of the oft-repeated /myth/ that wings develop lift because of the pressure difference between the upper and lower surfaces. My understanding of the physics is that this component is negligible compared to the second mechanism you mention of the downward deflection of the airflow. If you think I am mistaken, then please explain how symmetrical airfoils develop lift! Mike Amusing how partisans grow zealous for their chosen explanation! :-) Brian W Actually, we physicists get annoyed when people get the science wrong. Mike Hehe....good one, Mike! :-) Brian W |
On Apr 15, 9:20*pm, Mike the Strike wrote:
On Apr 15, 5:14*pm, brian whatcott wrote: Mike the Strike wrote: You might want to check on the accuracy of the oft-repeated /myth/ that wings develop lift because of the pressure difference between the upper and lower surfaces. *My understanding of the physics is that this component is negligible compared to the second mechanism you mention of the downward deflection of the airflow. If you think I am mistaken, then please explain how symmetrical airfoils develop lift! Mike Amusing how partisans grow zealous for their chosen explanation! :-) Brian W Actually, we physicists get annoyed when people get the science wrong. Mike Mike, You might want to check your own physics, before making comments like this. Because us aerodynamicists get annoyed when people get the science wrong :-) Symetrical airfoils work the same way asymetric foils work. The air is pushing up on the bottom, stronger than the air is pushing down on the top. If the pressure was the same on the top and bottom surfaces, there would be no lift. Please, don't confuse pressure differential with the incorrect "equal transit time" theory. I have lost my favorite link to a well presented and complete theory of lift, so I can't post it here. But the short version is: angle of attack makes the air flow change direction that change of direction makes air pressure rise on the bottom ( but not by much ) air pressure drop on the bottom ( most of the change) And it all happens because of the Kutta Condtion. http://en.wikipedia.org/wiki/Kutta_condition If you are going to berate people for their own incorrect knowledge, you should be able to improve on that knowledge. The original posters slides look like a pretty good explanantion. I think that it is more information than a pilot really needs, but some people won't relax and actually learn until they think they understand "why" it works. Todd Smith Masters of Science Aerospace Engineering 1990 |
On Apr 16, 1:18*pm, toad wrote:
If you are going to berate people for their own incorrect knowledge, you should be able to improve on that knowledge. The only flight theory that most pilots need to know is that sustained flight requires a continuous supply of money. It is easy to prove that when the supply of money is exhausted flight is no longer possible. Andy |
toad wrote:
The original posters slides look like a pretty good explanation. I think that it is more information than a pilot really needs, but some people won't relax and actually learn until they think they understand "why" it works. That's probably the best reason I've heard for teaching pilots about aerodynamics. Despite my deep interest in aerodynamics, my observation and experience is knowing the aerodynamics doesn't seem to be an asset to flying correctly, and that it is really all about keeping the airspeed up and horizon in the correct place on the canopy. When I fly, thoughts of AOA and pressure distributions are not flitting through my mind, and things happen too fast to be deriving your next action from first principles. You definitely want the designer of your glider to understand aerodynamics, but the pilot - completely optional! -- Eric Greenwell - Washington State, USA (netto to net to email me) - "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm http://tinyurl.com/yb3xywl - "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what you need to know tinyurl.com/yfs7tnz |
SU-30 MKI at Red Flag Lecture | Mike[_7_] | Naval Aviation | 1 | November 13th 08 06:51 PM |
Catalina Lecture - LHR | Merlin | Piloting | 0 | January 30th 06 09:39 AM |
Catalina Lecture - LHR | Merlin | Restoration | 0 | January 30th 06 09:39 AM |
Barnaby Lecture Oct 1st | Frank Whiteley | Soaring | 0 | September 27th 05 02:40 PM |
FA: A-10 and F-14 slides | THE RIPPER | Aviation Marketplace | 0 | August 26th 04 06:37 AM |
