Redbird's new full-motion, low-cost flight simulator
Old March 28th 11, 02:30 AM posted to rec.aviation.piloting,rec.aviation.student
Brian Whatcott
Default Redbird's new full-motion, low-cost flight simulator
On 3/27/2011 5:56 PM, Dimitri P. wrote:
On Mon, 05 Jul 2010 20:14:19 -0400, vaughn
As a student pilot, I insisted on pre-solo spin training. If I ever
screwed up
enough to get myself into an inadvertent spin, I did not want to be
required to
figure out spin recovery for myself!
well said. Especially figuring out spin recovery during short final,
where they are more likely to occur! I was fortunate enough to be part
of the student pilots where spin training was mandatory in Canada in 1999.
Hmmm...'short final' means 500 ft to me.
Spin recovery means more than 500 ft to me.
Better to maintain approach speed, and recover from a stall if you must,
not a spin.
Briaan W
Old March 28th 11, 02:31 AM posted to rec.aviation.piloting,rec.aviation.student
Brian Whatcott
On 3/27/2011 7:47 PM, vaughn wrote:
"Dimitri wrote in message newsp.vs0x00zt8gnu4d@main...
On Mon, 05 Jul 2010 20:14:19 -0400, wrote:
As a student pilot, I insisted on pre-solo spin training. If I ever screwed
up
enough to get myself into an inadvertent spin, I did not want to be required
to
well said. Especially figuring out spin recovery during short final, where
Huh? If you are on short final, you had better recover quickly from the
pre-stall, well before the actual stall and wing-drop! Because on short final
there isn't enough sky beneath you for a spin recovery. In fact, a befuddled
pilot may not be able to recover from pattern height at all. One of my main
take-home impressions from my pre-solo spin training was the loss of altitude
involved in the stall-spin-recovery sequence. It made me understand the
importance of maintaining airspeed and staying coordinated in the pattern.
Vaughn
Now you're talking!
Brian W
Old March 28th 11, 03:49 AM posted to rec.aviation.piloting,rec.aviation.student
Dimitri P.
not a spin.
Very true. But a spin (incipient) -- or any other type of cross-control
stall is more likely to occur during the landing phase. Say you're
approach, for some reason you're already stepping on the rudder, student
pulls to "stretch" the glide. A wing is more likely to drop upon
stalling... (spin) and recovery is a matter of luck. Else, it might turn
into something like a "under the bottom stall". Nasty stuff... Spin
training to me, means "awareness" to such thing. Not necessarily a
guarantee that low altitude cross-control stalls can be recovered without
ending in a "under the bottom stall" or if slipping, in a "over the top
stall" But, if well trained, I believe that with some quick instincts and
luck, recovery may be possible.
Old April 4th 11, 12:19 PM posted to rec.aviation.piloting,rec.aviation.student
Brent[_2_]
That is one of the funniest and strangest differences between canadian and
american flight training
It is a required demonstration for Canadian private pilots and a canadian
flight school cannot be licensed and operate unless it has at least one
aircraft certified for intentional spins. Canadian commercial pilots are
required to recover from an incipient spin as part of fligh training. (In
the last year Canada has shifted the focus from spin excecution to pure
recovery in the incipient phase)
Spins spend altitude like ther is no tomorrow and to my pleasure the biggest
thing i learned from round 2 (insurance signoff of my plane) in the cherokee
140 is just how MUCH it takes to make it spin. In order to spin the plane i
essentially had to throw it out of the sky sideways with a full stomp of
uncoordinated rudder. (mind you it recovers in an almost vertical attitude
requiring swift action)
"Dimitri P." wrote in message
screwed up
required to
where they are more likely to occur! I was fortunate enough to be part of
Old April 21st 11, 03:07 AM posted to rec.aviation.piloting,rec.aviation.student
As a student pilot, I insisted on pre-solo spin training. *If I ever
screwed up
required to
well said. *Especially figuring out spin recovery during short final,
where they are more likely to occur! *I was fortunate enough to be part of
We have a Redbird. About $100 per hour. In Canada we can do up to
half of the 40 hours IFR training in a sim, even if it's multi, and
since the Seneca plus instructor is well over $300/hour, the Redbird
does it far cheaper and we don't have to have flyable weather and the
Redbird is never off line for maintenance. The motion is minimal, but
it's enough to create vertigo and the student learns to trust the
instruments instead of his sense of balance. We also do the first few
hours of ab initio in it, saving the student several hundred bucks on
the Private. Much of the first few hours is just spent learning how to
start, taxi, make radio calls; stuff that happens on the ground but
still costs the full rental rate. Again, Redbird is cheaper and it can
be paused to explain something. Hard to do that with the real
airplane.
Spin training in Canada is done to teach not only recovery but the
various scenarios that lead to it. If one never experiences a spin,
it's all theoretical. Once a student has been into a spin out of a
skidding descending turn, he never skids that base-to-final turn
again. Ever. And he learns that trying to raise the dropping wing with
aileron is stupid. Spins are safe if taught properly. They don't
overstress the airplane at all. And they're not taught at 500 feet.
Spins are like taildraggers: they need to be experienced. There's no
other way to get clear of the fear of such stuff.
Dan
Simulator + Motion? [email protected] Simulators 10 December 20th 03 08:58 PM
Low Cost Motion Simulators For PC Games!!!! Mark Barry Military Aviation 0 December 19th 03 03:37 AM
Full motion home flight simulator. The Enlightenment Military Aviation 10 November 25th 03 12:36 PM
Full motion home flight simulator. The Enlightenment Naval Aviation 10 November 25th 03 12:36 PM
Full Motion Flight Simulator Available For Training in SW Pennsylvania Richard Kaplan Products 0 August 30th 03 03:57 PM
